New hybrid battery
Discussion in 'Gen 2 Prius Technical Discussion' started by ruidboi, Sep 1, 2014.
  1. ruidboi
    ruidboi Junior Member
    45
    Nassau, New Providence
    OK I took out the hv battery and opened it up. The only thing I noticed that was seriously out of whack was the aluminum shield wire nut was not tightened at all. I don't think that can cause the error code. Can it? Now I did not use a torque wrench to tighten the main battery cables and the service plug cables because the two torque wrenches I bought torques were too big for that job and I was getting impatient. I am getting the correct one today and I will retighten the main battery cables and service cables. Now is the sixth battery module the sixth module from the ECU Side or is it the sixth module from the other side? I don't know how the battery modules are numbered.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Eddy,
    Yes, I have that many Gen 2 modules.
    But I would not recommend just dropping a few Gen2 batteries into a Gen1.
    Over time they will not play nice together.
  3. ruidboi
    45
    The worst thing happened while I was working on the battery. I removed the two nuts from the two main battery cables. I tested 2 sense wires from what I thought was the sixth battery module and they all came back fine with perfect continuity. So I decided to loosen and torque all of the nuts that are connected to the sense wire to 48 inlb. I was tightening a nut when suddenly a HUGE SPARK came from the battery. It really spooked me out. The long main battery cable looks completely fried and the nut I was tightening has a slight burn mark on it. My torque wrench even looks burnt. I thought once the service plug was out the battery was safe to work on. I tested the module that I was tightening when the big spark occured for voltage and it came back a normal voltage similar to the other modules. What do you think happened? Is my new HV battery still even good? How can safely continue work on it? What should I do I spent $3300 on this battery I really need this to work
  4. JC91006
    JC91006 Senior Member
    16,800
    8,589
    This shouldn't be happening with a brand new battery. Something is not right here. Are the serial numbers on the battery all in sequential order??
    You have to be very careful working on this thing with the case open. You should be wearing the proper protective electrical gloves too. Your pictured gloves looks to be made of regular fabric??
  5. Patrick Wong
    18,210
    6,511
    You thought wrong.
    When the service plug is removed then the series circuit is broken. However substantial voltage still exists, more than 100V on one leg (since the 2G service plug does not split the modules into two even groups.). As long as the busbars connect the modules, you can get zapped.
    My guess is that the busbars came from the original battery. Maybe one of the sense wires was damaged and caused a short circuit.
    You need to think about how the spark occurred. Was the wrench in contact with the sheet metal enclosure? If not, was it in contact with a sense wire from one module while you were wrenching on another module?
    Any damaged wiring must be replaced. You cannot safely operate the car with damaged insulation on the high voltage cables.
    #45 Patrick Wong, Oct 16, 2014
  6. ruidboi
    45
    The busbars did not come from the original battery the new battery had them already attached. I did however transferred the 2 main battery cables from the old battery to the new battery. I don't recall the wrench hitting any metal, but its hard to argue with the evidence. The burn mark on the wrench handle may have been where the wrench touched some metal on the battery. What I do know for certain is the huge spark came from the very end of the battery probably where the main battery cable connects to the negative terminal. The main battery cable is severely burnt so I know for certain I need a new one. And I need prober gloves. What kind of gloves do you recommend?
    Th
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Phew. You dodged a bullet, Ruidboi.
  8. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    You aren't kidding - he nearly got himself killed.
    OP - please stop and take this to the nearest dealer. Your life is not worth saving a few dollars.
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    Not wearing proper gloves is ridiculous.
    Rubber soled shoes seems like a no-brainer, as does working on a wood bench.
    Beyond that, I HOPE that anyone playing around with the traction battery has a clear understanding of the electric schematic, AND has taken a multimeter and checked multiple points of possible short-circuiting for active voltage. If Pat Wong's statement of 100V present until the modules are disconnected from each other is not 100% clear then I whole-heartedly suggest someone else do the work.
  10. CARspec
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    This hits on a point I fear expressing for the sake of community backlash, being this site (with all the info on rebuilding batteries and DIYers) gives people a false sense of security when it comes to working on HV. I do it for a living on these cars, was trained by Toyota, and I still get nervous when I crack open a battery (and I've done many). I'm glad people are pushing the limits on these cars but it should come with a disclaimer each time.
    Robert Holt, JC91006 and usnavystgc like this.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Ruidboi,
    What did you buy for $3300 that leads you to open the pack ?
  12. JC91006
    16,800
    8,589
    read post #33. I really wonder if what he purchased on ebay was indeed a new unit.
  13. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    No one should be apologizing for stating concerns over safety and like anything many people may be totally unaware of how close they come to a truly dangerous or potentially lethal situation. That being said people need to remember this person lives in Nassau Bahamas (not many choices for Toyota dealers and who knows how competent they are on a hybrid car either). So I would suggest that the batteries are likely fine (they can handle huge current in/out flows) but clearly the wiring (and your torque wrench) took the brunt of the issue and will need to be replaced or may have other issues (should be able to get used wiring from ebay). Ideally you should be looking at getting an RC charger then load test and capacity test the modules all again just to be sure everything is fine (may be a bit much to ask given your location and shipping costs). Anytime you start connecting all the batteries back together in series again you need to be very careful what you touch and I do suggest you familiarize yourself with a multimeter too (esp DC voltage readings, anything over 50V should have rubber insulated gloves as a precaution)
    #53 MTL_hihy, Oct 16, 2014
  14. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Pictures look like the torque wrench body contacted the bar connector point.
    usnavystgc likes this.
  15. MTL_hihy
    536
    261
    Maritimes, Canada
    Agreed, seems pretty clear the torque wrench hit the connector and the dead short had him welding (ie big spark) in no time flat.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    Are wrenches made with rubberized handles ?
    Here are examples of insulated torque wrenches.
    Search Results - KC Tool
    It would be nice to find a used, less expensive tool
    #56 SageBrush, Oct 16, 2014
  17. Mendel Leisk
    41,747
    Use an extension on the torque wrench, so the handle's well away from battery?
    SageBrush likes this.
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    Very good idea. I'm going to put rubber sleeves on all the tools I use before I dig into a battery.
  19. GregP507
    GregP507 Senior Member
    3,002
    481
    I wouldn't throw out the old battery just yet. You might make your money back by selling the cells individually to people who would rather replace cells than replace the whole battery.
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    Now I follow... Ruidboi had bought a replacement battery but needed to swap the ECU and harness/electronics to the new battery.
    Since this is what I plan to eventually do too, I'm real interested in not repeating any mistakes LOL
    This link
    Hybrid Battery Junction Block Assembly
    is at least a starting point for this job.
    Question:
    Can the ~ 200v battery be isolated from the parts that have to be removed, or does the battery have to split into electrically isolated modules by disconnecting the busbar(s) ?
