First time for everything - Traction Control let me down BIG TIME
Discussion in 'Gen 2 Prius Main Forum' started by gak27, Feb 23, 2015.
  1. gak27
    gak27 Prius, Take Two
    117
    Akron, OH
    '08, owned since new. Good tread remaining on Goodyear Tripletreds.
    Drove from Akron to Pittsburgh this weekend on Saturday morning. Lots of fine-grained snow, roads getting worse as we got closer to Pittsburgh, but no trouble maintaining 50 or so on the turnpike.
    5 miles from our destination, driving on 2 lanes in each direction main road, slushy/snowy w/ occasional glimpses of pavement. Long uphill. We were doing fine when we had to slow down and switch lanes. And just like that, no traction, no wheel spin, no chance to get any momentum. No matter what I tried, I couldn't go more than 6-7 miles per hour. Took 10 minutes to work up the remainder of the hill, flashers on.
    Happened again trying to go up the snow-covered but passable road to my parents house later in the day.
    As has been mentioned many times here, the traction control is dangerous. Let me spin my wheels and stand a chance of regaining control. I could have walked up the hill faster...and safer.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    That's when debating the capabilities of The Prius as an extreme weather or winter/snow vehicle I always have to say, I simply don't define it as being very good.
    Good/Great snow tires I think are a must. And even then you are hoping you just break even with winter capabilities.
    PriusGuy32 likes this.
  3. Mendel Leisk
    41,580
    Second gen traction control came on sooner I think, too soon maybe? Still, OP: you describe everything but the tires you're running, and remaining tread depth.
  4. gak27
    117
    Akron, OH
    I indicated I have Goodyear Tripletreds, unsure of the remaining tread but definitely not close to worn.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    That is funny.. we drove 135mi/7hr in Mid-Atlatic on Sat with all snow, sleet, rain, etc and the traction on "C" was a big help. Only got stuck ones on uphill, in Baltimore, b/c some yahoo decided to walk in the middle of the street. When was asked to step off the road she stood in the middle with middle finger above her blond head proclaiming street to be her property. Unfortunately hill was too steep to start no traction just wheel spin.
    Otherwise there were alot of cars spinning as sliding around, but our Prius C was just fine. There was not enough clearance in some spots, but it did great for what it is. Now leaving chains and shovel home was completely stupid.
  6. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    For what its worth; I have 195/65-15 Yokohama[​IMG] AVID Ascend tires on my 2010 Prius 11. I have about 5,000 miles in them. Last two days its been raining constantly. I can not make these tires lose traction on our wet roads. Last night we got 1/2 inch of sleet and freezing rain so I took it out to see how it did in those conditions. Had no trouble at all and was going the speed limit most of the time. No problem stoping or starting at all. The first 55 years of my life I lived in Erie, Pa so I'm used to driving in extreme conditions with all season tires.
    Read more: Low Rolling Resistance replacement tires: Current List | Page 15 | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  7. bisco
    52,037
    are the triple treads snow tyres? how many miles on them?
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    TripleTreds are all season tires, with treads that make them very good in the rain, based on past experience.
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    Studs work in the op's situation, night and day difference
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    "Long uphill" in Pittsburgh could translate as "mountain". Driving in western PA in the snow can be an adventure. I've had my share over the years and prefer to just not go.
    Would you really prefer a spinning wheel and the possibility of burning out a motor?
  11. fuzzy1
    10,510
    Those are All-Season tires, not Winter tires. My experience with other AS tires is that they all became useless in winter (for my purposes at least), and had to be banished to 3-season use long before the tread appeared worn.
    Again, how much tread depth is left? I didn't have a real tread gauge until recently, but am guessing that my past 'winter retirement' point was around 6/32nds. Now, I use real winter tires on the primary winter travel car.
    #11 fuzzy1, Feb 23, 2015
  12. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Should've pulled off the road and disabled the TC!
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I disagree.
    Do really want to come to a complete stop partway up a slippery hill?
    Tire spinning is overrated.
