mpg with 91 vs 87, in your prius c
Discussion in 'Prius c Fuel Economy' started by xraydoug, Mar 18, 2014.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I've been to stations alone I-90 which dispensed E85 and gas from the same nozzle, 4 grades. And can you be so sure E85 isn't getting occasionally transferred from one tank to another?
    All this is a moot point: gas differs in E content, and in some locales it can contain 20% ethanol or more.
  2. Mendel Leisk
    41,557
    Not sure if it's just in Canada, but Chevron (and some others?) offer ethanol-free gas, in highest octane only.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    I am sure that further "discussion" with you about this is pointless.
    You win. I quit. :whistle:
  4. cyclopathic
    3,292
    547
    2014 Prius c
    Haven't realized we were playing for something?
    Just passing my experience. Almost cost me an engine, and time baby it to honest gas station.
  5. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    It's a little different...most of the majors here have mandates to blend 10% ethanol to meet quotas.
    Also many major city areas have E10 mandates.
    So if you get away from the major metro areas, you can find some E0 in various grades, usually from smaller gaso companies.
  6. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    Now the price of premium is 22 cents. More at 1.89 so I won't be saving much but I have grown weary of tracking the miles and mpg so I will just run premium if its less than 14% more per gallon. My test was all but one tank at costco in roseburg oregon. And I did the test for the better part of a year. I get 14% better mpg so thatis the figure I will use.
  7. Easy Rider 2
    1,584
    258
    Ocala, FL
    Have we not had this exact discussion before ?
    And have you ever answered the question of how much of that "premium" you were using was ethanol free ??
    Your 14% figure is so far off from what the engineers say and other owners experience (both ZERO) that it cannot be accepted without comment.
  8. cyclopathic
    3,292
    547
    2014 Prius c
    @rider: he probably means he needs 14% to break even on cost.
    Out of curiosity: "C" is equipped with knock sensor, right? High compression engines with knock sensors usually get better MPG on premium...
  9. Easy Rider 2
    1,584
    258
    Ocala, FL
    I assume it has one but don't know for sure. Even if it does that is only half of the equation.
    The other part is the max. timing advance allowed.
    Anyway, spark knock and compression knock are two different things; same result, just different causes.
    NONE of the Prius engines and probably none of the Toyota engines in general can properly be considered "high compression".
    If there really was anything practical to be gained by using a higher octane fuel, Toyota would be shouting it from the rooftops.
  10. cyclopathic
    3,292
    547
    2014 Prius c
    "C" has 1:13.4. Highest of non-diesel sold in US
  11. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    I am not an expert on engines, but I've never heard anyone here say that the c is able to get better MPG with Premium due to the higher octane.
    I do think the energy content of gasolines can vary (eg; E0 vs. E10), and my understanding is when EPA does MPG testing they correct for energy content before reporting MPG to the public.
  12. cyclopathic
    3,292
    547
    2014 Prius c
    Not sure if EPA does such thing. I remember reading Chevron bolster about big 3 trucking their gas across several states to Detroit for EPA tests. That was many-many years ago; thing change over time.
    From what I see so far "C" MPG is worse than Gen3, but there's too many factors to call it. I'll test 87 vs premium after break in. Since our gas is E10 across the board, E content will not be a factor.
    #72 cyclopathic, Feb 2, 2015
  13. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    It's also same energy content, if not a little less for the Premium here, so it'll be an octane test for sure.
    Just remember the summer fuels change comes in and changes things a little. Try to do your test before or after that change.
  14. cyclopathic
    3,292
    547
    2014 Prius c
    That another factor. How much of what fuel in the fuel? with the switch to summer fuel staged btw March a d June 1st...
    Looks like the best time to check is in Feb and August. But my "C" is still too green. Plus in general C seems to be more sensitive to temperature, so Feb might be the best time
  15. GregP507
    GregP507 Senior Member
    3,002
    481
    According to one car-expert in a documentary on gasolines, knock-sensors make using Premium gasoline unnecessary in most cars which specify using it.
  16. Easy Rider 2
    1,584
    258
    Ocala, FL
    Unnecessary maybe but that's different than "undesirable".
    In a car designed to use higher octane fuel, you are almost always better off to do that.
    If you drive hard, more power.
    If you drive easy, more mileage.
  17. GregP507
    3,002
    481
    Opinion_noted.
  18. mahout
    mahout Active Member
    655
    116
    NC
    generally that is true, however, we are finding 91 octane gas typically has less contamination with ethanol and less energy components so 91 can give better mpg. it has nothing to do with octane rating as it is the result of recipes that have more energy. we've had the opportunity to test both non ethanol vs ethanol up to 10% and the diff about 5 mpg in favor on non ethanol mid grade gas. its faster on track too, adding 2-3 mph at ends of long straights. the recipes for gas, which generally has a multitude of compounds, will yield different mpg from the same pump week vs week. no, not in same day generally, just after another delivery.
  19. mahout
    655
    116
    NC
    take it from a crowd with vettes, jags, vipers and such, those knock sensors are absolutely necessary. gas varies that much. that is an expert opinion from a vehicle and petroleum engineer.
  20. mahout
    655
    116
    NC
    you can rest assured that 91 octane will not be cost efficient on any engines designed to run on 87 octane gas though sometimes 91 will yield better mpg and power. its never enough to pay for the extra cost of gas.
    engines with high compression ratios that require higher octane should use the 91 octane stuff and not depend on knock sensors to dial back the spark advance enough. it used to be pretty consistent that CR's over 9.5:1 required 91 octane but many of todays engines withspecially designed combustion chamber will tolerate octanes of 87 above 10:1. mazdais a good example with skyactive designes and computer trickery.
