2001 prius hv battery help
Discussion in 'Generation 1 Prius Discussion' started by Cook71, Jan 12, 2015.
  1. Cook71
    Cook71 New Member
    24
    2001 Prius
    Hi i'm new here. Just bought a 2001 prius with a bad hv battery. I removed the battery and measure the voltage cell and i have found that last 8 cells are bad and the other 4 are 7.7v the rest are 7.8v. Can anyone tell me what to do? Should i replace all 12 cells or only 8 that are low.
  2. bwilson4web
    16,109
    Your choices:
    • ~$2,300 - buy traction battery from Toyota, swap electronics/modules
    • ~$1,500 - buy Dorman rebuild, $1,000 core charge, swap batteries
    • $?? - buy modules, learn how to rebuild pack, and repeat
    Speculation on my part, it sounds as if an internal short drained the modules on one side of the pack. Alternatively, someone tried to rebuild the pack and failed to balance the modules. Check the module serial numbers and see if there is a break in the order that corresponds to the failed modules. Also, check the sensor connector.
    The battery has module pairs and the voltages are monitored by one connector to the battery control electronics. You want to see if there is any evidence of a problem with the connectors.
    Cook71 likes this.
  3. Cook71
    Cook71 New Member
    24
    2001 Prius
    I let you know today. Thank you. Is ok if i replace all 12 cells with gen 2 cells? Or i have to replace all of them?
  4. bwilson4web
    16,109
    The newer modules have lower internal resistance so their voltage swing is more moderate than the older modules. Since you are replacing at least 12, I would recommend get 20 new modules and keep the 20 best old modules. Then pair old and new . . . assuming you can handle the slight offsets of the terminals. Alternatively, stack one side new and the other side old.
    Check some of the early postings but the problem becomes:
    • matching amp-hour (Ahr) capacity - the weaker modules, each contains six cells, will have a greater voltage swing as a function of State of Charge (SOC). A weaker module can go into voltage ranges either too high, out-gassing and heat, or too low, loss of NiMH function.
    • matching initial SOC - all 38 modules need to start at the same, middle value. The Prius will seek to maintain 60% SOC and if any are too high or too low, it again can drive those modules into too high or too low voltage regions.
    Don't forget you will need NiMH aware, battery charge-discharge units to measure what you've got. The balance charge is not too hard by wiring them all in parallel and either charging up to a set voltage or discharging down. But knowing the module capacity is key to re-stacking the modules:
    • pair weakest and strongest on ends of string - this way the measured pair will appear to the battery controller to be 'like the others.' The ends are the coolest parts of the stack and heat is the enemy.
    GOOD LUCK!
    Cook71 likes this.
  5. Cook71
    Cook71 New Member
    24
    2001 Prius
    Thanks can you recomend a battery charger-discharger i can buy to do this
  6. Cook71
    Cook71 New Member
    24
    2001 Prius
    Serial numbers are all the same. Connections looks good. I found gen 2 cells from a 2007 prius. They are only 28 should i buy 10 more? I think that they have to be 38 right?
  7. bwilson4web
    16,109
    Correct, a total of 38. The challenge will be matching Ahr capacity. So look for a battery charger-conditioner:
    • NiMH chemistry, 6-cells (each module)
    • Stops charge based upon all three:
      • dV/dt - the voltage drop that signals fully charged
      • temperature limit - sometimes dV/dt does not work so don't let it thermally runaway
      • charge limit - these are rated 6.5 Ahr so no more than 6500 mahr or 6.5 Ahr
    Do take the buss bars off and start working on removing the corrosion. Look carefully at which ones are closest to the 8-12 failed modules. Search the message archives as I remember someone having success with acetone. Pay close attention to the 19 sense wires. Corrosion can 'eat' the copper inside the insulation.
    Cook71 likes this.
  8. Cook71
    Cook71 New Member
    24
    2001 Prius
    Got a question witch one of those battery chargers are better?
    Dont no for sure witch one to buy. I dont want to buy one that i cant use.