  14. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Unless you are Driving a rwd Charger rt (Like I did Last Winter) in a blizzard…:eek:
    Then Tire spinning down to the Pavement is occasionally a must…:D
    Still got home without issue…..(y)
  15. PriusGuy32
    1,417
    514
    Gak27- I printed out these instructions, and left them in my glovebox, along with the directions on resetting the maintenance light & resetting the reverse beep, lol.
    Disabling TC on the Prius:
    These steps must be completed within 60 seconds.
    Step 1: Set the ignition switch to ON, not READY. To do this press the power button two times, without pressing the brake pedal.
    Step 2:
    While the transmission is still in park (P), fully press the gas pedal two times.
    Step 3: Apply the parking brake to ensure that the vehicle will not move during this step. Put the transmission in neutral (N) and fully press the gas pedal two times.
    Step 4: Put the transmission back in park (P) and fully press the gas pedal two times. The car will display “!Car!” in the upper left corner of the LCD screen.
    Step 5: Press the brake pedal and turn the ignition switch to the start position, without going back to the ready position, to start the engine.
    If these steps are followed correctly, the vehicle will start with the traction control system defeated.
    CSS makes a good point, one that I didnt consider - about not stopping going UP the hill to turn off your traction control. My point I was trying to make was, if you are already almost stopped going up a grade because the TC is disabling forward movement of the Prius, then I dont see much hazard in pulling off the road and disabling TC. It is not something you can do while in a busy lane of traffic, however.
  16. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Hmm, I haven't run into that. I wonder if it was the snow that day. Snow can vary a lot in how much traction it provides. Some snow offers nice grip. Other snow is so greasy it makes it impossible to get anywhere.
    I find the TC does permit a little wheel spin without activating. I noticed it recently when rolling too slow at our driveway exit, where it's a bit uphill and the sand is pretty soft. I gave it a little pedal and the front of the car started heaving up and down as it scooped sand backwards with the tires. It was moving slowly forward but I figured it was digging too much, so I reversed and got another run at it, but the TC never activated (no light, no power cut). I notice in the snow it'll let the tires squirm some without activating. I can get it to activate if I really try, but otherwise, it seldom does. I have a light foot though.
    #16 tanglefoot, Feb 24, 2015
    lar.smith42 likes this.
  17. *Goldfinger*
    *Goldfinger* Junior Member
    Sheffield, England
    Interesting post, I wasn't aware it was possible to disable TC. Doesn't it need to be on, and is so sensitive, in order to protect the motors though? Could they be damaged with it off?
  18. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Traction control is mostly protecting drive chain and components after it. MG2 is huge flywheel that is directly connected to drive chain that is directly connected to wheels. Maybe you could break something if you would get wheels to spin very fast and then suddenly have good traction. But I don’t think that I have heard anybody having this short failure.
  19. PriusGuy32
    1,417
    514
    Here's the skinny on that....
    For years I read on the site that disabling the traction control would cause Utter total prius devastation and e-cvt transmission self-destruction. Until I tried it. And read several other accounts on the website of people doing the same with no ill effect. I've now been doing it for years. And I think it's safe to say, that after selling my last Prius with 97,000 miles, it's not as dangerous as is said. My cvt fluid was clean when I drained and refilled it at 89,000 miles too!
    If you do a simple search for disabling traction control on Prius chat, you'll see what I mean. Not one single person has ever experienced a failure while disabling traction control That you will find. The key to doing this safely and making sure you don't create a problem, is not letting the wheels spin at a very high speed and then suddenly gripping dry pavement – this could be the end to any transmission, but it has been theorized here that the Prius e-cvt is even less tolerable. Either way I am pretty much willing to bet my firstborn child that disabling traction control to get up a hill or get unstuck or prevent from getting stuck, will never cause a problem so as long as you don't abuse it. We just had 16" of snow in one day here and even with my Michelin x-ice snow tires, I couldn't get out of my driveway. Disabled traction control, and my Prius was better than a jeep four-wheel-drive in the snow!! (Well almost) :D
    *Goldfinger* likes this.
  20. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Here's my PSA:
    Excess wheel spinning in any car can damage the differential or differential gears in a transaxle (particularly with an open differential).
