LED-backed Lower Rear Red Reflectors
Discussion in 'Prius v Accessories and Modifications' started by Air_Boss, Jul 4, 2014.
  1. Air_Boss
    Air_Boss Senior Member
    4,205
    1,186
    New Yawk
    They don't dim the OEM brake lamps, and they don't affect the CHMSL in my experience (that problem had been reported earlier).
    Just requires powering the marker and brake functions by tapping into the three wires feeding the OEM ground and marker/brake lamps.
  2. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Air Boss,
    So, with the lights functioning as both parking and brake lights do they get brighter upon braking or just flash quickly?
  3. Air_Boss
    4,205
    1,186
    New Yawk
    There are two internal LED arrays. One illuminates with marker lights, the other illuminates with brake lights, they both illuminate (brighter) with markers and brakes.
    tanasit likes this.
  4. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    GOT MY REAR BUMPER LIGHTS TODAY.
    I had them wired to be on only with parking and headlights - no brake or turn signal. I could have opted for one or the other.
    "Better seen than sorry."
    BTW Air Boss, the bumper lights are wired for normal and high brightness for use as brake or turning signal if wanted. Mine are set up for "normal" brightness.
    #64 Eric "v", Jan 22, 2015
  5. Air_Boss
    4,205
    1,186
    New Yawk
    I suppose. Which function(s)?
  6. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    My bumper lights are wired to be on for "parking" and "headlight" only at normal brightness. I decided I didn't want them for turn or brake function.
    NOTE: I had my rear bumper lights professionally installed and the wiring was routed through an existing rubber plug (replaced with a grommet) instead of along the rear door gasket. The installer protected the wiring (outside, under the body) between bumper and trunk floor with plastic "conduit" and silicone caulk seal in the underbody area. Very neat and OEM looking and no new holes were drilled.
    ** I had the wiring run this way because it is far less vulnerable than running it along the rear door seal area.
    #66 Eric "v", Jan 24, 2015
  7. Air_Boss
    4,205
    1,186
    New Yawk
    Right. I use them for parking/headlight (red) and brake (red). Turns are amber.
    tanasit likes this.
  8. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Ditto & +1
  9. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Here are all my
    LIGHTING MODS:
    1. headlights -> Sylvania Silverstar Ultra
    2. fog lights -> Auer LED
    3. running lights -> CREE LED from JDMToy
    4. rear bumper -> Share + Style LED
    5. interior -> JDMToy
    I may get interior footlights in a soft amber/white
    BTW, d' ya think Lowrider v owners would like these tail lights in a sequential up-and-down blinking pattern. Jus' saying'...
    #69 Eric "v", Jan 26, 2015
  10. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    that's a great mod! thank you for sharing it.
  11. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Well that was the end of August 2014 and now March 2015 which is almost 7 months ago and I use my car daily for my business that required at least 3-4 stops with the trunk open/close, so there should be roughly over 1,200 cycles so far. And it looks like below:
    As you can see it is still working and no signs of wear or tear, thus your concern is unfounded.
    Thanks but no worry now folks.
  12. asukadc
    asukadc New Member
    2015 Prius v wagon
    they look awesome, gonna buy a set soon
  13. Michael Leary
    Michael Leary Junior Member
    39
    22
    Kansas, U.S.
    Had my 2012 versatile for a couple of weeks now and getting mod excited. They are out of these lights on rakuten.com and now want them for $250.00 on ebay. Any other place you know of?
  14. Michael Leary
    39
    22
    Kansas, U.S.
    Can you please walk me through the steps to buy these. I got email from them but nowhere is a way to buy them nor ship them to me. Any help?
  15. Air_Boss
    4,205
    1,186
    New Yawk
  16. Michael Leary
    39
    22
    Kansas, U.S.
    Thank you. I think it went through this time. We'll see. Really want these lights.
  17. Air_Boss
    4,205
    1,186
    New Yawk
    Glad it worked out for you. I think they're some of the nicest night time styling updates.
  18. chriswong
    chriswong New Member
    There are fellow members installing the taillight. Looks good as well
    Prius v Valenti tail light install | PriusChat
  19. richwiller
    richwiller Junior Member
    St. Louis MO
    2015 Prius v wagon
    Got my light set in about 5 days and plan to use a power tap off of the aux 12v. receptacle located in the cargo area, that is live while the car is on to power one array. I will tap this behind the panel to keep a clean install. This will serve as a DRL on the rear and will be run through one side of the to be used relays. I will use two double pole, double throw relays energized by the respective turn signals, which will break any power coming from the and "DRL" and brake circuit which will power the second lead to the light through the normally closed contacts. This is the lazy way to get both brake illumination and signal illumination at least while coasting to a turn or lane change and have no effect on the existing lights. Note the signal indication of the new lights will actually be the drop out of the light when the actual signal energizes the relay. Sort of a "wig/wag effect.
    #79 richwiller, Jul 7, 2015
  20. Air_Boss
    4,205
    1,186
    New Yawk
    Easier to tap the tail/stop lamp leads? The lower led-backed reflector arrays have internal diodes to defeat leakage to the CHMSL.
