  1. xliderider
    xliderider Senior Member
    8,084
    3,237
    Honolulu, HI
    Pics? Seems like you're using one for your avatar...
  2. Sean Callahan
    Sean Callahan Senior Member
    314
    582
    Honolulu
    Washed and clayed yesterday, now time for polish, polish again, then throw some black fire sealant on :) WEKFEST prep so much fun..... Haha image.jpg
  3. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    Sean! Good luck at Wekfest. Funny thing, I was just asking some local Prius owners what they use to wash/clean their cars. What products do you have laid out there and what do they do if you don't mind me asking? Thanks!
  4. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Getting camber bolts and camber shims installed and realignment by Speed Element. 20150128_144902.jpg
  5. Sean Callahan
    314
    582
    Honolulu
    For regular washing I use Meguiars ultimate wash and wax. For detailing what I had laid out was a menzerna 2500 which is a medium cut to remove swirls and scratches and 4500 which is for finishing it's very light cut polish. Also "Eraser" which will remove all the oils from the polish prior to putting the last product shown on which is black fire wet diamond paint protector. That's what I use as my sealant it's much better then wax and lasts a lot longer.
    Ramtart likes this.
  6. Xterra72
    Xterra72 Senior Member
    1,430
    1,676
    Why are you getting all this work done? Installing larger wheels?
  7. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Ruh roh... :oops:
    OCD is acting up again... :eek:
    ...that black HU adapter against the gray dash is still bothering me... :(
    Sean Callahan and adizon like this.
  8. adizon
    adizon Junior Member
    52
    89
    SF Bay Area
    it's like crack . . . I hear!
    sfprankster likes this.
  9. sfprankster
    444
    490
    ...and all I was going to do was make the 12v plug under the flying bridge hot 24/7... :p
  10. Xterra72
    1,430
    1,676
    3M is my friend. Installed jdm stainless steel rear bumper protector.
    TopRamen likes this.
  11. sfprankster
    444
    490
    Matching HU adapter and center console... (y)
    Through the magic of Photoshop... :whistle:
    Not... :p
    #5911 sfprankster, Jan 28, 2015
    TopRamen, RightOnTime and Ramtart like this.
  12. TopRamen
    307
    578
    Fremont, Ca.
    No, when Speed Element did the original alignment after lowering it, they tried to get it to true 0 but was off a couple of degrees. So they recommended camber bolts for the front & camber shims for the rear to get the alignment to true 0 alignment. Without these, my tires would've worn faster.
  13. TopRamen
    307
    578
    Fremont, Ca.
    Hi sfprankster, how hard was it to remove the original shifter? I tried to remove mine but pretty tough, I didn't want to break the whole thing. Just a thought because I want to get that TRD shifter you have. Cheers!
  14. sfprankster
    444
    490
    The shifter knob just unscrews counter clockwise. No need to remove anything else.
    The shifter bezel comes off with a gentle amount of leverage with a panel tool. I started on the edge nearest the driver's knee, and worked around the panel counter clockwise lifting up towards the rear view mirror/map lights.
    I do believe I'm the winner... :ROFLMAO:
    I found an actual weld in the Prius today...
    #5914 sfprankster, Jan 28, 2015
    Sean Callahan likes this.
  15. Xterra72
    1,430
    1,676
    Oh. I guess My TRD lowering springs were a mild enough drop that alignment was still able to have it within oem specs.
  16. ncases
    ncases Senior Member
    609
    672
    Chicago
    #5916 ncases, Jan 29, 2015
  17. Sean Callahan
    314
    582
    Honolulu
    Anyone got any tips to put the car badges back on? I removed them to do the detail and now they aren't so sticky. I have a couple ideas but just seeing if anyone else has a better alternative. Thanks :)
  18. Burna J
    1,067
    3,337
    53
    Long Beach, CA.
    I just used clear silicone adhesive to reattach them after I removed them for paint. Been nearly 3 years and they're all still on......
  19. Sean Callahan
    314
    582
    Honolulu
    Thanks a lot, I was thinking about using the 3m decal adhesive but I heard some bad things about it. Suppose I'll run to the store sometime today and find something. What you used came in a small tube?
  20. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
