Beware of the placement of floor guard in prius C as the gas pedal is very low to the floor.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusC42012, Jan 28, 2015.
  1. PriusC42012
    PriusC42012 New Member
    I'm deleting this post because there is nothing wrong with the car.
    #1 PriusC42012, Jan 28, 2015
  2. PriusC42012
    Please disregard this post.
    #2 PriusC42012, Jan 28, 2015
  3. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    This is unacceptable behavior. If it's repeatable you should have the car towed to a dealer so they can experience it.
  4. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    This may seem like a stupid question, but, do you have the mat locked in place? Do you have an aftermarket or second floor mat on top of the first? Did you look and see if something is touching the pedal, or if it can get caught under something after you depress the gas pedal?
    Do you have anything connected to the obd2 port?
    Do you have really intelligent friends who may have hacked into the car and hidden a laptop anywhere?
  5. PriusC42012
    Please disregard this post and thanks all for your help.
    #5 PriusC42012, Jan 28, 2015
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The engine speed alone doesn't control the power to the wheels.
    Take it by the dealer if any symptoms remain.
  7. Eclipse1701d
    645
    224
    Three Touring
    If you are sure about the pedal being obstruction free, you should bring it to the dealership and tell them what happened. That is NOT something to play with. As a reminder, if for some strange reason the car accelerates, familiarize yourself with the proper procedure to turn off your vehicle. I don't remember if the C has a Start/Stop button, but if it does, you have to hold it down until the car shuts off.
  8. bisco
    52,337
    deleted to prevent trolling.
    #8 bisco, Jan 28, 2015
  9. PriusC42012
    Hey Eveyone, problem solved. Thanks for the suggestion. It turns out the gas pedal was covered by the improperly placed floor guard. The floor guard was taken out for cleaning and put back last night in the dark. It actually was on top of the gas pedal.
    ftl likes this.
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Let's say this territory's been covered before.
  11. bisco
    52,337
    ouch. good call eclipse, i will delete my recommendation as well. wouldn't want any trolls picking up on a non story.
