Cut in the tread
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Oct 4, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Just noticed this. No leak. OEM Toyo Proxes A20 with 42K. Good for another 8K before I replace them with Ecopias? uploadfromtaptalk1412462363142.jpg
  2. working1
    working1 Active Member
    121
    112
    What to call it? Weather Checking, Weather Cracking or Ozone Cracking. Time for new tires.
  3. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    Your call, but since you asked...I'd start price shopping.
  4. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    They might be okay for local travel, but I sure wouldn't go out on the new 85 mph highway there. Personally, I'd replace them, a possible accident simply isn't worth trying to squeeze another 8k miles out of them.
  5. Okinawa
    Okinawa Senior Member
    1,333
    320
    I would replace them now.
  6. Emcguy
    Emcguy Member
    177
    29
    Australia
    The crack looks harmless, i doubt it travels anywhere near the depth of the belts. The tread height however is getting quite low. I'd swap them out if you drive on windey roads or wet season is approaching.
  7. lester williams
    227
    68
    mississippi
    Another vote for time to replace. Worn tread has long stopping distances, and are dangerous for wet roads. Those 4 little contact patches of the tires are the only thing connecting you to the ground--- make sure they are good....
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I will start shopping and ordering the Ecopias. No one stock them locally for some reason.
    PS. W-rated LRR is, well silly.:)
    #8 Jonny Zero, Oct 5, 2014
  9. Paul Schenck
    Paul Schenck Active Member
    524
    306
    Fresno, California
    Is say you hit a piece of retread on a freway
    iPhone ?
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I seldom run on the highway. My best guess is I ran over a broken beer bottle. See that a lot around here. Much more devastating to my 22mm road bike tires.
