Question about EV mode and Charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by MRH, Sep 17, 2014.
  1. MRH
    MRH New Member
    San Diego CA
    Hello,
    I just bought a used 2012 PIP (this is my 3rd Prius- first PIP). The charging cable was missing from the car, the dealer has ordered one and will get it to me within the next few weeks.
    Unlike my 2010 regular Prius- when I push the EV/HV mode button on the PIP- to put the car into EV mode, it will not go into EV mode. The battery icon shows full. There is an error message that says something to the effect that EV mode is not available at this time.
    The question is- is EV mode only available when the battery has been charged via the charging cable, even though the battery is fully charged via regeneration?
    Thanks,
    Mike
  2. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    You have charge in order to shift into. EV mode. You shoud get a message that EV battery is not charged
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    MRH,
    Mostly true, unless you get on a long, long downhill run. Once you have a full charge from the wall outlet at home, or from a public /commercial unit, then regen will help to keep the battery charged, more generously than in your other Prius'. You will then have a number indicating an "estimated" EV Range, based on previous driving conditions. When that EV Range number is not in evidence, it is unavailable. That full charge you saw, along with the error message, will still get you up to a mile or so, depending on terrain traffic, and how light you can be on the throttle, just like on your 2010. Wonder how the dealer took the car in w/o the charging unit.:rolleyes: Somebody wasn't paying attention. Or maybe it was stolen, even an inside job.:cautious::cautious:
    Good luck.
    #3 rogerv, Sep 17, 2014
  4. bisco
    52,284
    looks like you're covered. congrats, and welcome to priuschat!(y)
  5. MRH
    MRH New Member
    San Diego CA
    Thanks to each of you for helping with this.
  6. rogerv
    1,639
    317
    You are welcome. Enjoy the car and the conversations here.:)
  7. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Also note that the "full" battery you're currently seeing on the screen has lines through it. That's when you're in HV mode. When you can use EV, the battery will have no lines through it.
    markabele likes this.
  8. vskid3
    vskid3 Active Member
    773
    228
    There is one HV battery in the PiP. The majority of it is allocated to the EV mode that lasts approximately 12 miles. After that, it simulates the HV battery in a regular Prius by using a small portion of the battery. The full battery you're seeing may be the "regular hybrid" portion and the "EV" portion is empty. There's a difference between the two displays, but I'm not sure what it is.
    perrysan likes this.
  9. MRH
    MRH New Member
    San Diego CA
    This makes sense - thanks.
    A brand new charging cable arrived today - and I am currently charging the car. Looking forward to seeing how the total system works when driven tomorrow!
    Mike
  10. bisco
    52,284
    all the best!(y)
  11. -Rozi-
    -Rozi- Member
    134
    60
    Slovenia, E.U.
    2014 Prius Plug-in
    When the battery is displayed with a smooth fill, it shows capacity to full.
    When the battery is displayed in small segments (bars) it shows the zoomed view of the last few remaining %.
    It's a nice and informative indication once you understand it. (y)
  12. CharlesH
    2,797
    1,164
    Roseville, CA
    "Portion" in this sense is not a physical part of the battery; it is just a portion of the charge. It is all in the hybrid control software. By pressing the EV/HV button when there is charge left, the software will go into hybrid mode to preserve that charge, but if the state of charge gets too low, then the system is forced into hybrid mode.
  13. rogerv
    1,639
    317
    Both of mine seem to have lines/level indicators.
  14. -Rozi-
    -Rozi- Member
    134
    60
    Slovenia, E.U.
    2014 Prius Plug-in
    I was reffering to this:
    FULL upload_2014-9-19_23-6-43.png EMPTY
    Your battery indicator does change to bars when battery is running out, does it?
  15. rogerv
    1,639
    317
    Right, but it still looks like segments to my tired old eyes, although they are more pronounced in the EV battery level indicator.
  16. -Rozi-
    -Rozi- Member
    134
    60
    Slovenia, E.U.
    2014 Prius Plug-in
    It's a low resolution display. Actually, your eyes are still sharp enough to notice pixels wich form the "solid" picture of a battery. (y)
    You outperform your PiP! ;)
  17. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    It's available at other times, but that kind of side-steps the purpose of being a plug-in hybrid.
    For starters, the behavior of "EV mode" is different for the plug-in than it is for the regular model. The plug offers both more power and more speed. It also allows you to engage it without the emission system already have been pre-warmed, but will consume gas for the sake of cleansing emissions once you have exceeded the power/speed threshold.
    Put simply, the system is designed to take advantage of plug-supplied electricity. You'll see that by watching the MPG display. At times, it will be sustained at the max, even though the engine is running. That's achieved by taking advantage of the battery-pack to allow the engine to run at a very low RPM, which in turn is very efficient. Those miles of travel won't be counted as "EV" though, since the engine wasn't stopped. They'll be counted as "HV" miles instead.
    Over time, you'll observe when it's best to allow the system to do that. The "HV/EV" button lets you disengage that electricity boost. For long drives on the highway, you'll find saving the battery-pack for later better overall. You'll also discover there are circumstances that will allow you to top-off the battery through brake-regenerating, like when exiting off the highway.
    It's quite a dynamic system, very smart with how it utilizes the electricity available by taking advantage of the engine at times.
    Here's a starter video for newbies... Watch the EV available go down, being used up entirely 14 miles into the drive.
    rogerv and Escaped like this.
