Adding Brake Fluid to Prius two
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bskija, Feb 3, 2015.
  1. Bskija
    Bskija Junior Member
    When Prius was first purchased brake fluid was just above lower mark. Now after three years of use and 30,000 miles the brake fluid is slightly below low level mark. There is no problem with brakes. I want to add brake fluid to where it was when new which is just above lower mark.. I understand about over flow if you fill it to maximum and then put in new brake pads. My problem is how do you get the rubber cover off without cracking it? PriusInParadise solved my problem.I thought the middle mark was minimum, it was not. The minimum mark is below the seal of the reservoir. There is nothing wrong with my brake fluid level.
    #1 Bskija, Feb 3, 2015
  2. Mendel Leisk
    41,299
    Was the car new when you purchased, with full pad thickness, when the level was already low?
  3. Bskija
    The car was brand new
    The car was new. I suspect the tank for the brake fluid was on the lower minimum end so as to prevent one not to over fill it when adding new pads. In most of my cars I would get 75000 miles before needing to change pads. With this Prius two I probably will never need to change brake pads. This is the way I use brakes and because the motors do most of my stopping. With this 2011 I plan to purchase a 2015 Prius two in the spring.
    #3 Bskija, Feb 3, 2015
  4. Mendel Leisk
    41,299
    Maybe it was underfilled, from the factory. If you're getting any maintenance done at the dealership maybe ask their opinion, and they could top it up, save you buying a bottle of the fluid.
    I don't think you'd want to top up to the full mark, keep it a little lower, considering there'll have been some reduction in the pad thickness.
    OTOH, it's not the end of the world if you do overfill a bit, I mean: you can baste out some when it comes time for new pads. All in all, it seems odd: ours was on the full mark when purchased new, and has dropped a bit I think. Our pad thickness are reducing a bit too, to around 7 mm remaining, at almost 50000 km's. New is 10.0 on front, 9.5 on rear.
    If it's just dropped slightly over 30000 miles, sounds like no leaks, anyway.
    #4 Mendel Leisk, Feb 3, 2015
    frodoz737 likes this.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the Gen III forums from the Prius v forums since the OP owns a 2011 which is a Gen III.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Apparently you don't have a good understanding or you would be inspecting the pads first.
    If the pads do need to be replaced soon, then adding fluid is just a waste of time.
  7. kronos89
    kronos89 CHRRYPRL
    105
    North New jersey
    I had the same issue 10k into the car. i Never thought about checking it, and it was low. I took it to the dealer, and they inspected it and found no leaks in the system, so they topped it off. Now at 34k it is low again, and the dealer says it is normal in these vehicles with the braking system they have. So i never kept arguing with them since it is my first prius and am still learning about Prius noises and fluid levels
  8. Mendel Leisk
    41,299
    Second time around it might be low pads. Have you been keeping an eye on their thickness.
  9. kronos89
    kronos89 CHRRYPRL
    105
    North New jersey
    Not really, but shouldn't it be a any normal car? Should make a squeaky noise when pads are on their last leg no?
  10. Mendel Leisk
    41,299
    When you're at the dealership next time, you could ask specifically about pad thickness. Any time they've got the wheels off for rotation it's relatively easy to eyeball. That might clear up why the fluid's dropping: there's a direct correlation between pad thickness and fluid level in the reservoir. Or there should be, unless it's disappearing elsewhere.
    What sounds a little fishy: you report dropping fluid level to them, and their response is it's normal. They're supposed to be doing (cursory) brake inspections if you're getting maintenance there, pretty much every other interval. The feel I get is that a lot of places are doing zip, just relying on Toyota's over-engineering, ignoring the system until there's a complaint.
    Again, my guess is that you're pad thickness's have gone down a bit, but good to know. Minimum thickness is 1 mm, but: brakes don't wear evenly, and going down to 1 mm is asking for trouble. It's good to be cognisant of where they're at, plan ahead.
    Merkey likes this.
  11. Easy Rider 2
    1,584
    258
    Ocala, FL
    You did an excellent job there.........of ignoring the important points and replying to the insignificant ones.
    If you do this, given all that you have said, it is likely you will muck something up.
    Just my opinion, of course.
  12. PriusInParadise
    180
    91
    Hawaii
    Just to make sure everyone is on the same page...
    The brake fluid level in the reservoir will vary with the amount of fluid in the brake accumulator.
    The Max level is the brake fluid level in the reservoir when the accumulator is completely discharged.
    You would almost never see this in normal use. If you wanted to discharge the accumulator, an easy way is to disconnect the 12v battery, and then pump the brake pedal up to 40 times. Somewhere between the 20th and 40th pump, the brake pedal will become very firm. This is when the accumulator is discharged.
    The Support Level is the max fluid level with the accumulator fully charged.
    When you first open the driver's door, the brake hydraulic pump runs, drawing fluid from the reservoir and pressurizing the accumulator, preparing the brake system for driving.
    Pump the brake pedal a few times, the pump will run and then stop. Check the brake fluid level. It should be near the Support Level.
    The Min level is below the seam of the reservoir. If your brake fluid is near the Min level, the Red Brake Warning Light would remain ON anytime the vehicle is in Ignition ON or Ready mode.
    If your brake fluid is near the Min level, the brake system will require inspection.
  13. Mendel Leisk
    41,299
    Interesting. I opened passenger door, reached across to release hood latch, then took this pic:
    Then opened driver's door, let the sounds subside, and took a second pic:
    kc410 and PriusInParadise like this.
