Prius side mirrors at different angles to car body???
Discussion in 'Gen 3 Prius Accessories and Modifications' started by talkin73, Jan 20, 2015.
  1. talkin73
    talkin73 Junior Member
    53
    Washington DC
    My 2010 Prius mirrors are at slightly different angles to the car body when fully unfolded. Driver side is about 10 degrees further away than passenger mirror. I saw another Prius with same thing. Is this normal and do others have same thing?
    52,069
    maybe it provides the same view from the drivers seat, since it is not centered.
    #2 bisco, Jan 20, 2015
  3. talkin73
    53
    Washington DC
    Are yours the same way?
  4. bisco
    52,069
    i've never noticed on 3 pri in 10 years, i'll have to look closely.
  5. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I haven't checked my Prius, but I googled "cars from above" and quite a few have the driver side mirror angled further out than the one on the passenger side. Here's a Ferrari, for example:
    As bisco says, because the driver's seat isn't centered the mirrors have to be angled differently in order to give the same rear view. Some cars may do this by having the mirror housings at different angles, as above, while others may just change the angle of the mirror itself within the housing.
    Burna J and talkin73 like this.
  6. talkin73
    53
    Washington DC
    Very interesting. I have since stopped to look at 3 other GEN3's and they all have the same as my car so seems to be a Prius thing. Even with these angles, my mirrors are at noticeably different angles within the mirror housing. My wife's ES350, however, has mirror housings that are at the same angle to the car and the mirrors are also at the same angle within the housing when I set it to provide the same rear view that I have on my Prius. I realize they are different cars, but does indicate that asymmetric mirror housings are not a necessity to provide adequate and normal rear viewing from both sides. At this point, hard to appreciate the benefit of this variance, but difficult to believe its incidental and not intentional for some reason.
    Thanks guys for the feedback and the pic of this on another make/model is also very interesting to see and learn about!
  7. Ank
    Ank Junior Member
    San Francisco, CA
    I noticed this too, and my hypothesis was:
    (a) The housing is differently shaped in the Prius for aerodynamic reasons - the side mirrors are a major source of drag (for example, the reason a Nissan Leaf looks like a frog is because they designed those bulbous headlights to redirect air away from its side mirrors, avoiding that drag).
    Anyway, (b) the differently shaped Prius mirror housing reduces the extent of rotational freedom available to the mirror (ever tried lowering your right side mirror to gauge distance from the curb while parallel parking in a Prius? Its somewhat difficult to get it to go all the way down like you could in most other cars).
    Therefore, (c) not being able to utilize the rotational space as in other cars to angle the mirror's base position, they had to reorient the entire housing for optimum viewing and for enabling sufficient left-right/top-bottom variance for the driver's individual circumstances.
    Just my two cents.
    ftl likes this.
  8. macman408
    1,179
    367
    That's unpossible. If the mirrors are positioned exactly symmetrically, the only place you will get the same relative view in both is if you are equidistant from both (i.e. in the center of the car). Angle of Incidence = Angle of Reflection; it's physics. But perhaps the design on your wife's car makes the asymmetric placement more subtle?
    It's hard to tell from the lighting (and this is obviously a rendering), but the image that Lexus uses to illustrate DRCC for the ES350 seems to show that the mirrors are slightly asymmetric. Not nearly as much as ftl's Ferrari example, but it's there.
    ftl likes this.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    That's exactly it. Here's the Ferrari (not *my* Ferrari, unfortunately!) with lines drawn from the driver's head position (approximately) showing how the angles have to be quite different on the two mirrors in order to provide the same rear view:
    Ank likes this.
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Ah, but with the wide angle of the passenger side mirror its aim is nowhere near as critical as the planar mirror. You could aim them the same and use them that way (suboptimally).
  11. talkin73
    53
    Washington DC
    Props for using the word "unpossible"! But, that's how it is, hard core physics aside. I did measure her mirrors and they are not EXACTLY the same angle but so close as to be trivial. Visually they appear the same where the Prius is grossly at variance from side to side. Perhaps your thoughts on the Lexus image explain some of what I'm experiencing. If nothing else its clear to me that what I'm experiencing is the way the car is designed and other car manufacturers have done similar. Still not clear WHY....? Thanks to all who shared their thoughts and these pictures have been worth a thousand words. Very compelling and helpful.
    ftl likes this.
