ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. Elsiediveley
    Elsiediveley New Member
    Chunky, MS 39323
    OK, then, as I plan to see if I can get 300,000 miles from this 2014 [ Elsie's first Prius-- a 2005-- was sold to a family friend,, it now has over 300,000 miles on it, no problems ] I will change mine early also. I guess I should suggest to her to get hers changed also. [ E.T.A.,, just advised Elsie to have hers changed, she said, ''OK'' ]
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,738
    Bay Area
    The problem I see here is that you need a stubby hex and not the long hex that you have to fit your breaker bar without the extension. I used the stubby hex and it works fine.
  3. lester williams
    227
    68
    mississippi
    Home now, Elsie will get hers changed this week--- we are going on a week long ''motor trip'' to Colorado a few weeks into Sept., it will be time for my ''10,000 mile oil change'' from dealer upon return [ had first and paid for one at 2,050 ] and will pay for the ATF then. Sometimes,,, this stuff is cheap....
  4. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    I hate to bring up an old argument, but here it goes. I am planning to change my fluid at the dealer for first time at 10k then I plan to do it myself at 30k, which will be less than a year from now. I have always been a fan of Mobil and Amsoil lubricants and I checked today at the local autoparts store and the Mobil says it is not compatible with the Toyota ws. I also checked Amsoil's website and they now have 2 fluids that are compatible with Toyota ws. That being said what do I have to gain using Amsoil for my second change over using Toyota ws? I trust Amsoil and I have easy access to it considering I drive within one block of one of their warehouses everyday (and I checked I can buy it there if I want to). I
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Say what ?
  6. kenichols29
    250
    109
    Mckinney, Texas
    I read this entire thread and people have been arguing over wich is the best, mobil, redline d4 or d6, Toyota ws, and amsoil. I don't have access to redline products where I live. I just want to know if people recommend amsoil now that it meets toyota ws standards.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    Ah.
    The peeps that use Amsoil recommend it.
    On the other hand, those who use WS do not.
    kenichols29 likes this.
  8. Mendel Leisk
    41,398
    I wouldn't risk using anything other than Toyota ATF-WS.
  9. gliderman
    gliderman Active Member
    751
    225
    I think you should do the research and make up your own mind. All Amsoil dealers are going to swear by their product. Toyota will always stand by theirs also. So you pick whatever you want and go forth. If your just looking for a healthy debate, try reading all the transaxle fluid change threads. There is plenty of advocates either way you go. Good luck!
    irrational likes this.
  10. NutzAboutBolts
    1,693
    1,738
    Bay Area
    Be safe than sorry, what happen to that? go with Toyota WS lol, or read the label on the product and see if its equivalent to the WS fluid.
  11. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Yeah, and see if they not only say it's compatible with Toyota ATF-WS, but back it up in writing. As in, will they buy you a transaxle if their fluid causes yours to fail? ;)
    SCH-I535
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'll be happy to provide that warranty*.
    *All owner has to do is prove causation.
  13. Mendel Leisk
    41,398
    I'm surprised (or maybe not) that people can read this in the Owner's Manual:
    And then the next question out of their mouths is: what alternatives can I use?
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    LOL
    The even more curious thing is that the alternative is not cheaper and not superior. So where is the advantage ?
    Choking on gnats but swallowing elephants comes to mind.
  15. Mendel Leisk
    41,398
    ^ Yup. Well, more expensive equals better, right?
  16. frodoz737
    frodoz737 Top Wrench
    4,694
    2,495
    33
  17. Mendel Leisk
    41,398
    Saw that movie, with the kids, pretty much the night it opened. The audience basically exploded during that scene.
  18. Bill Norton
    Bill Norton Senior Member
    2,146
    734
    MONW, Ks.
    Expensive/Synthetic usually does = better.
    Isn't that the theory with your engine oil?
    WS is the house brand of a generic ATF that Toyota uses in their entire fleet. There is nothing unique about it.
    It has a viscosity spec. If a synthetic has a similar spec wouldn't that be a better lube?
    The eCVT in the Prius is a box of gears and bearings. It's surprisingly simple! It needs a clean lube (no filter, no magnetic drain plug).
    Anything similar to ATF could probably be used with no problem.
    Amsoil makes an 'FE' (?) version of ATF that has a similar viscosity spec to WS.
    Remember: Toyota is not 'All Knowing' on this subject. They don't tell you to change this nasty brew that develops in the transaxle.
    frodoz737 likes this.
  19. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    No but they tell the trainee technicians! I would want to know if non Toyota brands could guarantee no damage to the electric motors.
  20. Mendel Leisk
    41,398
    Bill, you really carry the torch for this subject. The way I look at it: if they tell me adamantly to use their fluid, and it's a multi-grand transaxle repair in the balance, I'll go fry other fish. ;)
    Cripes, you traded your's in about a year back. And I recall you saying "I'm outa here".
