2007 Prius base milage
Discussion in 'Gen 2 Prius Fuel Economy' started by Autoconfig, Aug 1, 2014.
  1. dolj
    dolj Senior Member
    8,457
    4,293
    Wellington, New Zealand
    Yes, any service station with an air fill station.
    Also, a question, do you press the "Reset" button (at the bottom right of the "Consumption" screen) each time you fill your tank? If not, press it the next time you fill up then see what the MPG figure is by the next time you fill up. See if you can run a good 300 mi before filling up.
    Let us know how you get on.
  2. Autoconfig
    Autoconfig Junior Member
    Bay Area
    Thanks for the information, yes, i did reset button.
  3. Autoconfig
    Bay Area
    Just filled up air pressure front tires 40 PSI and back side tires 38 PSI, i will update you soon about mileage details.
  4. dolj
    dolj Senior Member
    8,457
    4,293
    Do you know what the pressures were before you filled them? If not, did it take a lot of air in each tire to fill to 40/38 PSI?
  5. Autoconfig
    Bay Area
    it was 38 PSI front and back wheels , please find above attached service maintenance document.
    #45 Autoconfig, Aug 27, 2014
  6. Autoconfig
    Bay Area
    Yesterday went to LA , I got around 40.3 to 40.4 round trip total 260 miles, is this good mileage ..?
    Its been month i brought Prius.
    First month fuel consumption update.
    completed 1008 miles.
    one month fuel: 35.26 gallons
    Total spent on 125$
    Started getting 32 miles per gallon initially when i brought car and now getting around 40.2.
    and when i coming back i can hear some small noise from front side small speakers next to driver , is this any known issue with Prius ..?
    #46 Autoconfig, Sep 1, 2014
  7. vskid3
    vskid3 Active Member
    773
    228
    Getting better, but I would still consider that to be pretty low. I've only gotten below 40MPG on one of my 46 tanks. Do you have a friend with a Prius you can borrow and see what you get in it? Or go to a dealer and test drive another Gen2, make sure you reset the MPG meter first. I feel like you must either drive crazy or something is wrong with your car.
    Autoconfig likes this.
  8. Autoconfig
    Bay Area
    before traveling i went to service station and checked car, they said no issues with car, one of mechanic told me since i am new driver it will
    take while to get good mileage and need to understand art to prius driving.
    all along trip mostly i went over 70 MPH in highway, my friend in NJ right now i will check with him in once he comes back,
  9. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    When travelling on the highway in my Prius Gen2, I have developed the knack of accomplishing my journey at 65mph. I will often use cruise control too. Occasionally, I'll put in a burst of speed to overtake or get out of a dangerous huddle of cars driven by clearly inept drivers, otherwise I do stick rigidly to 65mph. You'd be surprised at the fuel consumption difference between 65mph and 75mph for example - especially in a Prius.
    I'm also inclined to believe there might be something wrong with your car - unless your driving style is far more spirited than we might want to believe.
    Do you use your A/C all the time? Do you use the Auto A/C button or do you configure your A/C use manually?
    I run mine at 18c on the lowest fan setting, set to recirculate. Uses far less fuel. Using the Auto A/C function apparently uses more electric energy, ergo the engine kicks in and runs for longer periods more often.
    Are the aerodynamic panels under your Prius missing? That could theoretically create more drag. Just curious - clutching at straws now...... ;)
  10. Autoconfig
    Bay Area
    I went to 400 miles plus trip on this week end,I got excellent mileage between 47.3 to 47.5 (with A/C on and some times heater on)and most of times my speed was 80 mph on highways.
    Spent 4 plus months to get good mileage and got excellent suggestions from u guys thank you all for making me real Prius guy ,started from zero 28 mph to 48mph now. image.jpg
    tanglefoot likes this.
  11. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I just saw the Driving With Load article. It was informative. As far as going up hills and speeding up before the hill is good. I do that a lot. I have found that in most vehicles if you freeze your throttle position as you get to the hill, and hold that position you will slow down a little and hold the mpg reading better. If you let the throttle drop off some you will lose too much speed.
    To maintain good mpg while cresting the hill just feather the throttle and let the car run down hill. If you let off the gas fully you may slow down too much, wasting gas getting back up to speed.
    These things work really well with my 26 foot 14,000 # Motor home! Best mpg = 20, average 10.5 some 15 mpgs too.
  12. Created_1
    Created_1 New Member
    My 07 was getting 47 on worn out Good Year Integritys, now it is getting 44 with new Cooper CS5. My Wifes 08 gets 45 on Michelin Defenders.
