Project: Angry Panda
Discussion in 'Gen 3 Prius Accessories and Modifications' started by RightOnTime, Sep 8, 2014.
  1. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Following modifications:
    • Stock muffler
    • Traction control - OFF
    • Tein - Street Advance (Coilovers)
    Results:
    #61 RightOnTime, Dec 20, 2014
    Dylan Doxey likes this.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Nice work! Did you overinflate the tires and mark them with chalk?
    WE0H likes this.
  3. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Just a couple months later - some random guy posted a Video on YouTube :cool:
    That is a very good suggestion (y)
    32 psi - Front
    38 psi - Rear (so the rear can rotate)
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Take it from the idiot who tried to autocross a tight (Miata) course on runflat tires. ;). You were much more graceful.
    RightOnTime likes this.
  5. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    RightOnTime, yours is by far the nicest, clean and simple and the G's wheels looks best.
  6. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    It pains me to post this pic, but several weeks after the above Video was taken -
    Was driving home on the Freeway and BOOM!! Hit an orange cone in the middle of the Freeway late at night during construction hours :cry::cry::cry::cry:
    Took out part of the lip including one fog light :eek:
      File size:
      92.2 KB
      639
  7. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Ouch!!! :unsure:
    Sure it wasn't one of Santa's elves? :whistle:
    #67 sfprankster, Dec 28, 2014
  8. jamessicat408
    jamessicat408 Active Member
    110
    175
    San Jose, CA
    My condolence to your car :(
  9. sfprankster
    444
    490
    New JDM anti-pedestrian, small furry creature and orange cone mod. :censored:
    KananDume, RightOnTime and xliderider like this.
  10. VALCAS
    VALCAS Junior Member
    28
    Time for the prius g's front bumper!!!
  11. toyopri808
    toyopri808 Active Member
    226
    116
    this thread is EPIC
  12. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Would like to take a step back and give a full review of the 1st two suspension parts after thoroughly bashing the Prius on the Track for several months:
    Tein-Street Advance (Coilovers)
    Installation of the Coilovers took about 2.5 hours with the correct tools and can be done with a floor jack.
    Since the Coilovers have adjustable Dampers (Adjustablity of each rebound/compression stroke) you do have a choice on how hard or soft the car rides. Only issue that I had was when it was time to adjust the front Coilovers dampers - you had to take off the complete Wiper assemble to get to the damper dials :confused: This in fact is due to the design of the Prius.
    Overall - The car felt alive with just a change in the ride height and on the track the car did improve on each corner taken.
    TRD Performance Rear Sway Bar
    Installation took me about 1.5 hours and the instructions were very clear!
    In my Opinion, this was the best Bang for your Buck add on for the Prius. On the track - the transition from corner to corner gave me the confidence to push the car to a higher speed!
    I have now now moved on to a different Rear Sway Bar, but after 8 months the End links did show signs of cracking and tearing :oops: So to others who have the RSB please check those end LINKS!!
    Lets move forward shall we?
    Now it was time to introduce some Cusco/Tanabe goodies into the picture:
    **Picked up from Primo Powder Coat - wanted to match the color of the TRD Rear sway bar without having the bottom of the Prius looking like a Christmas Tree :D
    Top - Cusco (front center brace)
    Middle - Cusco (front lower arm bar)
    Bottom - Tanabe (front Sway Bar)
      File size:
      106 KB
      581
  13. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    • Modellista Muffler
    • Tein Street Advance
    • TRD Rear Sway Bar
    With the Rear Sway bar added to the setup, my times were cut by 2 seconds!! It was just amazing to see the night and day difference this simple bolt on did ;)
    Now it was time to install Cusco reinforcement bars and the Tanabe Front Sway Bar.....
    Tanabe Bar compared to Stock:
    Stock Bar:
    Tanabe:
  14. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Took about 2 hours for the install, but i was taking my time to make sure all bolts were torqued correctly :whistle:
    Front Sway Bar installed:
    Burna J and Dylan Doxey like this.
  15. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    After 2 months from the cruel casualty of the Orange cone devastating my Modellista lip, it was time to make a decision to buy another lip or complete the full G's conversion o_O
    SO..............................................
  16. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    With the above added parts my observations are as follows:
    The Cusco reinforcement bars did help the stability of the car - Especially during high winds but could improve with the the lower rear Triangular bar.
    The Tanabe Lower Sway bar did help out some under steer but not enough to justify the cost of the add on :cautious:
    Overall- After track testing the car for a couple of weeks, my average times got a little slower :( Could it be the thicker Lower Sway Bar that is upsetting the balance of the car? Lets see........
  17. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Badass ride, man.
  18. adizon
    adizon Junior Member
    52
    89
    SF Bay Area
    must subscribe to this thread!!!! Sweet ride, oh and those G tail lights I think are some of the best looking ones of oem, jdm, and aftermarket tails. Did they take awhile to get here?
  19. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Thanks! Each part took about 3 weeks for delivery - :cool: Got to love Customs!
  20. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    TRACK DAY @ Adams Motorsports Park
    • TRD Rear Sway Bar
    • Tanabe Front Lower Sway Bar
    • Cusco - front/center braces
