'14 Prius Stereo Wire Colors
Discussion in 'Gen 3 Prius Audio and Electronics' started by kenniekenken, Feb 21, 2015.
  1. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Hi everyone! Was wondering if someone can lead on the stereo wire colors for a '14 Base Prius so I can tap my Scosche Line Out Converter for a Sub/Amp addition. Thanks in advance!
    kc5dlo likes this.
  2. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    From the back of a Metra 70-1761 Radio Wiring Harness Toyota 87-up Power 4 Speaker. Not the best focus, but hopefully enough to see the wire colors.
  3. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Thank you for the info. What I need though are the colors coming from the HU itself if I'm making sense? I've seen a couple sites but there are differences in the colors so am looking something more accurate.
  4. aponteluis
    aponteluis Junior Member
    United States
    Attached are the radio head unit wire color / connector pinout for the 2014 non-JBL Prius. I installed a subwoofer this weekend and can validate they are correct.
    kc5dlo and frodoz737 like this.
  5. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    That's awesome! Thanks apontelius!
  6. aponteluis
    United States
    Here is an additional one with more info.
  7. frodoz737
    frodoz737 Top Wrench
    4,781
    2,547
    33
    Interesting it's the same as the 2010 base.
  8. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    sorry, misspelled... thanks again aponteluis! can't wait for the weather to get better...
    kc5dlo and aponteluis like this.
  9. Koaokamoo
    Koaokamoo New Member
    Maui
    What did you use to turn the amp on and off? I mean which wire on the Prius did you use to control the power on off for the amp?
