Convert cig lighter to DC plugs
Discussion in 'Generation 1 Prius Discussion' started by primuspaul, Feb 8, 2015.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I am tired of the cig lighter plugs popping out all the time so I would like to convert my car's 12V cig lighter system to a DC plug connection system to power 5 devices:
    Device 1: Cellphone powered by: micro USB (5 volts I assume). I imagine the cellphone uses 1 AMP, 5V
    Device 2: Latitude Laptop Currently powered by: Car Power Charger Adapter for Dell Latitude D400 D505 D510 D631 E5400 E6410 | eBay , 19.5V, 4.62 Amps
    Device 3: Mini Hi Fi Audio Stereo Amplifier 12V Amp for Motorcycle Boat Home Car US Stock | eBay , Currently powered by: DC12V Car Cigarette Lighter Socket Auto Power Supply Cord 5.5mm Adapter Charger (it's 12v so no power conversion). 12V, 6A
    Device 4: Currently powered by: CA-570 S, 8.4V 1.5A
    Device 5: RoadMate 1700 powered by: Vehicle Power Adapter , 5V, 1A I think
    Note: the cellphone USB conversion device should one which transfers the power in a way that prevents the ground loop.
    I picked the following parts:
    Power Conversion:
    1. DC DC 10 24V to 5V 1 5A Step Down Isolated Power Supply USB Charging Converters | eBay - $11.99
    2. 60W 5A 4 32V 12V 24V to 1 25 20V 19V Step Up Step Down DC Converter Regulator | eBay - $12.95
    3. No converter necessary, 12V. - $0.00
    4. 1 DC DC Buck Converter Step Down Module LM2596 Power Supply Output 1 23V 30V | eBay - $2.31
    5. New Waterproof DC Converter 12V Step Down to 5V 3A 15W Power Supply Module | eBay - $2.71
    DC plugs:
    1. Some $1.00 micro USB cable. Just connect Red to + and Black to GND, right?
    The rest: do I just get a $5 universal DC plug set? Then I just solder some wires to the plug, back to one side of the power convertors, and solder wires from a disassembled cig lighter plug to the other side of the power convertors?
    Universal Tool Notebook DC Power Adapter Socket Plug Connector New | eBay - $5.39
    10x DC Power Male Jack Connector CCTV Security Camera DC Jack Pigtail 5 5 2 1 Mm | eBay - $5.99
    I already have 50ft of High Voltage Cable 24KV (20KV) for any wiring/soldering I need to do.
    #1 primuspaul, Feb 8, 2015
    bwilson4web likes this.
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    If it's the same as in the current Prius the lighter circuit has a 10A fuse, so make sure you don't exceed this by connecting too many devices at the same time.
  3. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Really? The current Prius has such low specs? Mine has a 15A fuse in there for the cig lighter:
    28. CIG 15 A: Power outlet
    The system appears to work fine continuously with all devices on at the same time.
  4. ChapmanF
    18,249
    That would be quite an unusual choice for wiring circuits that are all between five and twenty volts. It's important to choose your material so the wire gauge is appropriate for the current you'll be carrying, the insulation is suitable for the intended voltages, and the stuff is easy to work with. You don't gain anything just by using wire engineered for voltages a thousand times higher, and it might be more fiddly to work with.
    As ftl points out, the lighter socket is already fused at ten amps. That can give you two kinds of problem: (1) ten amps might be lower than the total of all the loads you want to attach, and (2) ten amps might be higher than the safe current-carrying capacity of some of the wiring to your smaller loads, presenting a fire hazard if that wiring gets pinched or damaged. (Usually, skinny-wired accessories that end in a cig lighter plug will include a smaller fuse built into the plug to further limit fault currents to what the wire can handle.)
    An option you might consider would be a small distribution panel straight off the aux battery at the left side of the trunk. It's easy to buy tidy panels providing several separately-fused circuits, allowing you to fuse each one appropriately for the load it will be serving. This thread may give you some ideas; now that I know about the VCM-06, I would recommend it over the homebrew control circuit I used.
    -Chap
    ftl likes this.
  5. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    As far as power consumption is concerned, 15A at 12V is equal to 36A at 5V. The above project is a mess...
    Avi
  6. Avi's Advanced Automotive
    776
    363
    My suggestion:
    Get this Adapter and this cable.
    Plug the adapter into one of your two power outlets and your 12V device into the other.
    Read more here.
    Avi
  7. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I am certain the lighter socket is fused at 15 amps so I don't understand what you mean. The manual says to use a 15A fuse there and that's the fuse that is there. I checked.
