Fuel sense indicator worn out @ 105,145 miles
Discussion in 'Gen 3 Prius Main Forum' started by ruizfamily-u2c3, Dec 4, 2014.
  1. ruizfamily-u2c3
    ruizfamily-u2c3 Junior Member
    South Tx
    My Prius just stalled out on highway from cruise control @ 65 mph, so I coasted luckily off an exit, and before coming to complete stop the whole dash went black with exception of power steering failure warning light. I had it towed, at my cost of $95, to dealer for troubleshooting. They found that the fuel sensing system/indicator had worn, and cost for repair is $422+, as not under any warranty or recall. Anyone else have similar events, please reply with ideas. Thanks,
    51,873
    that's a new one on me. sorry to hear it.
  3. Mike500
    Mike500 Senior Member
    2,593
    767
  4. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    wow never heard of that, not even on priuschat. sorry.
  5. bisco
    51,873
  6. Mike500
    2,593
    767
    Bisco,
    It is a known defect in Gen II Prii. Toyota gave certain VIN# cars a warrantly enhancement.
    2014 Toyota Prius Speedometer Instrument Cluster Dash Panel Gauges 739 Miles | eBay
    Combination Meter Warranty Enhancement | PriusChat
    It could also be a bad sender unit in the tank. However, unlike the simple gas gauge of old, the ECU senses a "no gas" error, returns and error code and shuts down the car.
  7. bisco
    51,873
    thanks mike!
  8. Mike500
    2,593
    767
    Welcome.
  9. ruizfamily-u2c3
    South Tx
    Mike; that's exactly what they said fuel sending unit had worn out
  10. bisco
    51,873
    do you have to drop the tank to do that? iirc someone else had this problem.
  11. Mike500
    2,593
    767
    #11 Mike500, Dec 5, 2014
  12. bisco
    51,873
    that's easy access, thanks.
  13. Former Member 68813
    3,524
    983
    US
    That can happen with any car. I had gas sensor stuck in my old nissan sentra under 100,000 miles and also run out of gas. They say that using quality gasoline with techrone prevents that.
    OP: what brand of gas do you buy?
    #13 Former Member 68813, Dec 6, 2014
