Big orange cable under the body... Safety concern?
Discussion in 'Prius c Main Forum' started by FireFire, Nov 29, 2014.
  1. FireFire
    FireFire Member
    101
    Ontario, Canada
    Do you guys notice the orange electric cable under prius c's body? I think those are the cable from the battery pack to the engine bay. Any concern about those cables on rough road or snow day... Sounds risky but I think toyota thought about that already.
    I found one pic on google. The orange on the left is the one I am talking about and it looks like plastic pipe.
    #1 FireFire, Nov 29, 2014
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    All the Cs have that. Ive had my for almost 2 years and not one problem with it going thru snow and rain. I recently examined the orange cable when I installed my chassis brace and did not see any type of wear and tear on the wiring.
  3. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    that orange cable is made out of titanium
    so don't worry ;)
  4. Mendel Leisk
    41,376
    That's not so much cable as sheathing, robust looking too. And yeah, Orange is code for the hybrid system wiring.
  5. FireFire
    FireFire Member
    101
    Ontario, Canada
    Thanks. Feel better now.
  6. GregP507
    GregP507 Senior Member
    3,002
    481
    You could wrap it with another layer of insulation, but that's probably over-kill, and I doubt it would accomplish anything.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Just a thought on this but if you take a chunk out of that cable driving over a rock, would the car notice and isolate itself by switching off?
  8. Mike500
    Mike500 Senior Member
    2,593
    767
    That wouldn't be a good idea, since insulation causes heat retention. Electrical wiring insulation is temperature rated. It's heat that causes insulation to melt in wiring and fires from short circuits.
    Making a protective steel or heat conductive metal shield would be better.
  9. GregP507
    3,002
    481
    Probably leaving it alone would be better.
  10. SwhitePC
    495
    214
    ca
    Unless you're driving it like a stolen tesla, you shouldn't worry too much about freak accidents
    I've (very carefully) driven my C in some pretty rough dirt/rock roads that no C should go on and I was more worried about random rocks/ditches puncturing other components then the orange wire
    and
    my clutsy wife has also gone straight from a curb onto the street and the metal side thingies have also protected the underbody of the car pretty well (it bent a little inward...but it is still there hanging down lower than the underbody components)
  11. GregP507
    3,002
    481
    I think the infamous Tesla incident to which I think you refer, was a freak accident, caused by a piece of metal puncturing the battery pan.
  12. bisco
    51,873
    an aftermarket kryptonite protective sleeve might sell pretty well, especially if they can make people worry enough.
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    If you punctured the insulation it most likely would create a Ground Fault. The system has a GF detection system that would generate a DTC and safely shut down.
    GrumpyCabbie likes this.
  14. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    No, since he said "stolen", it is most likely this one: Officers Injured, Stolen Tesla Split in Half After Fiery Pursuit Wreck | NBC Southern California
    Although it could be the one in Mexico in which the stolen Tesla was driven into a turn-about at 100mph, hit and traveled through a concrete retaining wall, went airborne, went through another wall and then caught on fire after the thieves got out and ran away.
  15. It's fine. I kept my hybrid parked outside all last winter with temps down to -15F.
    And when the temps warm back up, I take it to a car wash and have it spray the undercarriage, and it's still fine.
  16. orenji
    orenji Senior Member
    5,887
    3,488
    Do Habanero colored C's use a different color for the Orange cable? ;)
    ewaboy likes this.
  17. bisco
    51,873
    lime green. stay thirsty my friend.
    ewaboy likes this.
  18. ChrisChichester
    ChrisChichester New Member
    VT
    2015 Prius c
    My 2015 prius c with 29k miles would not start yesterday after I pulled into a gas station for some coffee. Towed 2.5 hours to the dealer, "Found corroded positive battery cable" "replace pos. battery cable." $1,753.40 not covered under warranty! :( The mechanic told me to file an insurance claim, kept insisting I hit something. I did not hit anything.
  19. bisco
    51,873
    ask for the old parts back and post a pic. sounds like a ripoff. but it could be that something damaged the cable, i'm presuming the high voltage cable to the hybrid battery?
  20. Mendel Leisk
    41,376
    Take his word, file a claim?
    If insurance assessment there was no hit, go back to Toyota? This shouldn't be happening, and your car is near-new.
    There's a few other threads here on hybrid battery cable failure; I'd suggest to just search with google for "priuschat hybrid battery cable (etcetera)", not this site's search function. Or try both. Might find something helpful.
    Assuming there was no evidence of impact, I'd definitely contact Toyota corporate, don't see why this wouldn't be warranted.
