4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    There once was a certain un-named writer that gave the impression that he wants all of the "attributes," but at the price of a Prius.
    I am quite certain that any and all manufacturers would immediately marked a vehicle that meets, and exceeds, all of the stated criteria (power, acceleration, fuel efficiency, quietness, size, towing capacity, comfort, and reliability ) at the cost of a Prius if such a design were possible. But each one of those attributes, dictates a compromise in one of the other attributes. Too bad that engineering and physics, just isn't fair.
    BTW, I do not believe the accelerator pedal is physically connected to the ICE, so I do not understand the "heavy input" comment. Also, I live in the mountains, (5000 foot elevation, and must climb over passes to leave my valley). I hear the ICE work harder, but never had it "screaming" on a grade. OTOH, my BMW works a little harder to climb the same grades as well.
    SageBrush likes this.
  2. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    I apologize for causing any controversy.
    All I said was I would like better performance (ie closer to a Camry Hybrid) out of the next gen Prius. I said that I'd be willing to take a MPG penalty for this. I never mentioned price, but I'd pay more for better performance if you must know. I said, I like the more space efficient and larger cargo area of the Prius over the Camry body. In my opinion the Prius seems to work harder at 75 MPH than the other modern cars I have driven. This is just my experience.
    I also apologize for embellishing to prove my point. No the ICE doesn't scream, but it does drone excessively loud when it works, and in comparison to other modern cars that I have driven on the same grades.
    I know there are other's who have stated similar things about performance. I don't mean to upset any who does not agree with my opinion.
    lensovet, Felt and SageBrush like this.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Camry hybrid power is between a 4 and a 6 cylinder. it has 200 hp. When I tested a Camry hybrid, I felt as if it had more power and faster than my TSX, and TSX is FAST!
    The 2012 Acura TSX has 201 hp.
    This is week 7 for me as Prius driver, almost no driving time for the other car, more "fun to drive" with Prius.
  4. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    The un-spoken back-theme here reminds me of the years (ago) when Ford stuffed V8's into Pinto's & Mustang II's and Chebby stuffed V8's into Vega's and Monza's, etc.
  5. Tideland Prius
    16,553
    The problem is that people expect the Prius to be a leading in mpg so warranted or not, the Prius is expected to blow the minds of what's possible in terms of delivering incredible fuel economy in a car that's easy to drive every day and requires fewer and fewer compromises with each generation as technology improves.
    Also, with the Gen 3, you need to push past 130km/h. That's when the engine starts focusing on power and not fuel economy. (You'll also see the ECO light go off in the HSI to indicate it switched modes)
    Note the torque increase past 3,650rpm if you the torque to accelerate and pass someone.
  6. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I think he has point. Look at the difference between the Prius v and Camry Hybrid, 1 mpg. I would think the Camry HSD in the Prius v would be an awesome combo and probably even better mpg given the better aerodynamics and lighter weight of the Prius v.
    Emcguy, NR427 and Tideland Prius like this.
  7. Tideland Prius
    16,553
    I suspect that the Prius chassis wasn't built for the 2.5HSD setup. The question for Gen 4 is should the chassis accommodate the v and PHV or just the PHV? If the latter option, then the v needs to be on a separate chassis which may increase cost.
    The Gen 4 will be built on Toyota's new NGA which will form the basis of a larger range of vehicles so maybe there's a chance the v may get the 2.5HSD setup (still unlikely but it'll benefit from the extra torque but how to offset the extra weight of the 2.5 litre engine?) The more weight the mechanical parts weigh, the less weight you have left over for other things like creature comfort. Wasn't an issue before since it was generally agreed upon that upgrading to a V6 in a family sedan came with more power and a fuel economy penalty but not in the case of hybrids where people expect both extra power and next to no fuel penalty.
  8. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    An innocent question .... because I would like to know.
    Is the 1.8L engine in the Prius, the same engine that is used in the Camry Hybrid? Obviously, the Camry is larger internally, but I mean the external dimensions.
  9. Tideland Prius
    16,553
    No, different family. The 1.8 litre engine in the Prius is from the ZR engine family line (same as the 1.6 litre 1ZR, 1.8 litre 2ZR, 2.0 litre 3ZR. (FE for regular cars e.g. 2ZR-FE, FAE for Valvematic versions, 2ZR-FAE and FXE for hybrid versions, 2ZR-FXE).
    The engine in the Camry Hybrid is from the AR family (The Camry's is the 2AR-FXE). The engine is 50kg heavier than the ZR.
