2002 Prius lacking power with high revs of engine after a few minutes o driving but restart fixes it
Discussion in 'Generation 1 Prius Discussion' started by racerx944, Sep 9, 2014.
  1. racerx944
    racerx944 Junior Member
    LA, CA
    2002 Prius
    I
    Hi all,
    I am new to this forum and need some help with my 2002 prius. It runs well and everything works with 1 weak cell in the HV battery p3006 and 03017 so I isolated it to cell #13 reading 6.6v. I am going to replace the weak cell next week and I will be careful not to touch the 2 ends of the battery and electrocute myself. I will also clean all of the connecting strips and place the cells in descending order (volts).
    After I drive it for a few minutes, the car loses power and the engine RPM becomes high. Sometimes the LCD screen would flicker. The strangest thing is that everything resets and if I pull over and shut off the car/restart, the car runs great.
    Has anyone encountered this problem and if so, what is the fix? Thanks in advance.
    #1 racerx944, Sep 9, 2014
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, those are classic symptoms of a dead/dying/weak HV Battery. You really should rebuild your whole battery rather than replacing just one cell.
    xpcman likes this.
  3. Adam Oas
    Adam Oas New Member
    Dallas, TX
    2002 Prius
    I
    Those are basically the same symptoms that we had in our first NHW11 before we replaced the cells.
  4. racerx944
    LA, CA
    2002 Prius
    I
    Thanks for the input. Since I already bought a used (tested good) cell, I am going to install it to see how it works out. I bought the car recently and want to put some miles on it to make sure everything else works before I sink money in the future to upgrade the HV battery to Gen II cells or buy a parts car for it. I will update the thread with results.
    BTW I read that it was a good idea to buy a good transaxle so I picked one up taken out of a wrecked car for $300.
  5. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Hi Racer, please be careful on your HV battery project and get someone working along with you who is an electrician if it is a first time evolution for you, there is a bit more to it than "being careful not to touch the two ends of the battery" and mistakes here can easily be fatal.
    I had the same symptoms you list 2 months ago, and the car is like a new one after some battery work. Wishing you the same success!
    On your spare transaxle, have you seen Carolyn Coquilliete's video on replacing MG2 stator with the transmission still in the car?
    Sincerely, R.
    #5 robert mencl, Sep 11, 2014
    bwilson4web likes this.
  6. racerx944
    LA, CA
    2002 Prius
    I
    I received the used cell from Ebay for $40 and took the HV battery out. I was doubtful that one single bad cell could cause all these problems. I took the battery out and put it back all together without any mishaps.
    After taking the bad cell out, I understood why the car ran so badly. The side of the cell looked like it suffered from a mini explosion followed by a small fire as there are black carbon burn marks with a piece of solder inside of the cell exposed and visible from the outside. It partially melted the side of the adjacent cell. After I replaced that single cell, all of the warning lights went off and car runs great getting 45+mpg.
    Amazing how one single cell can make the car almost undrivable.
    Aaron Vitolins and usnavystgc like this.
  7. bwilson4web
    16,012
    Pictures?
  8. racerx944
    LA, CA
    2002 Prius
    I
    Here is a picture of the failed cell. After driving for a couple days, the P3006 code comes up again with a p3076 for abnormal air flow by battery cooling fan so I think I may have to take the battery completely apart and match the cells. In the meanwhile, the car runs fine with 400+ miles driven at 44.2mpg. Notice the crack on the top of the cell on the left and right corners.
    #8 racerx944, Sep 20, 2014
  9. racerx944
    LA, CA
    2002 Prius
    I
    Update after replacing another cell that tested unusually low but it was tricky to track down because it tested the same voltage with the rest right after a drive but voltage drops much faster than the rest of the cells overnight. This time I took every one of the cells out and tested them with a voltmeter to arrange them in descending order. It was difficult because I drove the car shortly before the battery removal and the cells were measuring around 8 volts and dropping over time. The reading would change and I had to rearrange the batteries because some would drop a little faster than others so that presented a little bit of difficulty. In the end, the highest cell had 7.99 volts and the lowest had 7.81 and 7.80 with most of them around 7.91 and 7.92. In the pack, there were 11 gen 2 cells and 27 gen 1 cells with the weakest 2 (7.82 and 7.80 volts) from the gen 1 so I will replace them next with gen 2 cells.
    One word of caution is during the reassembly of the cells, I had both hands on the metal 3/8" socket extension turning the 8mm nuts tying the cell terminals together and felt a small electrical shock. I was wearing shoes on carpet and did not touch anything with both hands other than the extension to turn the one single nut so I did not short myself on anything. I am still puzzled as to how electricity flowed through my hands. Needless to say, I used thick rubber gloves for the rest of the nuts.
