Tail lights acting weird
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Abe, Oct 26, 2014.
  1. Abe
    Abe Junior Member
    37
    OK I think my 2004 Prius is haunted.
    Last week both brake lights (just the upper, red part) stopped working.
    A day later the right/passenger side light came back on.
    Then the next day, the left/driver side light resumed working too.
    Great, right?
    Nope.
    Today both went out again.
    Then the right side came back on.
    What's going on? A bad fuse? loose wire? A dying LED? A Poltergeist?
    Any suggestions?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    The condition of your 12v battery is what?
  3. Abe
    Abe Junior Member
    37
    Haven't checked, Everything else working fine, all lights, etc. Dealer wants $800 to replace BOTH tail assemblies, he says both LEDs are giving out. Ouch!
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Well there's your answer. You need to replace both units. Yes it seems wasteful but that's just how it is. You can get aftermarket rear lights on ebay for much less, though you need to check that they're legal for use.
  5. valde3
    valde3 Senior Member
    2,002
    747
    Finland
    It’s possible to repair rear lights by replacing leds. You just have to cut hole into housing and replace leds that way.
  6. JC91006
    JC91006 Senior Member
    16,723
    8,546
    I believe you can buy aftermarket tail lights for less than $100 each. I bought a new driver's side light at Camelback Toyota for $177, installation wasn't too difficult. I would be cautious in buying used, many would replace their non working LED tail lights and put them on ebay.
  7. Mendel Leisk
    40,934
    FWIW, I've seen a lot of second gen driving around with headlights on but no tail lights. Actually my first conversation with a Prius driver came about thus. I was walking down to my train connection, noticed a Prius go by, back completely dark. Caught up with the guy in a parking lot, mentioned what I'd seen. He seemed to know about it, guess it was an ongoing issue.
    We started talking mpg, and maybe that's when I got the bug: we had a Civic Hybrid at the time, lagging Prius mpg by about 10%, at it's best.
  8. Abe
    Abe Junior Member
    37
    How does one determine whether the lights available on ebay are street legal?
  9. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Before going to replace the lights, I would make sure that the associated chassis common connections are clean and tight. They are located under the rear hatch. You need to take out the rear deck to access the wiring harness.
  10. Abe
    Abe Junior Member
    37
    Would you have a diagram, or a link to one?
  11. Cadenza
    Cadenza Member
    125
    43
    LALA Land
    2-3 LEDs in my brake light clusters work intermittently and sometimes flicker. Do LEDs flicker? Is that a sign they're heading to LED heaven or reincarnate into future Prii???
  12. nh7o
    1,686
    340
    Hawaii
    Here you go.
  13. Abe
    Abe Junior Member
    37
    Much appreciated. Thank you.
  14. Abe
    Abe Junior Member
    37
    Taillight Update:
    Took the Prius to Prestige Coach Works, a AAA-approved repair shop in Marina del Rey CA that has helped me in the past. Unlike the Toyota dealer, these guys did check the wiring. But they came to the same conclusion: I needed both lights replaced. I then went on eBay and bought a PAIR of brand new aftermarket lights, with a 10-year warranty (Toyota warranty is for 1 year) and free shipping, for $125 (they came from AM-Autoparts). Repair shop charged $50 to install them. Everything looks great and works great, and I saved over $600 compared to Toyota's outrageous estimate. My 2 takeaways: 1.Research pays off, and 2.Dealers are thieves! (actually, one more: When you find a good repair shop, it's like striking gold.)
  15. JC91006
    16,723
    8,546
    You can't really compare OEM parts costs vs aftermarket parts costs. The fit and finish of the product will be different. Yes there is a savings by going aftermarket, but many times, you will find out, you get what you pay for. But for a savings for $500, I would go aftermarket too.
    If you would have chosen the DIY cost with original OEM replacements from discount online retailers, the cost would be around $177 each light.
    #15 JC91006, Nov 3, 2014