    Okay, so based on the responses, I think it would be better to just take the existing 12V cig lighter adapters and just solder wires to the connectors and connect those to a single cig lighter plug and somehow attach that firmly into the cig lighter plug. Or do the soldering and then just wire the entire setup directly to the 12V battery to avoid frying the car's internal 12V wiring system (which probably won't happen unless you do something like put a 20+ amp fuse into the cig lighter fuse port).
    Can I safely just solder all of the side connections together, all of the center spring connections together, and wire each one to one point on a single plug?
    #7 primuspaul, Feb 8, 2015
  8. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Unfortunately, USB specifications only allow for 1A current. 3 of my 5 devices are above that and don't even have USB power input. Of the remaining two devices, only one is designed to be run using power from a 12v cable, the other can only charge from it (appears to only run when plugged in via the DC connector).
    I have a way of running the devices right now, but the cig lighters just don't reliably stay plugged in.
  9. fuzzy1
    10,481
    Device 1: 1 AMP, 5V => 5W
    Device 2: 19.5V, 4.62 Amps => 90.1W
    Device 3: 12V, 6A => 72W
    Device 4: 8.4V 1.5A => 12.6W
    Device 5: 5V, 1A => 5W
    Total device power (excluding converter & inverter inefficiencies): 185 watts.
    This circuit is overloaded.
    Those 12V sockets are really intended for no more than 120 watts, though some devices appear to get away with 180-200 watts, at least for a while. Your devices are unlikely to all be pulling max power simultaneously and continuously, so you can get away with it for quite a while.
    But at some point, the 15A fuse is likely to fail, due to too much use without adequate operating margin below its rated trip point. Can you hardwire a separate circuit, wired for and fused to 20 amps, and using more reliable connectors such as the Anderson connectors favored by the amateur radio folks?
  10. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I see what you're saying regarding the wattage. 185/12 = 15.42, which is above the 15A fuse on that line. I can do what I outlined in the uploaded image above, just wire it directly to the 12V battery. I can glue together the cig lighter chargers from the 4 devices by their large plastic enclosures. Then I can solder and insulate (with rubber) the chargers using a piece of wire at the negative side terminals, and with another wire at the positive center point terminals. Then I'll just solder the negative and positive wires to two longer wires and wrap+bolt those onto the 12V in the trunk. I assume this won't damage the car, correct?
  11. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I also had another question regarding the 12V cig lighter wiring. If the amount of power drawn exceeds what the wiring system can provide, it just means the fuse will blow, right? The wires won't melt as long as I don't put a higher-than-specified fuse in there, correct?
  12. fuzzy1
    10,481
    Gluing the enclosures together and soldering to the contacts sounds like a dirty kludge, and won't let you change out devices easily.
    Can the Roadmate 1700 be powered over USB, such as using a regular USB cord to your computer? If so, ditch its car adapter, and power it from the same 12V->USB adapter as the phone. Multi-outlet devices such as Avi pointed to are readily available providing 2, 3, or 4 USB outlets in a single 12V socket. Or use something like this USB converter ( DC DC Converter Module 12V to 5V Duble USB Output Power Adapter 3A 15W | eBay ) to skip the socket and wire direct to 12V.
    Then, you are down to needing just two or three 12V sockets/converters and one or two direct connections. Something of this sort (Enercell 12VDC 3-Outlet Vehicle Power Adapter : Adapters | RadioShack.com) with provide the sockets and inline fuse holder to the battery (or Accessory 12V tap somewhere, to prevent draining the battery), though I don't see the current rating on this particular model.
    I'm still browsing for other ideas on the 19.5 and 8.4V supplies. Pre-packaged devices wiring directly to 12V, skipping the socket, would be best. For converter devices with a wire between the plug and device body, just cut off the plug.
    I don't endorse any specific products. The links above are to show the concepts, many similar products of varying quality exist.
    #12 fuzzy1, Feb 9, 2015
  13. ChapmanF
    18,249
    If Toyota puts a 15 amp fuse on a circuit, that means all the wires Toyota supplied in the circuit have been sized to safely handle 15 amps. In case of an overload or short, the fuse will blow before those wires melt or ignite anything.
    If you plug some gizmo of yours into that socket, and the gizmo's wiring cannot safely handle 15 amps, and that wiring becomes damaged/pinched in the seat rail/whatever, the 15 amp fuse might not blow before your wiring melts or ignites something. If you attach anything to a circuit that would not safely handle the maximum that circuit can deliver, it's up to you to supply a smaller fuse that will protect what you have attached. If you look at a lot of cig lighter powered accessories, you'll find there is usually a fuse contained in the lighter plug, small enough to protect the (often very skinny) accessory cord. If you're thinking of cutting off the fused lighter plugs and soldering wires together, including properly-sized fuses becomes your responsibility.
