2006 Prius with 54,000 miles warning lights today
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by That_Prius_Car, Mar 3, 2015.
  1. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    My partner drove the Prius to work this morning as he always does. So he is on lunch and sent me a text saying some warning lights appeared on the dash while he was sitting at a red light. I asked if he had any loss of power, if the battery fan was running, he said it drove normally. We bought it last summer with 44,000 miles from a Toyota dealer. They said it had a new inverter pump. It has the original 12v battery however. Though it doesn't act weak at all. No issues this winter at all.
    Note, the battery in the photo is at 1 bar. I asked him about it and he said he was driving aggressively to work today, which includes a 2 mile 6% climb he said he made at a high rate of speed... Though after the exit, he has another mile to work.. So the battery should have built itself up before him parking it.
    His HV battery does act weird though after it's been fully charged. I think it's suffering from capacity loss. I won't be able to read the codes till he gets home tonight. Until then, any ideas?
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Yeah, it sounds like he ran the battery very low by driving aggressively and up a large hill. I'm betting if you put it in drive and hold your foot on the brake while giving it gas, you can charge it up to 6 bars and then shut it off and on 4 or 5 times and your problem will disappear.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    [QUOTE="...warning lights appeared ... at a red light ... it drove normally. We bought it last summer with 44,000 miles from a Toyota dealer. They said it had a new inverter pump. It has the original 12v battery ... Though it doesn't act weak at all. No issues this winter [till now].
    [HV] battery ... is at 1 bar ... driving aggressively ... 2 mile 6% climb ...at a high rate of speed... Though after the exit, he has another mile to work.. So the battery should have built itself up before parking...
    HV battery does act weird [when] fully charged. I think it's suffering from capacity loss. ...[/QUOTE]
    Original 12v battery in a 2006? Really?? 1 mile fully recharges the HV battery? REALLY? Think again. Get a new 12v. And plan on more time for HV recharge. Your are stressing the HV battery with the 6% grade at high speed.
  4. JC91006
    JC91006 Senior Member
    16,762
    8,562
    If y0u have equipment to read the codes, do so and there won't be any guess work. A HV battery failure or a failure of the inverter pump after 10,000 miles is possible. A weak 12v battery shouldn't cause the problems you are experiencing while it's on and in READY mode. If you haven't checked your oil level yet, it would be a good time to do so.
    That_Prius_Car likes this.
  5. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    I didn't say it would fully charge it, but build itself up from at least one bar to maybe 3 or 4 in a mile.
    At first I thought that maybe the warning lights appeared if he parked the car for 5 hours with one bar showing on the SOC. But I don't think that would be the case.
  6. kenoarto
    398
    Chicago, IL
  7. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Read the code. P0A80 which is hybrid battery failure. Calling Toyota tomorrow. When he arrived in the parking lot, the battery was full and the engine was revving highly, then it stopped, and the battery within 2 minutes fell to two pink bars.
    I've built a G2 Prius from the ground up before and installed packs, so I may go about this myself. I'll keep you all updated.
    Strange because the car was a one owner, in mint condition, no accidents, and we bought it used from a Toyota dealership last year with only 44,000 miles. It now only has 57,000 miles. Hopefully Toyota is helpful...
    #7 That_Prius_Car, Mar 3, 2015
    uart likes this.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It has been speculated that a battery that is rarely driven and allowed to sit for extended periods dies earlier than a normal use car. You have exceptionally low miles on that 2006 and my guess is that it just "rotted away". Use it or lose it.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi TPC, are you in a carb state? Anyway, if you're not hopefully Toyota might still help out. It's certainly a very low mileage failure.
    BTW. I'm not aware of the circumstances that required it, but it looks like you did a nice job with the strip down and rebuild. :)
  10. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Checked the 12v battery today and that is still healthy.
    Called Toyota customer support who then said I'd need a Toyota dealer to diagnose the issue before they could assist me.
    Made an appointment at Jim Robinson Toyota tomorrow afternoon and a 100 dollar diagnosis fee.
    I also have a reference number from Toyota that the service rep asked for. Made a video of how the battery acts too, I'll post it shortly. It drains down to two pink bars within 45 seconds and charges up to 4 blue bars within 10 seconds.
    #10 That_Prius_Car, Mar 4, 2015
  11. kenoarto
    398
    Chicago, IL
    You need to edit you video above! It goes directly into your awards presentation!
  12. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Oh! I don't know why it did that. Is it better now?
  13. bisco
    51,843
    you're good for 10/150 bud!(y)
  14. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Not in WV. ): PA has the CARB law, and PA is only 10 minutes from me, but the car isn't registered in PA. ):
  15. bisco
    51,843
    dang, i thought imadrifter was a carb state.:p
    usnavystgc and That_Prius_Car like this.
  16. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    I'm really hoping that since the car has low miles and is just a couple months over the 8 year warranty, that Toyota would be kind enough to replace it under warranty. I'm sad and mad at the same time.
    #16 That_Prius_Car, Mar 4, 2015
  17. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'd be surprised if Toyota picks up everything. They may cover part if approached politely.
    "Raising Hell" when one doesn't have a defensible position is the fastest way to vaporize any goodwill there may have been and get your case denied.
  18. bisco
    51,843
    all the best man!(y)
  19. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    The car was manufactured 6/06.
    I know, I apologize. I won't be raising any kind of hell... I'm just kind of in a rut. I don't know what to do. Out of all my Prius', this is the first time a huge failure has happened to me.
    #19 That_Prius_Car, Mar 4, 2015
  20. JimN
    7,028
    1,117
    South Jersey
    Better to vent here than elsewhere.
    You'll want the date the care was first placed in service. In 2006 a Prius didn't sit on the lot for a week so I'm guessing an August 2006 in service date at the latest. The best estimate you'll probably be able to get is the predelivery service from Toyota Owners Official Web Site: Service Coupons, Owner's Manuals, Service Scheduling And More. My 2010 sat on a lot for about a month in 2009. I would guess a later date & let Toyota reply with the date of the first sale.
