possible or hybrid problem
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cheanko, Aug 29, 2014.
  1. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Hopefully a battery load test would disprove that?
    52,351
    if you can find a dealer who knows how to do one.
  3. cheanko
    cheanko New Member
    2013 Prius Plug-in
    Shouldnt all dealers know how to do that?i had trouble with my car this morning again.i had to do 2 tries to turn it on.definetely the 12v right?
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    I would think so!
  5. Okinawa
    Okinawa Senior Member
    1,333
    320
    And IF they will go through the trouble of doing it.
  6. srl99
    srl99 Member
    113
    2014 Prius Plug-in
    any full service auto parts store that sells batteries will have a battery tester, and quite often a battery test is free. If you are lucky (or the appropriate gender!) they may even take the battery out of the vehicle and put it back in later.
    #26 srl99, Sep 1, 2014
  7. cheanko
    cheanko New Member
    2013 Prius Plug-in
    And i forgot to mention ev miles went back up to 8 miles without any charging.maybe the computers are confused because of low battery?
  8. bisco
    52,351
    possibly. i'm sure there are mechanics who know how to test a battery. all too often, they hit the power button, if she fires up, the battery is fine. if you can watch them test it and get the results, that would be helpful.
  9. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Checking the battery is pretty easy to do yourself with a multimeter.
    12-volt battery
    Open voltage at 68 °F (20 °C): Manual page 567
    12.6 - 12.8 V Fully charged
    12.2 - 12.4 V Half charged
    11. 5 - 11.9 V Discharged
    (Voltage is checked 20 minutes after the system and all lights are turned off.)
    I have some test leads routed to the back seat so I can have the meter connected and read it through the window after the 20 minutes. That way there is no load except the usual very small 35 ma or so that runs the computer.
    Potorap likes this.
  10. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Cheanko,
    My suggestion is to purchase a battery tender for about $50 and use it on a regular bases. Minimum once a week. Also has any lights been left on that may have drained it? Good luck and let us know.
  11. Potorap
    345
    148
    Pahrump, Nv
    Hey California Bear,
    I love your idea about the meter. Would you post pics please? Thx. I connected pig tails for both our PIPs so I can plug in charger in easily. Only need 1 charger to swap between them.
  12. CaliforniaBear
    1,180
    289
    Northern California
    Not much to show.
    Clips on the battery terminals, wire routed to the back seat.
    Double ended banana plug leads, be sure to plug into the meter first.
    Back windows are tinted so I have to view the voltage with a flashlight in the garage. This
    reading is a little low because it was made without waiting the 20 minutes and door was open
    so dome lights were a draw on the battery. My readings are typically 12.6 to 12.77
    #32 CaliforniaBear, Sep 1, 2014
    Potorap likes this.
  13. Potorap
    345
    148
    Pahrump, Nv
    Thanks, very nice.
  14. srl99
    srl99 Member
    113
    2014 Prius Plug-in
    Thanks for this, I haven't driven the PiP in several weeks, and you prompted me to check the 12V batt voltage. 12.29, a bit low. We'll be taking it for a drive today!
    I happened to look at the specifications section for the 2014 (and 2015!) PiP. I believe Open voltage means with at least one of the battery terminals disconnected, as you might expect if a battery tester is being used. [Suggest you pull the + terminal!] (Different than those posted by California Bear, especially, discharged is < 11V.)
    12-volt battery Open voltage*1 at 68F (20C):
    Fully charged 12.5 V or over
    Half charged 11.0 - 12.5 V
    Discharged Under 11.0 V
    Charging rates 5 A max.
    *1: Voltage is checked 30 seconds after the hybrid system and all lights are turned off.
    #34 srl99, Sep 1, 2014
  15. cheanko
    cheanko New Member
    2013 Prius Plug-in
    Same thing again this morning..1 try to start the engine and another 8 ev miles.bringing it in tomorrow for repair.i will be updating tomorrow.
  16. bisco
    52,351
    all the best!(y)
  17. cheanko
    cheanko New Member
    2013 Prius Plug-in
    Thanks!if they dont find anything tomorrow,i am going to ask them to leave my car overnight and test it the next day.for sure they will find out the problem by then.
  18. bisco
    52,351
    you may need to do that so they observe the ev estimate jumping around. it would be well worth it.
  19. GregP507
    GregP507 Senior Member
    3,002
    481
    I think the world awaits for a better charge indicator. In a wet lead-acid cell, a hydrometer can measure the state of charge by reading the density of the electrolyte. Perhaps someone will come up with an internal sensor which can more accurately measure the amount of usable electrical energy in a hybrid battery.
  20. GregP507
    3,002
    481
    IIRC, for a brief period of time, HP had a calibration program which load-tested the laptop battery by completing a discharge-charge cycle on the battery. This was designed to make the battery-level indicator more accurate, but it wasn't very successful as I recall. Also, deep-cycling is hard on lithium-ion cells, degrading their longevity.
