It was a dark and stormy night . . .
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, Dec 23, 2014.
  1. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    The thing to be careful of is the minimum height, especially on the side of the road with a flat tire. Even the best jack is no good if you can't get it under the car. In my 50 years of driving, I've only had to use a car jack once and that was on our 1988 Grand Prix. If I run into trouble with the Prius, I guess I'll just wait on AAA. :)
  2. Mendel Leisk
    41,334
    The little steel wheels on a floor jack are designed for a concrete slab, not loose gravel or dirt. And hanging out into traffic using a floor jack on a narrow shoulder?
  3. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    This jack and a Dewalt...less than 10 chock to chock...on Monday, half asleep, bass ackwards, in the rain. To each their own. ;)
  4. bwilson4web
    16,196
    Ok, more details:
    • Former front tires, Sumitomo T4s, 51 psi max sidewall
    • Front tires replace by rear Sumitomo T4s with 5/32" remaining
      • Part of this test was to NOT rotate tires so the front would wear out first
      • It worked as I have a year or so remaining on the now, front Sumitomo T4s
    • Replaced with Yokohamas, 51 psi max sidewall (51 psi Sumitomo T4s no longer available)
      • Firestone mounted and deflated to door jam pressure, 32-35 psi
      • Yokohamas are on the rear wheels per Firestone recommendation
      • 37F, last night, got barely 50 MPG on 32-35 psi, over 5+ miles @50 mph
      • 37F, this morning, got 63 MPG on 45-48 psi, over same 5+ miles @50 mph
        • because of cold and time, did not fully inflate tires
    • looking at having a lug-nut welded onto scissor jack and an electric drill
      • compact, see 'trailer stabilizing systems'
      • electric drill handles both scissors and wheel lug nuts
        • both cars have 1 kW, inverter
        • have not selected the electric drill, yet
    I agree that the scissors jack 'crank' is the weak part of the design. It has too much slop and not enough leverage. But with a welded lug-nut on the worm-screw and a strong electric drill, it should be no problem. I may need a U-joint to the socket. FYI, I've got a nice, electric hammer drill used to build the wheel-chair ramp for the wife. Worse comes to worse, use the lug wrench to crank it up and down but a long-handled ratchet would work too.
    Overall, I'm happy with this approach. The two new tires were half the cost of four. It also lets me roll-in a new brand of tires and not risk a whole lot if they don't work out.
    ps. I'm more interested in high pressure tires over low-rolling resistance at lower pressure. Now if we're talking 45 vs 51 psi, well that is perhaps negotiable. But I really am a fan of hard tires for low rolling resistance . . . the physics are inescapable.
    #24 bwilson4web, Dec 31, 2014
  5. Mendel Leisk
    41,334
    A few examples:
    Honda style I've seen a lot:
    (Having the two plates, some distance apart, make the linkage much more stable.)
    Our current Toyota jack, the style at least:
    (The linkage jumps around, and the soft casting chews itself up, with every turn.)
    A "Rolls Royce" style I noticed, while browsing: ;)
    Gotta post a link to the above. Guy made it as a project. The top cradle's too flat, ie: not practical for pinchweld, but very nice:
    Scissor Car Jack - SOLIDWORKS, Other - 3D CAD model - GrabCAD
    #25 Mendel Leisk, Dec 31, 2014
    bwilson4web likes this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    "Poof a cloud of- white power- flew from the passenger side, front tire".
    I hope that's just a spelling mistake and not a Freudian slip.
    Otherwise your Prius is being vandalized by The Klu Klux Klan.
