Wish list for next generation Prius Plug-in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 100 mph, Mar 7, 2014.
  1. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Cheap here too!
    retired4999 likes this.
  2. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Thrifty is what I would call that. Smart also, not wasting hard earned cash.
    markabele likes this.
  3. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    Good, we need more people to ask for this. I did in post 135 as my #6 wish.
  4. -Rozi-
    -Rozi- Member
    134
    60
    Slovenia, E.U.
    2014 Prius Plug-in
    Automatically foldable outer rear-view mirrors: fold when you lock the car, unfold when you put it in D, R, or B.
  5. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    HV mode that's optimized for the PIP not copied from the non plug in. Example ICE shut down on deceleration should happen at 62 MPH like in EV mode.
    -Rozi- likes this.
  6. Mendel Leisk
    41,925
    Not sure if it's been mentioned, but:
    A revamped Tire Pressure Monitor System that doesn't use expensive, fragile, hard-to-program sensors in each tire.
    Ashlem and rxlawdude like this.
  7. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    … and that don't get destroyed by using Toyota's flat solution for the PiP. That's just dumb.
    Ashlem and Mendel Leisk like this.
  8. El Dobro
    El Dobro A Member
    7,093
    3,271
    My Buick has that. ;)
  9. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    Sorry to bring up an old topic, but......
    I don't know if this has been mentioned in this post (I've seen complaints about it) but fix the "FINISH" part of the timer. I use both timers, one for the weekdays and one for weekends (and vacations, holidays, etc.). The FINISH timer should know what type (L1 or L2) of charger you have plugged in and the state of charge you're starting from and finish by the time stated. Typically it just starts 3 hours before you leave.
    Or better yet fix it so we can have multiple timers. My thermostat at home is the size of a pack of cigarettes and I can program it with multiple cycles per day and for each day of the week.
  10. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I've been driving my PIP since Feb. 2012.
    I drive 15 miles to work, with 3 miles of highway. During the Highway segment I usually press the HV to lock in and save the Battery until I get off and Press it again to go back to EV. I can then almost get to work before the battery runs out.
    However, if I forget to Press the button to go into HV, when I get off the Highway I have very little battery left, so I drive with the engine more than desired.
    I wish I could set an option to Force HV mode whenever I go above 62 mph, when the engine comes on.
    Another wish - that we had a button to reset the engine to off below 62 mph, if it turns on and then stays on until warmup, like if I bump up unexpectedly to the Power Area and the engine start, yet know I don't need the engine any more.
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    European PiP does that. They don't have blended mode like us and they wish to have it.
    Having option is good.
  12. hill
    8,929
    PiP v.
    'nuf said . . . . . . . .
  13. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    There's a ~2-3% difference in fuel economy, and I imagine a ~4-5% decrease in the drag coefficient with grill blocking.
    Testing grille blocking & wheel skirts: +5.7% improvement - MetroMPG.com
  14. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    1. Option for increased range, up to 25 miles / 40 km.
    2. Along with that increased range, increased top EV speed, up to 110 kmh / 68 mph.
    3. Along with that increased range, increased acceleration on EV, so that flooring it doesn't activate HV mode.
    4. AWD.
    5. Better solution for charger cable lock. Perhaps something like this:
    6. Availability of accessories in Canada. Currently the only Plug-in Prius accessory available in Canada is the block heater. Toyota Canada doesn't carry any of the other accessories, including cargo mats and what not. Wth?
    7. Remove those stupid tire pressure sensors.
    8. Spare mini-tire option, with a rear cargo space bracket for it.
    9. Electric heater for car pre-warm up when plugged in. In other words, allow the car to warm up via an electric heater when you press the AC button on the remote, but only when the EV charger is attached.
    10. Cheaper and more consistent NAV updates. This should apply to ALL Toyota and Lexus vehicles.
    11. NAV audio decreases radio audio. Right now radio continues to play at full volume. (Not sure if I have this set correctly.)
    12. NAV audio increases with car speed.
    13. Get rid of the flying buttress design for the console.
    14. Cargo tray that allows access to the storage compartment.
    -Rozi- and rxlawdude like this.
  15. Tideland Prius
    16,621
    You can adjust the nav audio (it's called Voice Guidance under Settings --> Voice if the menu layout is the same).
