Where is the flasher relay?
Discussion in 'Prius v Accessories and Modifications' started by Vishnu, Oct 11, 2014.
  1. Vishnu
    Vishnu Junior Member
    2012 Prius Alpha
    I replaced the bulb in the turn signals to LEDs. They began hyperblinking. And I can not find the flasher relay. Under the dashboard to the right (as in ZVW30), I did not find it.
    At what point is the flasher relay in the Prius V?
    ozjimjam likes this.
  2. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Take a peek at this >>thread<<, post #11. It's for a Gen III, but I imagine the location in a V would be close to the same.
  3. Vishnu
    2012 Prius Alpha
    Thank you. But in that place there is no flasher. I already wrote about it.
    Instead of flasher using chip BTS 5240 L. It is installed in the speedometr.
    How to fix hyperblinking in this case?
  4. sfprankster
    444
    490
    Have you tried to place a resistor(3 ohm/4 bulbs or 6 ohm/2 LED's) in series with the LED's?
  5. Vishnu
    2012 Prius Alpha
    Resistor to each bulb - it's very simple solution. :) Is as simple as a return of regular light bulbs into place. (n)
    In series? I thought that resistor must be connected in parallel with the LED's. In this case.
  6. sfprankster
    444
    490
    It is in parallel, across the bulb leads, to simulate the resistance of the original halogen bulb.
    Been a long time since using basic electronics terminology. (n)
  7. Vishnu
    2012 Prius Alpha
  8. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Those resistors even with the built-in heat sink can get VERY hot, so be careful where you mount them!
    I learnt the lesson by touching it (just to see how hot it was) after the flasher was on for only a minutes.
  9. ozjimjam
    ozjimjam Junior Member
    35
    17
    22
    australia
    2016 Prius v wagon
    Thanks for the info. Looks like I bought the relay for nothing now
  10. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
    i found some info on a forum from China, apparently that car is also using the same BTS5240 chip, and the owner successfully solve the problem. Too complicated for me : ( guess you need to have some soldering skills and electric knowledge to do the job. and it wont allow me to post link here either
  11. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Indeed - there is no flasher relay in the Prius V... I also bought the flasher relay and begged the dealer to changed it for me (I was willing to pay). After watching the GenIII Prius flasher relay tutorial on YouTube, I didn't want to break any bones twisting my body in such a tight space! Their head IT tech guy came back and said there is no such flasher relay on my Prius V 2015.
    I don't feel confident enough to start splicing wires with resistors. Last time I used resistors for HID's on my old SUV, the resistors heated so much they had completely melted the plastic housing where they were attached.
  12. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
    yeh, true , resistor defeats the purpose of power saving , it is also a potential fire hazard.
    ricomtl likes this.
  13. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    There must be another solution? I read there are supposed to be LED bulbs with built-in resitors, but not sure if that really works!
  14. Air_Boss
    Air_Boss Senior Member
    4,187
    1,177
    New Yawk
    Using V-LEDS all around and it doesn't hyperflash badly. Quicker, yes, but not crazy fast.
  15. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Are those like $50/bulb or something like that?!
  16. Air_Boss
    4,187
    1,177
    New Yawk
    Yes, and entirely worth it. They blaze. You cannot be missed using those lamps.
  17. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
    Thanks for the info, is there a particular brand for the v-led bulbs?
  18. Air_Boss
    4,187
    1,177
    New Yawk
    The model V3 Triton is what I use. On sale, they are approximately $50 each.
    ricomtl and ozjimjam like this.
  19. Kepik
    Kepik Member
    61
    37
    Bay Area, CA
    2013 Prius v wagon
    Do you happen to know how often they go on sale? Think you could record a vid of how fast they blink w/o a resistor? The VLED's resistors do however look super legit compared to the gold generic eBay types.
    Tried using JDM Astar's Extremely Bright 50W Red LED bulb and the base connector is too thick to connect with the turn signal socket.
  20. AlexSmall
    AlexSmall Junior Member
    Krakow
    2013 Prius+ MPV
    Hey!
    I have fixed integrated into Prius+(PriusV) flasher.
    By replacing 2.2k resistors to 10k.
    Here is more details and pictures (it is in russian :) ) I can't post link :(
