4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. Tideland Prius
    16,539
    Give this man a prize.
    Toyota's goal is to reduce the cost so that the "premium" the customer pay is as little as "possible" (in quotes because Toyota still wants to make a profit).
    It is a pity that there's so much emphasis on EV range that total efficient is neglected.
    I get the high of driving in EV. I want my next car to be a PHV with good range but I'm pragmatic enough to know that an efficient engine and a large battery cost money. The bigger the battery and more efficient the motor, the less money there is to spend elsewhere (like an advanced ICE). So you either take BMW's route and go all the way down to a tiny engine and tiny gas tank or you lose efficiency and take GM's path (though credit where credit is due, the Volt 2.0 is impressive).
    Because the Prius PHV is based on a Prius, it already has the inherent cost of a Prius, compared to a dedicated platform like the Volt.
    The Prius PHV vs. Volt is like the Prius vs. Civic Hybrid all over again. The dedicated platform is more flexible for the manufacturer because it's not tied down. (Civic Hybrid tied to the Civic, Prius PHV tied to the Prius).
    The only way Toyota can effectively compete with the Volt is if the Prius PHV is a completely different vehicle - different exterior design, interior design, specifications and so forth (ok not completely different but more than what it is now)
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    It is interesting to see how Gen4 discussion sways off the subject into side discussions.. yes Plug-in and EV range is important.
    So is the ICE, and its thermal efficiency. A few /not really new/ news on ICE:
    Toyota's massive engine overhaul
    does this mean that new Prius will finally have DI?
  3. cyclopathic
    3,292
    547
    2014 Prius c
    Passo press release:
    Toyota launches new Passo hatchback in Japan [w/video]
  4. cyclopathic
    3,292
    547
    2014 Prius c
    this probably deserves separate thread:
    Toyota develops high-efficiency ‘free piston’ no-crankshaft combustion engine… to power an EV | ExtremeTech
    Something like this (2cyl 30hp) would be a good range extender for series hybrid/EV. Just take fuel cell of Mirai, increase battery pack, stick one of these and you have it
    #3804 cyclopathic, Feb 24, 2015
    NR427 likes this.
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Use as EV when commuting to work (PiP)? Not when I get on the freeway which is everyday driving to work.
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The PiP has been out for nearly 3 years. I called Piercey Toyota parts for the second time yesterday and asked, what is the retail price for the Li Ion traction battery? The answer - $10,000. The same answer I was told a year ago. $10,000 with core credit. How much are people planning to spend to replace their traction battery?
    The service advisor told me she replaced her GenI battery and the job was about $3,200, replaced at 218,000 miles.
    What is the range degradation on a PiP traction battery? How many EV miles will it be providing after 8 or 10 years? If one plans to replace the LiIon, how much do they expect to pay or will they just deal with it when the time comes? Will these PiPs have much resale value when car is 10 years old?
    All these questions could be asked about Volt, other plug ins. Maybe these very expensive batteries will last a very long time (15 years, 200k+ miles) I don't know.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I don't think the Toyota CEO should step down. Word is he's had the vision of making more attractive cars (i.e. tasteful materials in the '15 Camrys, unlike uber boring and dorky materials in the 2014.5- Camrys. Now they need to work on fit inside the cabin).
  8. inferno
    inferno Senior Member
    1,072
    405
    Well I for one benefited in a used PiP which was $19k 2012 bought in 2014. I'll get no credits of course, but it was $4k less or so than a new low-end Prius package and about $11k+ lower than when it was new. So there is a resale value for sure, but not as much as people would hope. I guess I could have gotten a $19k 2013 mid-package Prius (which I saw as a possibility)...
    However, right now I have 9.8 miles EV in the winter. It started off at 11 and went down. I of course expect it to go right back up in the spring, and btw, this February had been nasty.
    According to my spreadsheets. We drive the PiP (wife and I) at an average of 45 mpg in hybrid mode. We also both drive (but much less) a Prius 2010, and it's getting 38 mpg. I am certain that the PiP has more mpgs but also can 'cheat' mpgs if it has a full battery. So it's already becoming and interesting test...
  9. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    That must be a mistake. I would check with another dealer.
    As for how long it will last, Toyota treats the batteries very kindly, not allowing it to get close to 0% or too full, so I would expect the battery to last at least 10 if not 15 years.
    I don't know the specifics of the batteries Toyota uses, however, it is pretty easy in a PHEV to treat the batteries very kindly.
    The battery pack for the Leaf is $6500. Considering the much larger size I can't see how Toyota gets away with $10,000 unless it is simply another manufactured reason for them to dismiss electric vehicles.
  10. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    MSRP = Manufacturer Suggested Retail Price
    Who actually ever pays that much? Back when I worked retail, that value was an absurd thing to even bother referencing. Yet, our signs always included it next to the actual price.
    Let's try to be realistic. No one is going to have to deal with that price. For that matter, we still have a minimum of 5 years before anyone would even be faced with that decision,
  11. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Fascinating. How many people still think the PIP is an EV. It is not. It is a hybrid that can EV for a short distance. The standard Prius can only EV in "limp mode", no speed, no power.
    Technology does march on, but we're not there yet. Unless you are stubborn enough to insist on EV at any cost! Hope you can afford a $100,000 car! ;)
    And here in Edmonton, lots of luck. An EV doesn't work too well where there is winter. Which is why just about all manufacturers don't offer them here.
    cyclopathic likes this.
  12. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It is going to be interesting to see how long these PHEV batteries last. Superficially, it seems like the 4.4 kwh battery in the PiP would have to really deteriorate before it reaches the point of no longer being able to support hybrid driving
    Even if its rechargable EV miles were to drop down to 5-6 miles after 15 years to the point where people stop bothering to plug it in it would still be at least as capable as a new regular Prius battery.
    markabele likes this.
  13. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    $10,000 battery cost is about 1/3 of the total vehicles price! Can't say that about any current ICE vehicles...
  14. inferno
    1,072
    405
    except here in Mass we are offered quite a bit (maybe second to california) in terms of EV options. Ford Fusion Energi, Leaf, PiP, even Tesla...
    And it's interesting. The cold does effect the battery but I think it rebounds back, whereas severe effects the battery negatively without rebounding.
  15. 70AARCUDA
    845
    209
    Tucson, AZ
    Something seems to be missing here...what word did you inadvertently omit?
  16. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Heat most likely, which adds another layer of EV concern for those of us in the desert. Tesla's cooling apparatus seems to allay any such fears...Nissan's? Not so much.
    It was interesting to read above that the traction battery on a Gen1 Prius in apparently northern CA "only" made it to 218,000 miles. What happened to the other almost 300,000 those Canadian taxis are achieving? Lost to heat? :p
    It also makes me wonder how many average miles Arizonans and southern Nevadans are achieving on their Gen 1 Prii.
  17. inferno
    1,072
    405
    Heat is the word..I'm curious to see how my 2012 pip and 2010 prius last as I am a severe battery abuser, trying to run ev whenver I can in all climates (-10, 100+ etc...)
  18. 70AARCUDA
    845
    209
    Tucson, AZ
    Being in Tucson, AZ, I was well aware of the Prius "heat-vs-battery" problem, so we'll see for ourselves with our Prius.
  19. Tideland Prius
    16,539
    When I was in the focus group on the PiP and they were talking about the heater for the PHV test cars, I asked them about cold weather performance for the heater (i.e. how cold before it would be useless). Toyota asked, "how cold are you talking about?" and I replied, "-40" and there was (briefly) stunned silence, followed by "where the heck do you live?".
  20. bisco
    51,807
    well said.(y)
Thread Status:
