2004 prius won't accelerate
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Maria Navarro, Oct 7, 2014.
  1. Maria Navarro
    Maria Navarro New Member
    san mateo ca
    I'm having the same problem. Just got a 2004 prius. The previous owner said i need to replace the battery. My uncle bought a "refurbished" battery that has a warranty for 3 years for 3k. The mileage i guess is over 200k. Whenever i turn it on maintanence reqd is lit on (the other signs too). We had it oil changed and the filter too. There are times when i try to accelerate it and it wont just go higher. It scares me on the freeway (sometimes i only run 40mph). I try to release the gas then step on it again harder. It would work at times. But sometimes it will really take awhile to go higher. When i try to accelerate on steep road i always get stuck on 10 mph. Its just really hard. Then there are times the the car starts jerking when i brake. Pls help! Thanks
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    Just curious how much you paid for this thing?
    Instead of guessing at the problem, maybe you can get the diagnostic codes read? That way you can pinpoint what is wrong with the car.....without guessing.
  3. vskid3
    vskid3 Active Member
    773
    228
    The maintenance light comes on every 5000 miles. You have to manually reset it, it doesn't sense that the oil has been changed. You can find the instructions on this site.
    So was the battery dead when you bought the car? Sounds like these issues should have come up in a test drive, if it was possible to test drive. You are flooring the gas pedal, correct? Some people don't because they're trying to get good gas mileage and then they complain that it has no power.
  4. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    One possibility is that your inverter cooling system is not functioning. Put your Prius in Ready mode (in park) and take a look at the inverter coolant reservoir. There should be turbulence, if not you need to either get some air bubbles out of the system or have the inverter coolant pump replaced. Your Prius will go into a safe operating mode when things overheat to prevent expensive damage.
    JeffD
  5. Maria Navarro
    san mateo ca
    Thanks for the information! My uncle got it from her niece. He didn't pay for it. He just replaced the battery which caused us 3k.
    How can i find the diagnostic code?
    I will try to manually reset it today. Yes i am flooring the gas pedal hence still no acceleration on my speed. It scares me alot!
    This is what shows on my dashboard when i start the engine
    #5 Maria Navarro, Oct 7, 2014
  6. bisco
    52,386
    you can get the codes read at a dealer or auto zone.
  7. Maria Navarro
    san mateo ca
    Thank you bisco. I will let you know once i have it
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    It sounds like you did.
    However, the picture you show above, the Ignition is on. Since you are new and unfamiliar w/ a Prius Ignition system, here it is simplified like a traditional car.
    Foot OFF Brake, press Power Button once = Accessory (radio can be turned on)
    Foot OFF brake, press Power Button again = Ignition (this is what you did for the picture above; power windows can be open/closed)
    Depress Brake, press Power Button again = car is Started (The car is now started and ready to be driven. "READY," will be illuminated on the Dash. You can start the car right away by depressing brake then press Power Button.)​
    Read the owners manual to become more familiar w/ the car. If you don't have it, download it from Toyota. LINK
    I would encourage you to just goto Luscious Garage (SF) or Art's Automotive (Berkeley), to have them take a look at the car, and tell you what is currently wrong, and what other maintenance items need to be done. Both shops have EXCELLENT reputations.
  9. Maria Navarro
    san mateo ca
    Hi all I got this codes, P0A80, P3019, P3019. Does anyone know what these means? Thank you.
  10. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    P0A80 points to the HV battery, sorry.
    JeffD
  11. bisco
    52,386
    the good news is, you have a 3 year warranty, but more work for uncle.
  12. Maria Navarro
    san mateo ca
    Hi jeffd, do we need to replace the battery? Thanks for helping
    Oh oh.. thanks for your help
  13. posey1981
    posey1981 New Member
    Oklahoma
  14. posey1981
    Oklahoma
    My car wont accelerate after I let it idol for 10 mints
  15. bisco
    52,386
    sounds like you might have a problem...
    after giving it serious though, i think your throttle cable has become disconnected from the carburetor.
    PriusGuy32 and usnavystgc like this.
  16. Cocooningweb
    Cocooningweb Junior Member
    22
    Hello,
    I'm having a similar problem with a 2005 Prius - 257,000 miles. Acceleration is getting really painfully slow. I've owned a Prius since 2006 and it's never been like that.
    I got a PA080 code about a month ago, changed the traction battery and not too long after I started getting code C1242. C1242 is related to the ABS system, but from reading a post on the 1st Generation Prius (Gen1 Prius C1242 fix - Inverter coolant pump and AM2 fuse | PriusChat), the inverter coolant pump may be responsible for the problem as suggested by Jdenenberg above. It could also affect the acceleration from what I read somewhere else (I can't remember where I read that, I've been reading non-stop all weekend).
    A friend of mine suggested the throttle cable or accelerator sensor, he wasn't really sure what it was called.
    I'm not sure what to try next. Inverter coolant pump?
    Sorry OP, I don't mean to hijack your post, but our problems are too similar to create a second post, hopefully we'll both get a solution out of this!
    Thank you.
  17. bisco
    52,386
    all you need to do to check the pump is see if the liquid is swirling and pump is making an aerator noise like an aquarium. if it is, your gonna need to download toyota tech manual and follow troubleshooting tree. are you using mini vci?
  18. Cocooningweb
    22
    I checked my coolant reservoir at lunch and it's not bubbling, but the liquid is definitely flowing and moving. I don't have a Mini VCI, I'll order one off eBay tonight. Hopefully that'll give me a better idea of what else I should be looking into. Thanks.
    valde3 and bisco like this.
  19. posey1981
    Oklahoma
    I need help on 07 Toyota prius .after i let my car set and idle for 10 too 15 mints it wont accelerate. .this don't happen all the time
  20. bisco
    52,386
    don't let it idle.