    A few hundred miles later, no more check engine light and the gas mileage went up to to around 47mpg+ as opposed to 44mpg before. The car runs in electric mode only much longer than before especially in traffic. A couple bad or low cells so far seem to make a big difference.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, one bad cell screws up everything. Your battery is only as strong as your weakest point. If the bad cell has .1 Ah of capacity, the whole pack has .1 Ah of capacity.
    GrumpyCabbie likes this.
  11. ChapmanF
    17,352
    How much of an issue was it where the bus bars had to connect between Gen 1 and Gen 2 modules? My understanding was the Gen 2 modules are a bit longer, and the terminal positions aren't quite the same.
    If you had both hands on the same metal wrench, then there'd have been no tendency for current to flow between your hands, but more likely from (both) your hands to another part of your body. For that to happen suggests there was a conductive path between some other module and (probably) the metal case, resting on your table or workbench, in contact with something else you were standing on or leaning against. How many modules had you reconnected in series at the point where you felt the shock?
    You might want to measure with a voltmeter between the terminal you were tightening at the time and the metal case. The case is supposed to be totally isolated. Any path that shows up may turn into a P3009 code when you put it all back together. Maybe there's a streak of some conductive gunk or carbon on one or more of the modules (maybe escaped from the one that went boom). Easier to find while it's on the bench....
    -Chap
    usnavystgc and robert mencl like this.
  12. racerx944
    LA, CA
    2002 Prius
    I
    The bus bar had to be bent a little and it was not much of a problem as I took a flat head screwdriver and tapped the bus bar (only 2 had to be done) to make the "step".
    As to the shock, the only think I can think of is that I had grease on one hand but not the other because I sanded all of the bus bars and greased them with normal grease to reduce future corrosion. I tied in all of the bus bars on one side and was half way through the other side before I felt this shock though it was more of a buzz feeling and relatively mild.
    A code 3006 kicked in for a little while during one of my drives but the car was going through what seems to be a re-balancing of cells. It went into limp mode for 10 minutes and afterwards it went away.
  13. racerx944
    LA, CA
    2002 Prius
    I
    An update after more than a year.
    I have replaced all the modules in the 2002 prius with gen 2. and working well.
    I also bought another 2002 prius with a bad battery pack. I bought a 3rd Prius (parts car) 2002 that was rolled over and took the 3 year old (Toyota dealer replacement battery) out to fix the 2nd Prius.
    It seems the gen 1 battery pack in the second car has different characteristics compared to the first Prius with the gen 2 modules. The gen 1 battery seems to run longer on battery and I have to step on the accelerator more before the ICE turns on.
    Another unrelated topic. I used a load tester for a 12v battery and tested the individual modules. It is not a very precise measurement but it will give you a good comparison of the strengths in different modules in the pack.
  14. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    Congrats Racerx944!
    I guess I was stupid lucky not to get shocked on my first removal, dis-assembly and re-assembly. What I learned for being shock on my 911 as a noob. is to remove Negative side first.
    So what I did was first wear my linesman heavy rubber clad gloves, locate and disconnected the negative cable connection where the ecu sat then the positive cable connector, ALWAYS taking care not to touch any metal surface will placing the socket on the 8MM socket nut and for extra measure I also disconnect the push on connectors where it looks like a white rectangular resistor. Then I move to the rear buses ( without the sensors ) and disconnected the negative side first then positive side cable.
    I felt good that I have pretty much made the battery less harmful but always kept in mind not to touch each side at one or side by side when buses are connected. Broke each nut open then used my hand power wrench with 8MM socket to remove 72 nuts.
    Installed in reverse order.
    I am not writing this is the proper method but it worked for me. I would be interested to know how you Vets have handled this step which is really not shared much.
    TIA,
    Jim
    P.S. I did not know you could mix G1 & G2 modules.
    #14 DRACO, Dec 25, 2015
  15. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Draco,
    There are reasons you shouldn't. The disparity in IR between them is noteworthy, and the difference in length is troublesome, though racer didn't seem to have a lot of problems with it.
    As far as breaking down a pack goes, I just start backing nuts off the non-sensor side from one end to the other. Then I carefully, and with 1 hand, remove the bus bar and strips in one shot. now you have 14 or 19 14.4V batteries. Nothing to be scared of.
    Steve
    DRACO likes this.
