moving from prius gen3 to PIP. Regrets?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by wantaprius, Sep 20, 2014.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I rented one for a weekend before trading up.
  2. wantaprius
    wantaprius Junior Member
    66
    Oregon
    2014 Prius Plug-in
    It is a gen II. I was wrong. My friends think it isn't worth the different in price but I really do like to support new technology in the energy department. It looks to me that if I get a new Prius 3 it would be a lot less but you can't get 0% interest on it and you don't get the 2500.00 energy tax credit.
  3. bisco
    51,895
    that sounds right, and you get a few things that aren't on the 3 like heated seats. i bought mine for the same reason. all the best with your decision!(y)
    wantaprius likes this.
  4. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    My commute is 4 miles each way and the engine does not kick in. It is also great for your long trip every few weeks. Because of the larger battery, you will not get into the mode of needing to dump electrical charge which means a bit better MPG than a standard Prius. When I took it easy and stuck in the right lane at 60 MPH, I got a bit better than 60 MPG.
  5. wantaprius
    66
    Oregon
    2014 Prius Plug-in
    I live on the coast and have to go into the valley to test drive but I will try to find a hill of equal valley. Has anyone wanted to go back to the reg Prius from the PIP
  6. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Climbing up the hill out of the valley where I live doesn't start up the engine. Of course, even if it did, there isn't an "everything is lost" penalty anyway. The system takes advantage of having plug-supplied electricity available. Watch what happens when a cold start happens.
    Here's an example of my commute to work, with a number of stops, driving 14.1 miles in EV before depleting the battery-pack:
    This video is my commute back home, taking a slightly different way which includes a steep hill climb, resulting in a 12.4 mile EV drive before depletion:
  7. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    John, I've watched some of the videos you've posted on your drive, both in the summer and winter.
    Was curious what the winter time does to your ev range, and how drastically it reduces it. Also, can you switch from ev to hybrid mode, say when you want to save the battery while driving on the freeway, and then turn on ev when taking slower streets? Or does the PiP do that automatically, and forces you to use the battery up first before then switching on hybrid mode?
  8. bisco
    51,895
    both of those questions are covered extensively in threads here and the faq sticky. briefly, winter reduces range on a sliding scale of temperature to a max of about 25%. and you can freely switch from ev to hv to ev anytime you want to until you're above 62 mph at which point it stays in hv until you slow down, then you're free to switch back and forth again. also, the car starts in ev, so you get to use all ev when you want without warming the ice.
  9. john1701a
    12,817
    5,303
    58
    As stated already, you may use EV whenever you want.
    The catch with winter is that sub-freezing temperatures increase electrical resistance in the battery-pack. That means the same KWH of electricity won't take you as far.
    In these 2 videos, you can see that my EV distance is reduced to 9 miles in the extreme cold (that's 0°F, well below freezing). It's quite a reduction compared to the 14 miles in the summer. But under normal circumstances, you'd turn on the heater to keep yourself warm... which in turn warms up the battery-pack too.
    The purpose for having filmed the videos was to prove that certain individuals were spreading false information about Prius PHV, claiming what I was routinely witnessing during my commutes here in Minnesota was impossible.
    #29 john1701a, Sep 21, 2014
    Ashlem and usbseawolf2000 like this.
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    To the OP, in your situation, the PiP is a win/win. 'Nuff said. ;)
    CaliforniaBear likes this.
  11. Bill Norton
    Bill Norton Senior Member
    2,146
    734
    MONW, Ks.
    But if you accidentally step down too far and the ICE comes on for less than a minute once or twice on your short commute,
    wouldn't that be rough duty for the ICE? It would never warm up and burn off moisture from the combustion chambers to the tail pipe.
    There is a car that will seat 4, be a comfortable EV for all 4 seasons and is rated 40 mpg for those road trips.
    What is your road trip vs. daily commuting ratio in miles?
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I also went from Gen2 to PiP.
    PiP has a better ride. You will notice during the test drive. Gas mileage is better too.
    EV efficiency is also unmatched due to the usage synergy with gas. You'll only use it at lower speed.
    Here is my first year data.
    My PiP - After One Year (Stats) | PriusChat
  13. john1701a
    12,817
    5,303
    58
    That less than a minute is all it takes for the engine to reach warm-up anyway. Also, keep in mind that there is less to burn off in the first place, since the starting process is graceful due to the boost from the big battery-pack.
    It's not good to old-school use terms like "rough duty" on an advanced system like that in Prius either. Think about how dramatically different it is. Just the oil alone is a huge improvement. That 0W-20 is great for reducing load.
  14. wantaprius
    66
    Oregon
    2014 Prius Plug-in
    Boy that was nice to watch. Although it did tell me I have a lot to learn. Is there a FAQ on the bottom screen. I don't see in in the FAQ thread. Like what SOC, MG1,MG2 etc mean. I am intrigued by it all.
    Also the last poster has a good question. Any thoughts?
  15. wantaprius
    66
    Oregon
    2014 Prius Plug-in
  16. wantaprius
    66
    Oregon
    2014 Prius Plug-in
    I like this comment a lot!!!!
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Bill it was discussed before you joined Priuschat.
    Prius Plug-in Versus Volt: Which Costs Less to Drive? | Page 5 | PriusChat
    Invest $24 in the SAE article. It has a lot of interesting information about what went into engineering of PiP.
    markabele likes this.
  18. vskid3
    vskid3 Active Member
    773
    228
    If you want to support the new technology, get the PiP. If you want to save money, you may be better off sticking with your current Prius.
    Is your commute 2 miles one way or 2 miles round trip? Either way, I'm sure your commute MPGs are pretty terrible, but you could still buy a lot of gas for the same price as upgrading. What is your total mileage per year? Ever consider a bicycle for your commute?
  19. bisco
    51,895
    what was the question of the last poster? i have a 15 mile r/t commute that i make in all ev 52 weeks a year. the ic e never comes on, i don't use the heat and when the ice does come on in any situation, it goes through the full warm up process and is not detrimental in any way. it's toyota engineering. who makes a more reliable car? that's good enough for me.(y)
  20. Mendel Leisk
    41,400
    Just a quibble: I'd think any third gen Prius would have similar ride feel.
