Ramp clearance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frank O, Dec 15, 2014.
  1. Frank O
    Frank O Junior Member
    35
    I was going to pull my 2011 Prius up onto my ramp set (Harbor Freight's solid steel ramps, #68365) only to notice that, due to the Prius's low clearance, I can't get the ramp anywhere close to the front tires without hitting the front body. Has anybody figured out a solution for that? Or do you all use jacks and jackstands?
    52,388
    i think there are other ramps that have a lower profile. what if you tried putting some wood on the floor before the ramps, so you hit them at a higher plane?
  3. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I use Rhino Ramps with my Gen II and they work fine. However, I no longer have a front spoiler attached which may make the difference.
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    +1 on some 2x4s, etc placed in front of the ramps to gain 1.5 inches of clearance.
    SCH-I535
  5. working1
    working1 Active Member
    121
    112
    My set-up:
    (2) - 2 ton Low Profile Steel Heavy Duty Floor Jack, Harbor Freight # 68050
    (4) - urethane jack pads, eBay purchase from seller urethanepads, search for: vw volkswagon jackpad
    (4) - jackstands with a flat top, these are over 25 years and fit the jack pads perfectly. Most newer jack stands do not have a flat enough top.
    Advantages with this set-up:
    - Use both jacks on one side of the car to rotate tires. Jack pads fit nicely and don't damage the pinch welds.
    - Use one jack for the front end and lift high enough that the plastic door can open and not hit the ground for oil changes. Note: always position 2 jack stands with pads in front in case the floor jack fails. Safety first.
    - Use one jack at both ends at the same time and position all 4 jack stands with pads under the car. Good for working on brakes and changing the ATF fluid.
  6. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    My 94 chevy impala ss had the same problem, and I have the rhino ramps. a couple 2x4 or even a few brick laid flat on the ground at the base of the ramp gave me just enough clearance to clear the air dam/bumpers....
  7. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Rhino Ramps - just finished changing oil on our 2011 Model 5 (which has low profile tires).
  8. Southbound
    Southbound Member
    91
    29
    Palos Heights, Il
    Ran into same problem with my wife's '11- was short a good 6 inches. I just drove it up; there's enough give in my opinion that there is no lasting damage . Even with it on the ramps there isn't enough room under there .... The 2x4's would do the trick.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Lol, low profile tires + larger diameter rims = roughly the same ground clearance as my 2011 model 3. Same overall total wheel diameter. ;)
    SCH-I535
  10. steve53mg
    steve53mg Junior Member
    33
    I use Rhino plastic ramps and there is no problem getting up on them. The car is just high enough that I could squeeze the oil access door forward out of the way just scraping the ground with it. My car is a 2012 Prius 4 with standard wheels.
  11. Mike500
    Mike500 Senior Member
    2,593
    767
    My favorite;
    And, much better than the Rhinos.
  12. Yakoma
    470
    125
    sss
    ^^ Didn't know about these, but if I was buying again, I'd get these instead of the Rhinos.
    More gradual incline and a better bump stop at the top, I think.
  13. Mendel Leisk
    41,900
    As outlined above, to solve your ramp clearance a bit of 2x8 on the approach should suffice. But commenting on your last sentence:
    I gave up on ramps a few decades back, just didn't like the excitement of running up the ramp and abruptly stopping (hope, hope) at the top. Plus considering things like transaxle fluid change (where car needs to be raised and level), brake inspections and tire rotations, and with the car being garage-kept, I prefer and use floor jack and jackstand.
    My only issue: the proscribed jacking positions (for placement of scissor jack) are sharp, unreinforced edges. I've found alternative points, relatively close, on reinforced structural components.
    Even using the scissor jack, with the correct shaped slot, which just cups around the crimped edge and bears on the bodywork directly behind, I've seen a bit of deformation. And this was on the lighter loaded, rear location when I was putting on the spare due to a flat.
  14. Mike500
    2,593
    767
    I made and use a special "pinch weld" jacking adapter that prevents damage to the body work. Several members purchased them from me a couple of years, ago, when I was allowed to sell them, here.
    They were made of strong acetal Delrin or polyoxymethylene.
  15. Mendel Leisk
    41,900
    Thanks Mike, but I gave up on those points, trying to make them work. I found four solid/heavy points, nearby. In this pic the front of vehicle is to the right side.
    The red bars are where I'm putting stands: front locations are just at the end of a structural body rail, and rear locations are in middle of convex thickened area.
    Note the little oblong plugs in vicinity of rear points. Pulling those out reveals a heavy gauge opening. The whole area appears to be a strong point. On our car one of the plugs was missing. When I picked one up at dealership, they told me those plugs are dealer-installed at Pre-Delivery Inspection, and they speculated during shipping some pins go into those slots, to prevent the car from shifting around during transit.
  16. GregP507
    GregP507 Senior Member
    3,002
    481
    Low-angle ramps are what you require. They're safer anyhow.
    ftl likes this.
  17. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Do you know who makes those?
  18. GregP507
    3,002
    481
    I believe those were fabricated by a metal shop.
  19. A617
    A617 Member
    213
    95
    OKC, OK
    You could stack some wood and place it behind the ramp so your bumper can clear the metal ramp. See attachment!
  20. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Great pic of the bottom of a Prius.
    I really like the tire alignment though!!!
    Yeah, I know, it's the camera lens.