    In other words, you can't only think about how much current the gizmo is intended to draw. Maybe it's only meant to draw half an amp, which means its cord might have really skinny wires that might only be safe for carrying an amp. The cig lighter plug on the end of that cord probably has a 1/2 or 1 amp fuse in it, so the skinny cord will be protected from unsafe currents even if some damage to the wiring or fault in the gizmo makes it draw more current than it was meant to. If you remove that plug and fuse and connect that skinny wiring to a circuit whose only fuse blows at 15 amps, you've asking for trouble.
    You're really asking for trouble if you wire stuff directly to the battery without proper fusing. Nothing will stop that battery (even a dinky Prius battery) from delivering hundreds of amps into that wiring if a fault develops.
    The other reason to be careful about attaching stuff to the battery directly is not so much a fire safety issue, but it could inconvenience you by draining the battery. The Prius battery doesn't store very much energy, so if any of your permanently connected gizmos draw any current while the car is off, you could find the battery drained when you come back. You might want to connect your stuff so it disconnects when the car is off. There's a product, the VCM-06, that's great for that purpose: it can tell when the car is in READY (voltage goes above 13) and turn on, and automatically turn off when the car is turned off.
    The VCM-06 also contains its own, fuseless, self-resetting, current limit to 15 amps. If you are connecting loads with lower safe currents then it's still up to you to supply the smaller fuses they need. If you need to draw more than 15 amps, you can add a relay and use the VCM-06 to control it.
    The link I supplied earlier can give some ideas on how this can be set up.
    -Chap
  14. Avi's Advanced Automotive
    776
    363
    The USB adapter is rated at 2.4A per port, the actual current flow will be determined by what you plug into it, including the type of cable. That is just the maximum it can provide. But, as fuzzy1 pointed out, the circuit would be overloaded.
  15. Avi's Advanced Automotive
    776
    363
    This would work in theory. I would be concerned about the springs that push the tips out not having enough tension on them causing a poor connection inside the adapter.
    fuzzy1 likes this.
  16. Avi's Advanced Automotive
    776
    363
    ...and I just realized this is in the Gen I forum and Gen Is only have one outlet.
  17. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    The devices are more or less permanent.
    It does not power on with this set up. It has to be via the DC connector --> cig lighter.
    The USB-powered device (just one) is not the problem. USB stays in reliably.
    I use these already. The goal is to get away from the bulky 12V cig lighter connectors.
    They are unusual power ratings so the only devices that do the conversions out of the box are the car charges I mentioned and I've almost never seen them have the converting circuitry in a way that can be "cut" such as the case in common AC adapters for the same electronics.
  18. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I'm only concerned about the Toyota wiring. I don't want to have to rip the car apart to replace those wires. My wires are external and easily replaced.
    What I was planning on doing was putting a on/off switch on one of those wires leading directly from the battery. However, I doubt it's necessary since I don't think my electronics can realistically even reach 180 watts (15 amps at 12v). If they ever do, I'll just blow the 15A fuse (happened a while ago after I used a cheap chinese cig lighter socket multiplier which apparently had a short), replace it and disable a device until I have time to wire directly to the 12v.
  19. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Anyway, looks like all the equipment I need is:
    New Auto Car Charger for Canon M32 M31 M30 M300 HF21 S21 S20 S200 S11 CA 570 | eBay
    Car Charger for Magellan Maestro 5310 Roadmate 1700 1700 MU 1700LM GPS Receiver | eBay
    I can just rip apart the plastic housings to avoid the "spring" issues mentioned above and solder those to the positive/negative points on a good cig lighter plug. The total comes in at a few pennies less than the original idea I posted, just under $30.
    So the only issues remaining:
    1. I need a reliably-built cig lighter plug with a 14-15 Amp fuse (or I can buy the fuse separately if necessary) with wires on the other end I can wire to terminals for the rest of my assembly.
    2. There is still the issue with the cellphone ground loop. Can I just get this: DC DC 10 24V to 5V 1 5A Step Down Isolated Power Supply USB Charging Converters | eBay
    and wire that to just the + and GND connectors on a disassembled micro USB wire and the other end to my main cig plug's 12V connector terminals?
  20. ChapmanF
    18,249
    ... if the biggest risk of an improperly fused electrical circuit were just maybe having to replace the wire, insurance would be dirt cheap ....
    -Chap
