Rebuilt battery issues
Discussion in 'Gen 2 Prius Technical Discussion' started by briansterling, Oct 12, 2014.
  1. briansterling
    briansterling Junior Member
    47
    I bought a 2005 prius which the owner said had a bad HV battery. I rebuilt the battery with the proper modules and it's all balanced just right. It turned on just fine and can drive but after test driving a few miles some warning lights came on and then the HV system cut off leaving just the gas engine which isn't that powerful. After pulling over and turning the car off and back on it works fine for about the same amount of time until shutting
    Codes were:
    P3024 - Battery Block 14 Becomes Weak
    C1392 - Un-Correction of a zero point of the stroke sensor
    C1345 - Not Learning Linear Valve offset abnormality
    C1310 - Malfunction in HV system
    C1259 - Malfunction in regenerative of HV ECU
    C1203 - control system communication circuit malfunction
    Right now the auxillary battery is kaput so I have a regular 12V car battery running aux and is working fine but I wanted to give all the info I can. I also don't have the cover, seats, and vents reinstalled over the battery for the reasons of access. There are no sensors (besides temp) for knowing the battery isn't covered so I don't think that's an issue.
    The only thing I can think of that's wrong is that the ECU has gone bad since it's an odd collection of codes. Any thoughts on this?
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    You should be very careful with what you're doing, that hv battery is high voltage, touching anything on the open case can cause serious injury.
    I would first go out and get the proper 12v battery and start from there. It also seems like the modules were not completely balanced and still contains a weak block, #14.
  3. briansterling
    47
    Thanks JC91006. I've rebuilt several of these batteries before so I know the danger in a HV system, but I appreciate the warning anyway. I just measured all the modules and they read from 8.01 to 8.12 volts which I thought was pretty darn good.
    The 12v battery I'm using is the same voltage and AH as the old battery so it shouldn't really matter. The only reason I won't use it permanently is because it won't fit in the battery bay.
    Since the codes think there is a weak battery block (and there isn't) do you think that would be the onboard computer or the ECU?
  4. JC91006
    16,827
    8,600
    But what's the voltage under load?
  5. briansterling
    47
    Took a spin with a HV multimeter hooked up the pack outputs (not relays) and total voltage never drops below 200V. I don't think it's the voltage at rest or under load but how the car is reading it. I think an issue is happens when it tries to charge recharge through braking or engine.
  6. bisco
    52,393
    maybe the battery ecu?
  7. Patrick Wong
    18,210
    6,513
    The traction battery ECU continuously monitors voltage of each of the 14 module pairs and keeps track of the module pairs with the high and low voltage readings (which continually changes). If the voltage difference is more than 0.3V then the traction battery ECU will log a fault code.
    As previously suggested, you need to look at the two modules which make up the last module pair because one or both has a problem.
  8. briansterling
    47
    I'll measure again but all the module pairs seem to be well within the 0.3V variance. I'll let it rest overnight and test again after some "settling". If the modules are fine but the code persists do you think it would be the main ECU (under glove box) or the traction battery ECU?
  9. Patrick Wong
    18,210
    6,513
    There is a big difference between measuring battery voltage when the car is IG-OFF and the modules are just sitting there, doing nothing - vs. measuring battery voltage when the drivetrain is under load and the modules are delivering 70A or 80A instantaneous current flow to the inverter.
    Another possibility to consider is that the voltage sense wire connected to module pair 14 is having a problem which is causing the traction battery ECU to think that the voltage is lower than it should be.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Brian,
    As one example, the Android app 'Torque' will let you monitor and log voltages by module while you are driving. Hopefully that will make it obvious which module(s) or pairs you have to sort out. The battery ECU diagnostics are pretty swift, so expect it to be the 14th pair at a minimum.
    I wonder if this is a case of modules 'balanced' to voltage but not capacity.
    Question: are you rebuilding for resale or personal use ?
  11. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The best option is buying a miniVCI from Ebay. It uses a diagnostics program called Techstream that is used by Toyota technicians.
  12. briansterling
    47
    Wow. A lot of great suggestions and information.
    Wong - Thats a very valid point that pair 14 may not have a valid connection. There was a fair amount of corrosion and I may have not cleaned the terminals as well as I thought. I shall revisit this.
    Sagebrush - The modules were charging/discharging at the same basic rate but I'll recheck after they've sat all night to measure the resting voltage. And I am building for resale. I've rebuilt a few of these for a local garage and have had good luck so far.
    lopez - I will look into this miniVCI right away. Seems like a useful item to have.
    I'm planning on driving it to the dealership Tuesday
  13. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    X2
    You need to monitor the module pairs to watch voltage drop under load (usually the cause of weak block codes) and the mini VCI setup is the same system the dealers use. Once you can verify the situation while driving, you should open up the battery again, locate the pair of modules causing the code, then check both the modules (load capacity/test) and the sensing terminal for damage (broken wire, corrosion, etc).
  14. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Brian,
    Did you load test the modules as part of the re-balancing? A 55w headlamp (high and low beams in parallel) for a minute and measure the voltage drop under load is a good test. Discard any module that differs from the others by more than 0.1 v. Listen to MTL_hihy as he did a good job in his rebuild.
    JeffD
  15. MTL_hihy
    536
    261
    Maritimes, Canada
    #15 MTL_hihy, Oct 14, 2014
  16. goitalone
    goitalone Member
    190
    Port St. John, Florida
    Is it ok to use brand new cells with old ones?
  17. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Where are you getting "new" modules? They are generally unavailable except by buying a replacement HV battery from Toyota. As to your question - Do not mix modules from different generations when doing a rebuild. Your 2004 Prius has early Gen2 modules. Later ones from a Gen2 (about 2009) are an improved type and the Gen3 ones may be further improved. It will be difficult to get a matched set (Capacity and effective series resistance) using a mixed set.
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    Lets say the same generation of new and used, wouldn't the new modules almost by definition have different capacity than the old modules ?
  19. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is no way to get new modules, except a full set of Gen3 modules as a new battery from Toyota. If you are assembling a set of modules you have to test each one to determine that there is a good match across the set.
    JeffD
  20. mattd2472
    mattd2472 Junior Member
    PA
    im going to guess the "pack 6" needs some attention and maybe replace both cells with the spare 06 hybrid battery i have ... i was using torque ... anyone have any input ... those reading were for driving from PA to Giants stadium up hill and down and on flat roads ...
