no traction in snow
Discussion in 'Prius v Main Forum' started by Bsver, Feb 16, 2015.
  1. Bsver
    Bsver Junior Member
    I have never had this experience in 33 years of car ownership and driving in snow. Have a 2012 v and absolutely no traction in snow. Got stuck in my flat driveway, on 1" of snow in parking lot, up a hill that required pushing all the way up the hill by two people. Is there any way to disengage the TRAC system? There is no moment in which the car bites into the snow and moves. It basically just rocks (too strong a word, because there is no movement) in place with the TRAC light on. I basically can't drive it. Any thoughts? I looked at some videos posted in the gen 3 forum and the car looks like it pulses and moves a bit at a time. No such experience with mine.
  2. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I don't have a v, but I took my Persona the other day into an empty parking lot to test the stock tires and on purpose stopped at a weird angle on the kinda steep entry way that had a fresh couple inches expecting to just stay stuck and have to back out. I was very pleasantly surprised that yeah traction control obviously kicked in but it climbed right up the grade without any fuss kinda like my old Subies used to…
    I then messed around and couldn't get the car to spin out as the stability control works real good…
    We are expecting 4''-8", tonight into tomm so if we get the 8'' my opinion might change as I have to travel a little for work tomm but its on a major highway (not my normal commute). We shall see..
    Bsver, if you live in the snow belt or anywhere where you get more than a few coatings you might want to consider some good snow tires...
  3. Mendel Leisk
    41,820
    What tires, how much tread depth left?
  4. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    X-Ice Xi3 Michelin's Was the answer to ice and snow for me ,,, but if there is a solid 6 inches
    Or more , wait till some one makes tracks ahead of you ,,,,
  5. Mendel Leisk
    41,820
    An in-a-pinch solution, for just getting up an icy ramp, is to turn steering hard over to one side, go a foot or two, then switch to the other side. You're effectively turning your route into a series of (less steep) switchbacks.
    Blizzard_Persona likes this.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Unfortunately, Toyota has decided that they won't give you the ability to spin a wheel and burn out the hybrid system. So, no traction means no go. But as others have posted, tires might be your real issue. But in any case, momentum is your friend.
  7. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    People have posted routines to turn off TRAC on the 2012-14 Prius v but I've tried them and none have worked. Toyota has apparently finally admitted that it is a problem since a TRAC OFF button has been added to the Prius v for the 2015 model year as one was added to the Lexus CT200h, which has the same drivetrain, a year or two ago.
    Our Prius v hasn't been driven much in winter but got stuck at the end of last winter. Until then we had been debating whether or not to buy winter tires for it but have since bought a set of four Bridgestone Blizzak WS70, four 16" steel wheels, four TPM sensors and an ATEQ TPM Quickset tool for reprogramming the ECU in our cars when we do the winter/summer switchover.
    Even with winter tires, I suspect our Prius v will occasionally get stuck. There is no substitute for turning TRAC off in deep snow.
  8. mahout
    mahout Active Member
    655
    116
    NC
    traction in snow is completely dependent on the tires and limited slip differential. if you don't have a snow tires recommended by consumer reports, who actually test them, you will be dependent on whatever tires are on your prius. if you don't have a limited slip differential, and prius don't, you are dependent on both tires having equal traction. if one doesn't, you will merely get one wheel spinning and the other just looking at you. trac may try to act like an LSD but its not quite the same. in your case the problem is most likely well worn summer, LRR, or all season tires. especially LRR, well worn or not.
  9. Offline
    646
    240
    Lenexa, Kansas
    You could have the best x-ice or Blizzak winter tires and they won't help you rock your vehicle out of a snow drift or get you going in deep snow if can't turn traction control off. I must have had to turn TRAC off and 100+ times while driving 25 miles home in fresh unplowed 12 inches of snow in my RWD Lexus V8 sedan equipped with nearly new Blizzak WS70 tires. It should have been a 10 mile drive but I had to search for streets that weren't blocked by abandoned vehicles including countless abandoned 4WD SUV's.
    Our 2012 Prius v is the first Toyota/Lexus we've owned where TRAC could not be turned off. It is disappointing but we are fortunate that our Prius is not used much in winter and it is good to see that Toyota has added a TRAC off button to the 2015 Prius v and to other Toyota hybrid vehicles that have the same drivetrain.
  10. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    No "traction control off" button on the 2015 Persona liftback though.....:(
  11. bisco
    52,274
    i've been driving in snow all winter with oem tyres and zero traction issues. perhaps you should have it looked at? i mean, one inch of snow in a flat parking lot?
    Bob-blehead and Blizzard_Persona like this.
  12. flynz4
    flynz4 Member
    332
    Portland, OR
    2015 Prius v wagon
    I've been driving a '06 Prius for the past 9 years and have always had studded snow tires in the winter. I drive over the Oregon coastal range about every other weekend all winter... and while we do not get a lot of snow, black ice is not uncommon. I've never gotten stuck, and I've never had to put on the chains.
    When driving over the Cascade range... I generally take the Jeep since it is much higher and snow is common in the winter (but not this winter).
    /Jim
  13. Zrkia
    Zrkia Junior Member
    17
    Michigan
    As others have said, tires are probably your problem. I have driven my v for three michigan winters with General Altimax Arctic winter tires and it goes as well as my Jeep Patriot did in snow. Never had a problem in deep snow, and rarely even turn on the TC or ABS lights.
    Bob-blehead likes this.
  14. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Hasn't been an issue; we use Dunlop Winter Sport M3 tires.
  15. rspeaker
    rspeaker Junior Member
    Colorado
    Can't explain it... Had an issue backing into the driveway a few nights ago with 1/2" of snow, but today pulled through 2"+ of snow and slush no problem.
    I guess if the car is moving forward, traction isn't an issue.
  16. rjparker
    10,405
    6,519
    You can turn off the traction control; however, it is convoluted to say the least. I tried it tonight on my Prius v and it worked. After trying it once, I shutdown and did it again in about 10 seconds.
    To disable traction control on the Prius:
    1. Parking Brake On
    2. Turn the car to ignition by pressing START twice without pressing the brake.
    3. Floor the gas pedal two times (two full top to bottom pressings)
    4. Make sure the parking brake is on, and while pressing the brake pedal put the car into NEUTRAL
    5. Again press the gas pedal two times
    6. Push PARK and press the gas pedal two more times
    7. Now put your foot on the BRAKE and press START one time while holding the brake down.
    #16 rjparker, Feb 17, 2015
  17. J L
    J L Junior Member
    30
    Northern VA
    2013 Prius v wagon
    I'm on the stock Bridgestone Turanza tires, otherwise the most unrefined and uncomfortable tires I have driven on, and I'm getting through snow just fine.
  18. bisco
    52,274
    and you guys got some snow, from what i hear!:cool:
  19. Air_Boss
    4,218
    1,188
    New Yawk
    Convoluted doesn't begin to describe it. Or you could use proper winter tires...
  20. fuzzy1
    10,583
    Please, please, Bsver, answer this question. At 3-ish years old, I suspect your OEM tires are now garbage in snow compared to what they could do when new, which even then wasn't comparable to real winter tires. I know mine were, both on my first Prius (2010,), and on my current Prius (2012). The later set is now questionable even in ordinary Puget Sound area rain.
