Get power for Radar from cabin rear mirror ????
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Victorio Mo, Feb 28, 2015.
  1. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    I want to install antiradar and think to get power from cabin rear view mirror which has power for some switch I never use, do you think it's possible?
    Other option will be to sneak power cable to the top of window, I don't want to use existing power too much exposure.
    Thanks
    Mario
    #1 Victorio Mo, Feb 28, 2015
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Easy. That switch on the mirror is for the garage door opener. If you can get the mirror assembly apart there is a red wire, which is always on, from the 15A Dome fuse, and a black wire which comes on with IGN, from the 7.5A ECU-IG fuse.
    That said, speeding in a Prius just seems like cognitive dissonance.
  3. Mendel Leisk
    41,824
  4. ronjuan
    ronjuan Junior Member
    59
    Encino, Ca.
    Am curious what radar detector you are planning on using and where would you mount it after you power up? Please let us know and send some pix so we can see how it came out.....
