How many water pumps in 2005 Prius.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vk60564, Oct 24, 2014.
  1. vk60564
    vk60564 New Member
    naperville, IL
    I have a 2005 Prius with 67K miles on it.
    In 2011, the dealer changed (free of cost) a pump called: HV Electric Water Pump
    Two months ago, I was told that another pump needs to be replaced: Engine Water Pump Assembly. Cost me $500.
    Today, I am hearing noise behind the driver dashboard (sounds like woo-woo....woo-woo... Sounds like a piston noise. It comes on at startup and when I shut the car down. It is not consistent. I was told that this is: Coolant Heat Storage Water Pump and will cost me $475 to replace.
    Question: Am I being taken by the dealer? Are there any other water pumps left to replace? The cost of these pumps is in the ~ $125 neighborhood on line, so what I was charged for Engine Water Pump Assembly appears very high and now the same story for CHSWP.
    Any feedback welcome.
    Thanks
    Vik
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Yes, of course they are kindly offering you another walletdectomy.
    To my knowledge, the coolant heat storage pump doesn't sound like "woo- woo, woo-woo". It's more of a continuous screech.
    It would be helpful if you could record the noise and upload it for us. Someone might be able to tell you what you're hearing.
    kenoarto likes this.
  3. vk60564
    vk60564 New Member
    naperville, IL
    Its not a screech. I will record it and post. Thanks for the suggestion.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    More likely a wallestomy. You keep your wallet, but now it has a hole for continuous drainage ;)
    #4 SageBrush, Oct 24, 2014
    dolj and jadziasman like this.
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Gen 2 North American Prius does have 4 water pumps.
    -Inverter water pump you listed it as HV Electric Water Pump (it runs always when Prius is powered on to cool all hv-electric parts except the battery)
    -Engine Water Pump belt driven pump (runs when engine is running to cool it and to heat up interior)
    -Coolant Heat Storage Water Pump it pumps coolant in and out of heat storage tank (normally runs at startup and shutdown)
    -Heater water pump it pumps hot coolant to heat interior if engine isn’t running but is warm and heater is used (runs if engine isn’t running but is warm and heater is used)
  6. jadziasman
    1,355
    488
    District 6
    From the service manual:
    The heater water pump sends engine coolant to the heater core while the engine is stopped to prevent heater effectiveness from becoming low. Directed by the air conditioning amplifier, hybrid control ECU operates the water pump relay and drives the heater water pump.
  7. JC91006
    JC91006 Senior Member
    16,800
    8,589
    My pump makes a tea kettle woo woo woo sound too. Normally when i shut down. I've been ignoring it and now oblivious to the sound.
  8. Patrick Wong
    18,210
    6,511
    Yes, what you paid to replace the engine coolant pump is high. That is normal business practice for a dealer service department.
    Regarding the coolant heat recovery system pump, as long as it is working (which it is, if you don't see the check engine light appear) then don't worry about it - unless you are the kind of person who is OK with spending $475 to deal with a minor noise that has no impact on functionality and only appears for a few seconds.
    BTW, if you are counting all pumps that move a water-like liquid, don't forget the windshield washer fluid pump and the back hatch fluid pump...
    okcwxguy likes this.
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I haven't done the Coolant Heat Storage Water Pump, so I don't know how difficult it is, but the engine water pump is very easy. its a diy if you have any mechanical skills at all. and a 10mm socket...
    bleeding the coolant system does take some time because air gets trapped in the system. but it'll save you about $400 bucks.
  10. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    Today, I got P2601 code for my 2008 Prius. Per my internet research, it seems related to the CHSR system pump. But as I searched entire internet, using the key words of "Prius CHSR pump", all results came with the inverter coolant pump, which is HV electric (12V) water pump. Does 2008 prius really have 4 pumps? May someone point me some direction where to find the CHSR system pump? Thanks.
  11. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You can try CHRS instead, for coolant heat recovery system. If you're having problems finding something on it, it may be because it's a rare repair.
  12. 08PriusXSJ
    42
    Connecticut
    Thanks. I found the information that there are four pumps. The reason that I got confused was that I thought the CHRS pump was in the inverter coolant loop because the CHRS tank is located just below the inverter coolant expansion tank. But this pump is actually hooked up with the engine coolant loop.
  13. 08PriusXSJ
    42
    Connecticut
    Update: Following some posts here, I tested the voltage from the terminals after pulling out the CHRS pump relay. No voltage was detected. Then I checked all the fuses in the fuse box and all of them were good. Measured the voltage again, still no value. So I gave up after I erased the code using a scanner. Since then, I have driving the car for about 250 miles without any difference and with great gas mileage (48 on HW and 54 on city). No any code comes back yet. Just checked the I/M readiness, found that all were ready but the EVAP.
  14. andrewclaus
    993
    326
    Golden, CO
    Terminal 3 on the CHRS relay, the top terminal (fed by a green wire), must have 12 V on it at all times when measured to chassis ground. If not, the fuse labeled 10A CHS W/P is blown. It's in the fuse holder in the engine compartment. Don't rely on a visual inspection, use an ohmmeter.
  15. TeslaCoils
    TeslaCoils Junior Member
    Ohio
    under the rear of inverter is a pump (I'm doing an ABS/ ReGenerator) 064100-00951
    14 vDenso Made in Japan
    Has a few names
    Water Circulation Pump Cooling
    INVERTER COOLANT PUMP
    21:50 how to remove connector clip
    https://i.ebayimg.com/thumbs/images/g/SJcAAOSwTs5k56N2/s-l500.jpg
    All 4 shown:
    #15 TeslaCoils, May 30, 2024
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,071
    1,987
    NJ-USA
    That particular pump is to circulate coolant through the heater core when the ICE is stopped (and the HVAC ecu calls for heat).
    FYI it is not part of the inverter cooling system.
