Rear wheel bearing replacement
Discussion in 'Generation 1 Prius Discussion' started by AlexY, Jul 27, 2014.
  1. Prodarwin
    Prodarwin Junior Member
    30
    2002 Prius
    Well, I got them apart. I soaked the backside of everything with penetrant a bunch of times. I heated the backing plate up around the hub with a torch for 10 minutes. Then I just pounded on the hub with a hammer, holding the whole assembly in place with a pair of vice grips via the backing plate. Eventually the hub looked like a mangled mess, but came loose.
  2. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Bravo! may be mangled, but if you save 8 of them you can use them to play Bocce... 148_6181.JPG
  3. DaveGoodrich
    DaveGoodrich Member
    141
    68
    I love how these "high-tech" cars are old enough to be getting the shade tree/sledgehammer/torch treatment. It is starting to sound a lot more like the jeep forums I frequent. My kind of place.
    robert mencl likes this.
  4. bwilson4web
    16,326
    A couple of undocumented procedures:
    • After cleaning out road-gunk, use a medium, flat inserted to free the socket lock.
    • Top bolts are 17 mm and bottom pair are 12 mm
    #44 bwilson4web, Sep 20, 2014
