SD card issue
Discussion in 'Prius c Audio and Electronics' started by Adnan Bashir, Oct 8, 2014.
  1. Adnan Bashir
    Adnan Bashir New Member
    pakistan
    i bought prius c but audio unit is without SD card.it keeps saying "program loading is necessary please insert SD card" i tried to get the "program" from local market of pakistan, but failed to do so, my prius c is imported from Australia.its audio unit model is 32203 made(fujitsu 10). i m reading prius c forums but again failed to read any related thing.from where can i get "program containing SD card" in Pakistan.can anyone help???
    52,291
    welcome to priuschat! just a thought, you might try disconnecting the 12 volt negative cable for a minute to reset the computer. just a guess, all the best!(y)
  3. Adnan Bashir
    pakistan
    thanks bisco.i think it wouldnt work.by disconnecting the terminal it ll reset computer and computer ll ask for "program" again
  4. bisco
    52,291
    i guess you're right. hopefully, someone with more knowledge will jump in.
  5. Adnan Bashir
    pakistan
    hope so...! i think "program containing SD card" is the only solution..but dont know how and from where to get???
  6. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Does your :AUDIO" has GPS built in and is this an OEM unit?
    Some of the HU uses SD card for GPS program start and do not use DVD.
  7. Adnan Bashir
    pakistan
    yes, it has built in GPS and it is an OEM unit as it is made by fujitsu 10.my unit isn't running anything(back view, radio, audio/video)
  8. Adnan Bashir
    pakistan
  9. bedrock8x
    1,483
    137
  10. Adnan Bashir
    pakistan
    i want SD card 'only'.if this card includes only maps then why other applications(back view, radio, video) are not working??
  11. Abbas M
    Abbas M New Member
    Islamabad
    2012 Aqua
    I got my Aqua 2012 imported from Japan. Every thing work good except the Audio system, Rear Camera and the navigation system. It is Panasonic Model CN-S300WD and the SD Card is missing. There are people around who are in business of programming these systems in cars and they own dozens of SD Cards for different models but so far I have not been successful to find any one who has the right SD Card for my car. I have also checked the Toyota website and they don't offer this software. I need help please.