    Genuine SKYRC iMAX B6AC V2 Dual Power (6Amps, 50Watts) NiMH AC/DC Professional RC Balancing Battery Charger & Discharger (Version 2) w/ Micro USB Port, Temperature Port, 2S-6S JST-XH Balance Ports
    Eastvita® Imax B6 OEM Battery Balance Charger for 1-6 Cell Lipo, Li-ion, Life (A123), Pb, 1-15 Cells Nicd and Nimh Batteries
    2B6AC 50Wx2 Dual-Output AC/DC Dual-Power LiPo Balance Charger Discharger
    Thunder Power RC TP610C-ACDC Multi-Chemistry AC/DC Charger/Discharger/Cycler with Balancing System
    HiTec 44167 X4 AC Plus 4-Port AC/DC Multi-Charger
    Eggsnow iMax B6AC 80W Balance Charger/Discharger Lipo,NiMH,Li-ion,LiPo,LiFe 1-6 cells
    iMax B6 50W DC LiPo Balance Charger Discharger
    Dynam Supermate DC6 Doublpower Balance Charger
    Thunder Power RC TP1430C 1000 Watt Single Port Multi-Chemistry DC Charger/Discharger/Cycler with Balancing System
    Kingzer IMAX B6 LiPo/LiFe/Lion/NiMH/NiCD/Pb AC/DC Battery Balance Charger/Discharger 80W
    Muchmore Racing MMHBK Hybrid AC/DC Balance Charger Discharger
    SKYRC QUATTRO B6AC Professional Balance RC Charger / Discharger (EU Plug) BC580 with RCECHO Full Version Apps
    TP610C 1-6Cell LiPo 0.25-10A DC Charger w/Balancer
    GONGXI Digital iMAX B6AC 80W Lipo NiMH Balance Charger/Discharger LiIon/LiPo/LiFe 1s-6s Cells
    Neewer® Bluetooth Version Balance Charger/Discharger/Litium Battery Meter/Motor RPM Tester/Servo Tester Made For iPod iPad iPone
    iMax B6AC 50W AC/DC LiPo Balance Charger Discharger, Dual-Power
    SKYRC QUATTRO B6 320W RC Professional Balance Battery Charger / Discharger BC550 with RCECHO Full Version Apps
    SKYRC Ultimate 400 W / 10 AMP ~ 200W X2 Professional Charger / Discharger / Dual Output
    SKYRC QUATTRO B6AC Professional Balance RC Charger / Discharger (US Plug) BC579 with RCECHO Full Version Apps
    SKYRC Model e6680 AC/DC Input LiPo Li-Polymer Balance Charger / Discharger BC495 with RCECHO Full Version Apps Edition
  9. bwilson4web
    16,109
    Owch! Let me suggest find the URLs for the top 3-4 charger User Guides and post them here. List them in order of what makes sense to you (some may be written in Chinglish) and I'll review them and post my opinion. I need you to start the selection and 3-4 on your top list lets me and our collaborators offer our experienced opinions.
    I am not trying to be coy but it will be your tool and what appeals to me might be poison ivy to you.
  10. Cook71
    Cook71 New Member
    24
    2001 Prius
    I cant post links
    I checked the harness and toke down the orange cell connector to clean the corrosion. What can i use to clean the copper connectors?
