Enginer PHEV kit Rebuilt with quality components and new batteries
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jason in OZ, Jan 9, 2014.
  1. alekska
    alekska Active Member
    435
    138
    Atl
    Just thought its interesting that large battery can be purchased so cheap.
    Alex
  2. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    Thanks for the link.
    I will check it out.
    Jason.
  3. Jason in OZ
    271
    112
    Sydney, Australia
    Ahh.
    Yes. Indeed. If that pack can be bought for 5K that would be interesting.
    I fear it would be closer to 8k here in oz.
    We get zero govt rebates or other incentives to buy and drive clean cars.
    When the leaf launched here, they were 60K.
    The volt still is 60k.
    Crazy numbers. Even at 40k the leaf is still over priced for what it is.
    Jason.
  4. Jason in OZ
    271
    112
    Sydney, Australia
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Jason one thing to bear in mind is that the leaf battery price is probably based on a core return basis, and without which would be considerably more.
    John (Britprius)
  6. mrbigh
    3,686
    699
    Long Island, NY
    Found a website with a reasonable price for NEW leaf packs at @2,995.00
  7. Jason in OZ
    271
    112
    Sydney, Australia
    So today I found someone at my local electronics store (Jaycar) that was willing to have a look inside the converter to see if it might be an easy fix.
    He's a freshly graduated electrical engineering dude.
    Seems keen to at least have a look for me. Who knows. Might even be able to save me some money.
    Does anyone have any info / pics on the insides of the converter ?
    Anyone here ever posted pics of a tear down ?
    Any info that I can find might be useful.
    Jason.
  8. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi Jason,
    I'm sure I've seen some pics of the inside of the converter on here when I had the enginer kit.
    I was learning at the time to trim the output current pot to lessen the load on the converter and hopefully lengthen it's life, as they were known to go poof.
    I also noted at the time mods that other enginer users had done by installing pc cooling fans on the converter body to keep it cooler. I did touch my converter a few times after a long run and jees, it was very hot To the touch.
    Can't recall the link but it's definately in this topic phev here somewhere.
    Could you ask the current sellers for an electrical circuit diagram, at least you'll have some kind of idea then when trying to diagnose a fault, unless of course there's something obvious inside.
    My knowledge of electronics is very limited, I wish i could detects faults, but I read on some or ums about tools and scopes etc.... And I have asked a friend before who's a tv repair tech about a fault and he basically said without a diagram it is very difficult.
    Anthony.
  9. Jason in OZ
    271
    112
    Sydney, Australia
    Thanks for the info. I'll keep looking for those pics.
    My converter already has 2 extra fans mounted above the case.
    They are hooked to the same fan that is inside the converter.
    So as soon as that one comes on, the two external ones also roar into life.
    It's a bit noisy, but I can live with it.
    I have had a chance to have a closer look over the system, and It looks like the main 100A breaker tripped. If that's the case, I'm guessing it's an internal short inside the converter somewhere.
    I havnt been keen to try resetting it, just in case it makes the problem worse.
    If it has tripped, there is a reason that it did.
    Most likely an output FET.
    So hopefully it shouldn't be that hard to find and replace.
    I now have 2 options open for possible repair.
    The guy I met at the electronics store,
    And I had someone send me a link to a professional repair place that specializes in chargers and inverters and the like.
    So if the first option doesn't find anything,
    I'll send the pros an email and see if they can help.
    I'll have more info in about 2 weeks.
    Can't do anything till then, I'm busy next weekend.
    I have a 85km charity bicycle ride planned.
    Again,
    I'll keep this thread updated.
    Jason.
  10. Jason in OZ
    271
    112
    Sydney, Australia
    so....
    the first option didn't work out, and i had help today to remove the converter from the car.
    im taking it to the repair shop Monday morning.
    while it was out of the car, i took the opportunity to open the lid and have a quick look inside.
    my untrained eyes couldn't see anything obviously melted / blown up.
    & nothing discolored or obviously out of place...
    i also tested all 4 of the fuses near the input to the converter.
    all 4 are ok, so it's not the fuses....
    i have taken a few pics for those that might be interested.
    i will report back if the shop is able top repair it or not.and how much it costs to fix....
    Jason.
  11. bisco
    52,351
    sorry to hear about your failure jason, all the best with the repairs, keep your chin up!(y)
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Even if it were just the fuses, the reality is that they would likely blow again.
    Next up would be to test the MOSFETS.
  13. Jason in OZ
    271
    112
    Sydney, Australia
    That was my thoughts
    One or more of the fets are likely blown or shorted.
    I'm dropping the converter off for a potential repair quote tomorrow
    Testing the fets is beyond my capabilities.
    I'll post what happens next.
    On a related note, I filled up tonight after having the system not running and only managed 4.18L per 100km and 870km.
    Not the greatest.
    Jason.
  14. bisco
    52,351
  15. mrbigh
    3,686
    699
    Long Island, NY
    Well, you are back to normal Prius standard MPG's.....
  16. Jason in OZ
    271
    112
    Sydney, Australia
    Yep. That's very true.
    Still I got so used to being at about half that.
    Hopefully I get some good news soon.
    Jason.
  17. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Still quite a good tank considering the weight at the back.
  18. Jason in OZ
    271
    112
    Sydney, Australia
    Update:
    Got the converter back from the repair place today.
    They opened it up, inspected inside, ran some tests and were able to get it running on the test bench.
    However, they didn't actually replace any components.
    So they think the problem is elsewhere in my system.
    I'll try to re install the converter this weekend and see if it works or not, and if not, I guess I have more trouble shooting to do.
    Does anyone know if the front mounted switch is prone to failures ?
    Mine appears to still work, the green led still lights up when the switch is on.
    Wondering now if that switch could fail and that might be the reason it's not turning the converter on ?
    Even though the green led comes on.
    As always, I'll keep this thread updated.
    Jason.
  19. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The front mounted switch is not prone to failure but the design of using a RJ45 plug is questionable as sometimes they do not make good contact and are prone to vibration as reported by some Enginer users in the past.
    See wiring diagram below. If the green LED works then it generally means the DC converter is working.
    When bench testing the DC Converter you need to connect a 2000 watt load across the output to verify it works. Verifying it works under no load does not prove much.
    #79 lopezjm2001, Mar 26, 2015
  20. Jason in OZ
    271
    112
    Sydney, Australia
    Thanks for the diagram. I'm sure it will prove very helpful.
    I'm not sure if the workshop tested the converter under load or not.
    I wasn't there at the time.
    But as you say that if the green light is on, then the converter should be working.
    See what I can figure out this weekend.
    Thanks again.
    Jason.