  16. DRACO
    DRACO Member
    362
    77
    2002 Prius
    Thanks Brother Steve,
    Yeah, even the ebay seller recommended highly against mixing the modules it. It is interesting how RacerX944 made it work for over a year now. I wish only the best RacerX944!
    Hmmm? Non-sensor is the positive side, right? I was always told to remove negative/ground side first then positive and on install positive then negative. Well, as long as nothing happened. No Harm No Foul.
    Good idea about the ONE HAND removal of the buses. But those damn terminals with the sealant/glue is a big PITA. I had to use my plastic door panel remover tool.
    I had a young AAA service guy come out last year and he installed a warrantied battery on the Lexus. He put the negative side on first then Positive, it resulted in a HUGE POP & SPARK and scared the poop out of him. I looked at him like Wth? He must have been new or did not know what he was doing or both, scary. Glad he did not cross connected it or AAA would have to buy me a new ECU.
    Jim
  17. DRACO
    DRACO Member
    362
    77
    2002 Prius
    Indeed Brother we both are still here so I think we are good to go
  18. racerx944
    LA, CA
    2002 Prius
    I
    The first gen 1 Prius I bought already had 18 gen 2 modules in the battery pack. The gen 1 modules were going out one at a time every few months so I replaced them one at a time with gen 2 modules. I had to take the battery pack apart 5 or 6 times to replace individual gen 1 modules that went bad. Eventually, I found a wrecked gen 2 Prius at pick your parts with an entire battery pack so I changed the rest and had a few leftovers. After the gen 2 module replacement, I had no more failures. This was a cheaper way to keep the car on the road and also I like trying different ways to make something work when possible. If anything blew up, I figure I could figure out how to fix it especially with all the expertise here.
    There is a moral to the story. If you don't want to take apart your battery pack several times, it is better to rebuild the whole pack with gen 2 modules especially if you have to pay for labor.
    After having to take apart the battery pack many times, I now unscrew all of the nuts on one side and remove the entire strip on one side first. This makes the entire battery pack into 38 7.2V modules that are not connected in any kind of series and renders it harmless.
    I did have to bend one copper strip connector as the gen 2 modules were a little bigger than the gen 1. Every time I had to replace a module, I simply will move the bent connector as I have all gen 2 on one side and gen 1 on the other side.
    I figured out a while back what was causing the 3006 cooling fan problem. When I bought the car, the battery pack did not have a top cover so the cooling fan for the battery pack had no effect. I eventually got a top cover and all is working well.
    I took that Prius off road for more than 30 minutes at Mammoth mountains and later at other places when I went camping and shooting at BLM lands. It is the only Prius I have seen taken off road. I did bang the oil pan a few times on rocks but nothing more than some scrapes. The car has about 35k miles more on it than when I made my first post. In many ways, I like my gen 1 more than my gen 2. With the 3 year old gen 1 modules, the car got 51.7 mpg average for the last tank of 352 miles. My gen 2 gets me around 46 driven in a similar manner.
    #18 racerx944, Dec 26, 2015
    DRACO and bwilson4web like this.
  19. ChapmanF
    17,352
    For the benefit of anyone drawn here by the thread title ("lacking power with high revs of engine after a few minutes of driving but restart fixes it"), it's worth mentioning that even a Prius with no code-worthy battery issues can occasionally do that, if the battery state of charge is low at the time you start it. It tries to keep SoC right around 60% at all times (as shown on an actual scantool, the MFD bargraph is rescaled and less useful), but it can happen that now and then your SoC is lower than that when you start the car (your last trip ended with an uphill, engine took extra long to start, etc.).
    If the state of charge is below 50%, the car will be noticeably more conservative about giving you battery assistance to accelerate. Once the SoC is around 40%, the car will not give battery assist at all, and will feel like a slug with a lawnmower engine. It will be running the engine harder than normal, partly to drive the car and partly to charge the battery. It will return to normal operation as soon as the charge state is back up where the car wants it. However, if you keep shutting it off to reset it, you can just be foiling its efforts to bring the charge back up.
    If you have an instrument like a ScanGauge II sitting on your dash to show you things like battery SoC in real time, you'll be able to clearly see what is happening at such times and it won't be a mystery.
    Naturally, you can see the same symptoms if there really is a serious issue with the battery (in which case you probably have battery trouble codes also that the scantool can show you), and if the battery needs to be fixed then it needs to be fixed. But in any case, any time the car thinks it needs to be diverting power to charge the battery, the best way you can react at the time is to let it do that.
    -Chap
  20. DRACO
    DRACO Member
    362
    77
    2002 Prius
    That would be the un-sensored ( rear facing side if battery was sitting in the car ) side correct?