  11. Cook71
    Cook71 New Member
    24
    2001 Prius
    Here we go
    skyrc com/download/catalog.pdf
    thunderpowerrc com/Products/Chargers_2/1-6-CELL-LIPO-LIFE-1-14-CELL-NICD-NIMH-0-10-10-0-AMP-AC-DC-CHARGER-DISCHARGER-W-BALANCER
    hitecrcd com/images/products/pdf/208_Hitec_X4_Manual_US.pdf
    pololu com/file/download/iMAXB6ACmanual.pdf?file_id=0J525
    skyrc com/index.php?route=product/product/download&download_id=17
    dynam-rc com/download/supermate_dc6.pdf
    thunderpowerrc com/TP1430C
    skyrc com/index.php?route=product/product/download&download_id=41
    skyrc com/index.php?route=product/product/download&download_id=3
    helypassion it/immagini/download/hn1Cjp_e6680-Instruction-Manual.pdf
  12. Jeff F
    Jeff F Member
    111
    37
    London, Ontario
    2001 Prius
    I'd assume without looking in any detail that they are all essentially similar. One word of advice - pay attention to maximum discharge rate. If you plan to cycle through charge/discharge cycles (and you probably should plan to do tht!) it's the discharge cycle that takes time. Most small chargers have a 50-80 watt charge but only a 5 watt discharge, so it takes 10x longer to discharge than to charge. I ended up springing for the Thunder Power 1430 mostly to get the higher discharge capabilities, 50 watts IIRC. TP has a good name in the hobby community. Most of the specs focus on charge rate but it's really discharge rate that's the bottleneck in our case. Also remember that many of these chargers need a power supply, and if you're charging banks of modules the poser demands can be pretty high - in the case of the TP1430 the charger is capable of delivering up to 1000 watts. I had a big power supply already, but if you're buying this stuff you can pay as much for the power supply as for the charger. Hope this helps. Jeff
  13. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    You really should measure capacity of each module and rebuild the pack with similar capacity modules. Throwing some new cells at the pack is only a short term fix. Get ready to play whack-a-mole!
  14. Cook71
    Cook71 New Member
    24
    2001 Prius
    What about Thunder Power RC TP610C, Thunder Power RC TP820CD and Thunder Power RC TP1430C witch one is better?
    #14 Cook71, Jan 14, 2015
  15. bwilson4web
    16,109
    • NetSuite | Page Not Found
      • delta V, good
      • charge/discharge cycles, good
        • single display of last charge/discharge, weak
      • battery setup memory, good
      • discharge 1A, adequate by means Ahr = hours per module
      • AC powered version, good
      • no temperature limit detect, bad
      • no charge limit setting, only delta V, bad
      • Recommend call Thunder Power as these may have been resolved
      • has charge limit setting, good
      • has time limit setting, OK, mitigates lack of module temperature monitoring
      • requires a high amp, external 12V power supply
    I would recommend calling the sales lines of the vendors and explain you need to measure the amp hour capacity of Prius, six-cell, NiMH modules rated at 6.5 Ahr. At a minimum, you need to cycle discharge-charge the six-cell modules safely. The clueful ones will work with you. The others . . . . have another business model.
    RECOMMENDATION:
    1. Buy battery charger from someone with a fair return and/or upgrade policy.
    2. Practice with the discharged modules
      1. return or replace as you find what works and doesn't
    Understand building a good battery on the cheap takes time. There will be at least 38 modules to test and rate.
  16. Cook71
    Cook71 New Member
    24
    2001 Prius
    I talked with a rep from thunder power rc and they told me that the tp820cd and tp1340 are both good for the prius modules. They are located in vegas so i will go with this manufacturer. Good tech support and warranty. I post updates after i get started with the testing on modules. Thank you so much for your help guys
    bwilson4web likes this.
  17. GregP507
    GregP507 Senior Member
    3,002
    481
    The economics will dictate whether replacing cells or replacing the whole battery is the answer. If only a few cells are bad in an otherwise good battery, just replace the cells. If most of the cells are poor, you're wasting your time and money replacing cells.
  18. 3prongpaul
    956
    730
    Over the last 18 months I've been seeing a lot of dying Gen1 modules. Some of them are now 14-15 years old, and even low mileage cars have batteries dying because of age (not mileage). If you are a hobbyist with lots of spare time (and another vehicle to use while the Prius is down) you can try refurbishing the modules with RC chargers, but it's a gamble.
    Cook71, you should log all the time you spend on the project and share results so others can determine if it's worth the time involved.
  19. GregP507
    3,002
    481
    I'm surprised any of them lasted that long, quite frankly.
  20. Cook71
    Cook71 New Member
    24
    2001 Prius
    Once i get all the tools i will start posting the progress on rebuilding this battery. Maybe later i will upgrade all cells to gen 2 or 3. Dont no if is possible to gen 3 but gen 2 it is.
