Cellphone Mount Recommendations?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tweaver, Nov 2, 2014.
  1. tweaver
    tweaver New Member
    Cambridge, Ma
    I'm looking for a cellphone mount and I see the dealer recommends the vent mount. But, I'm concerned about heating up my phone when I have the heat on in the car... Any other suggestions?
  2. ncases
    ncases Senior Member
    609
    672
    Chicago
    image.jpg Try this one i bought it from walmart. Its magnet and you can place it anywhere you want as long as it hold the holder
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Here's a mount which I got from eBay. It came with the vent-clips but I was concerned about heat etc. so I used the flexible stalk thingy with the suction cup (supplied) attatched to the small ¼-light panel on the driver's side. The other pics show my set up for the 2 SG-IIs and the Garmin 276C GPS (purely for info. and to show how the set up doesn't block the view from the driver's seat) Clip_3.jpg Clip_1.jpg Clip_2.jpg - Wil
    Data Daedalus likes this.
  4. winglik
    winglik Junior Member
    26
    NYC
    Since I never use the CD player, so I got the CD slot holder. It's a good spot in the car to put my phone. It doesn't block any visibility. It sits in the middle of both vents. but not enough to block the wind nor create over heat to the phone.
  5. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I use iOttie. The suction cup is amazing. I can actually install it on the side of the console. Actually, I have one for sale if anyone is interested because the I bought a bigger version of it so my iPhone 6 Plus would fit.
  6. lester williams
    227
    68
    mississippi
    I use the ''Pro Clip'' holder in my center left-hand A/C vent, and I am completely satisfied with it. The heat does not blow out of the center vent, A/C only, so no ''over heating'' issues are to be had. It also actually helps with reception in rural areas as the phone is higher and close to unobstructed windshield. I also have one in right hand A/C center vent for G/F's IPhone and we did not notice any lose of cooling this summer, we both like this set-up. I also judge them both very solid and high quality------- and no, I am a user only-- not affiliated in any way to them .
  7. 50MPGPAUL
    50MPGPAUL Junior Member
    25
    La Jolla
    ^ pro clip is awesome
  8. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    I use the mountek nGroove cd slot holder that I got on Amazon, works well for me and puts my iPhone 6+ in a good spot for using it for nav. image.jpg
  9. robomoto
    robomoto Member
    78
    55
    Surrey, BC, Canada
    Nothing worked for me so I made my own out of hanging wire LOL. Price: free
    Data Daedalus and RMB like this.
  10. Roar
    Roar Junior Member
    Long Beach
    I love my Nimbus mount. Search for it on amazon.
  11. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I use a mount called the Square JellyFish. I found it on Amazon for about $20, It is very secure when I clip it on the vent. There is a screw on the back that has to occasionally tightened but its worth it.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I don't like my phone blocking the vents and don't like the cold air blasting it. I also don't want it below the dash since that takes my eyes too far off the road but I don't want it on the windshield because that prevents me from using the sun screen.
    I'm not hard to please at all.
    I used this for a little over two years with it stuck to the little triangle window, but it recently broke.
    I recently got this one, and I think I really like it. Very stable. No bouncing or sliding. And if something goes wrong, it was only $10.
  13. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I’d patent that if I were you! You might strike it rich marketing a design like that - it’s actually useful.....and absolutely ingenious
    iPhone 6s +
    jerrymildred and WilDavis like this.
  14. WilDavis
    2,493
    2,155
    49
    …before someone else does! :rolleyes:
    jerrymildred likes this.
  15. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I don't like that either, my remedy for that was to shut the vent I put it on so that none of the air would hit the phone. I live in PA so I use the heat most of the time this time of year, and with the vent closed my phone stays at a reasonable temperature.