    Felt likes this.
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Toyota seems to leapfrog each new model with greater efficiencies. The 2004 Prius motor weighed 45kg and power was rated at 50kW. The 2007 Camry Hybrid motor is only 41.7kg but puts out 70kW. But everything else about the Camry Hybrid is bigger including the battery as well as the ICE you mentioned. The poor Prius v would also need upgraded suspension as well. There goes the weight savings...
    Tideland Prius likes this.
  11. Tideland Prius
    16,553
    The same power:weight was applied to the 2010 Prius, wasn't it? Power was bumped to 60kW even though the motor was smaller and lighter (but less torque which was supplemented with the reduction gear).
  12. Sergiospl
    3,938
    1,351
    28
    Toyota to pack track-tested tech into next Prius
    drash likes this.
  13. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I wish. It was increased substantially from the 2004 but in this case size matters, the bigger the motor the more room you have to get greater efficiency returns. Here are the peak specific power ratings as put out by Oak Ridge National Labs for various Toyota/Lexus motors:
    2004 Prius (50 kW) - 1.1 kW/kg
    2007 Camry Hybrid (70kW) - 1.7 kW/kg
    2008 Lexus LS600h (110kW) - 2.5 kW/kg
    2010 Prius (60 kW) - 1.6 kW/kg
  14. 1945steve
    1945steve Junior Member
    68
    southern indiana
    I haven't read all 160 pages of the gen 4 info but I do have one question: does anyone know if the engine is being modified to eliminate the cold (and sometimes warm) weather rough starting issue?
  15. 70AARCUDA
    845
    209
    Tucson, AZ
    The CLIFF's Notes™ summary statement:
    "The advancement comes in the semiconductors that manage the flow of electricity through the power control unit that integrates a hybrid vehicle's battery, motor and generator."
  16. lensovet
    2,615
    496
    Burlington, NJ
    That's followed by another statement that this won't be commercially available until 2020. So clearly not gen 4.
  17. cmth
    cmth Active Member
    279
    142
    UK
    I like the idea of AWD. Over here in the northern bits of United Kingdom, winter can mean very slippery roads so even if G4 retained its current level of ground clearance, the addition of AWD would make the car much more safer and maneuverable on frozen/icy roads.
    With regard to the comment on Semiconductors, I think there are two separate bits of information.
    1. There are new control devices being used in G4, these "chips" are also re-used in racing car so they get tested in extreme conditions
    2. Silicon Carbide semiconductor devices are not ready to go into production so will probably not make it into G4
    #3197 cmth, Nov 10, 2014
    lensovet and drash like this.
  18. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yeah that's what I read. In addition to number 1, the control chips are being tortured with rather large swings of voltage and current spikes from being mated with super capacitors. They'll have a rather pedestrian life in the gen 4 Prius.
  19. Starship_Enterprius
    Starship_Enterprius Active Member
    329
    162
    Ottawa, Ontario
    2018 Prius Prime
    Altho an AWD is an appreciated addition its not really crucial for me. My primary interest with AWD is potential higher fuel efficiency. I've always thought with 2 motors, the rear can be optimized for low take offs and the front optimized for highway thereby giving better overall mpg. That's why i was really interested if Honda will put a hybrid with their upcoming HRV. With that small size and a front and rear electric motor setup and better hybrid drive (in my opinion) than the current Toyota's, i was salivating with the potential of significantly better mpg's in the next few years.
    #3199 Starship_Enterprius, Nov 10, 2014
  20. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    That's what Tesla did with the S85D and P85D, it did extend range
    S60 208 miles range 5.9 sec 0-60 120 mph
    S60D 225 miles range 5.7 sec 0-60 125 mph (taken down, no longer available for orders but it shows the range improvement possible for dual motors in this case was ~8%)
    S85 265 miles range 5.4 sec 0-60 125 mph
    S85D 295 miles range 5.2 sec 0-60 155 mph (range increase for dual motors ~11%)
    P85 265 miles range 4.2 sec 0-60 130 mph
    P85D 275 miles range 3.2 sec 0-60 155 mph (range increase for dual motors ~4%)
    The S models use smaller motors and get that 8-11% range increase. The P models use bigger rear motors that aren't as efficient.
    When you consider the Model S is a luxury car with high performance there is probably even more range increase possible for a car where acceleration isn't as important.
    Starship_Enterprius likes this.
Thread Status:
