40 mpg...
Discussion in 'Gen 3 Prius Fuel Economy' started by Justin Valle, Mar 9, 2015.
  1. Justin Valle
    Justin Valle New Member
    17
    Los Angeles
    I just bought a 2011 with 90k miles on it. I'm getting 39.9 - 40 mpg according to my "CONST" reading on the display after the dealer reset it 1 week ago.
    A week ago I took in into the dealership to inquire about some bulbs being out and the MPG concern. They fixed the bulb, reset the CONST miles counter and told me that if there are no error messages there's really nothing they can do. I go back in a few days for a 2 week review of my "driving habits" and a better explanation I'm hoping.
    -Tire pressure is good
    -12v battery is in question - I tested against the 12v-battery-test found at Prius DIY
    and got these results.
    Test 1 - 11.5v
    Test 2 - 10.6v
    Test 3 -13.2v
    I'm still under warranty for another 1,500 miles, would love to fix my MPG closer to 50 because I plan to drive a lot of miles
  2. alekska
    alekska Active Member
    435
    138
    Atl
    Winter and short trips take toll. My wife drives her 2010 3 miles to work and stops at daycare midway. Her mpg is ~ 40
    When I drive I get ~50-55 mpg in her car but I take a much longer trips.
    - Alex
  3. Mendel Leisk
    41,859
    The battery sounds low. I'm really not sure how those values are derived, suspect the first is equivalent to measuring voltage with the car off, with a multimeter. The latter should give at least 12.4 volt (that's what I'm getting on ours, so it's ok, lol). A 100% battery would for sure give over 12.6 volt.
    Tire pressure is "good"? That likely means per the pressures recommended in the drivers door sticker. That pressure is a compromise, with one aim being to keep kushy ride. If you don't mind feeling the bumps a bit more, try running them up to around 40 psi, all around. Maybe a bit more on the fronts. Personally I set them all the same, makes life simpler at rotation time.
    That mileage is troublingly low. Doubly so because the car bs's on displayed mpg, actual is likely more like 37~38 mpg, if you were to calculate. Just stick at it for a tank or two, see if it improves. Is this highway or city driving. What speeds?
    All things considered, just stick at it for a tank or two. Try to adhere to speed limits, keep a good space in front, coast up to slowdowns. The less you need brakes the better.
    walter Lee likes this.
  4. bisco
    52,349
    fill out the 'why are my mpg's low?' sticky. that will give us more to go on.
  5. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    How do you drive the vehicle? It's really hard to tell why you're getting low MPG without knowing more detail. Do you typically drive short trips? Are the trips mostly all freeway? Or city?
    Take for instance I typically like to drive city routes since that's where I see my biggest MPG gains. If no one is on the road when I'm driving I will accelerate REAL gradual and purposefully drive under the speed limit and pulse and glide the entire time. All these little things add up over time and it just takes time to get used to driving habits. I think I would REALLY need to try hard in order to hit 40 MPG as I typically get 45 MPG when temperatures are in the single digits. Today's temperature reached around 40 today and I could already tell my MPG starting to climb. Can't wait to try and reach for the 60 MPG mark once it really starts to warm up :)
  6. Justin Valle
    17
    Los Angeles
    I'm in LA, doesn't get much colder than 45 at the very coldest here.
    I've gone through 3 tanks in 4 days driving for Uber. I drive a little aggressively but I rarely come to sudden stops -I watch some vids on maximizing mileage. Maybe 5% of my driving is over significant hills, the rest is pretty flat.
    Thanks for the tip with the tire pressure.
  7. Mendel Leisk
    41,859
  8. bisco
    52,349
  9. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    One thing I've really been trying to do lately is coast up to a red light. I mean I will start to slow down real early. Even if you've only gone down to 5 MPH, that's still better than a complete stop.
  10. Justin Valle
    17
    Los Angeles
    can't find that sticky, just searched for 10 minutes...
  11. bisco
    52,349
    it's the last one in gen II prius fuel economy forum.
  12. bwilson4web
    16,351
  13. Justin Valle
    17
    Los Angeles
    - Have you read This Thead Yet?
    Yes
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    40, based on trip computer
    - What fuel economy are you expecting and why?
    52, because that's what Ned at Toyota told me that's what "this one" got
    - What are the approximate outside air temps?
    50-80 Fahrenheit
    - How long are your trips?
    5-80 miles, varies, uber driver
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    not sure how old, reading 11.5 volts with no load, 13.2 volts in ready mode
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    new tires, toyota inspected
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    I'd estimate 2/3s highway, average speed on my dash reads 18mph
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    mostly flat, with some hills that make up less than 5% of what I drive
    - What are your tire pressures?
    40psi
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    not sure
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    Toyota Corolla 2001, 4cyl 1.8L Automatic. 31 mpg
    - What region/state are you in? (if you haven't set your location)
    LA, CA
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    constant eco mode, moderate acceleration, moderate braking, not trying very hard to save MPG yet
    - What modes are you using, if any? "normal", EV, power, eco?
    eco
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    no
    - Are you driving using D or B mode?
    D most the time, B down some hills sometimes
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    auto mode with ac on about 1/2 the time, set to 74, other 1/2 of the time it's completely off
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    New Yokohamas
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    My CONST read 38.3, I took it into my dealership for a diagnostic, they reset my mileage and told me to come back in 2 weeks to review my "driving habits", got low air error for tires, filled up tires with 40psi, CONST is now 39.9
  14. bisco
    52,349
    you need a new 12 volt battery, that can cost you 5-10 mpg, see ned. you may want to research the tyres to make sure they are low rolling resistance. if not, that can cost 3-5 mpg, see ned. how fast are you driving on the highway? over 65 can seriously compromise mpg's. other than those, i don't see any problems.
  15. bwilson4web
    16,351
    Just to amplify the 12V issue:
    • 11.9-12.85V - allowable, voltage without car charging circuit turned on.
    • <11.9V - 12V battery has been run down and/or is failing
    • 10.5V - 12V battery is toast, replace as soon as practical as starting becomes a 'crap shoot'
    • 13.8-13.9V charging circuit voltage for 12V battery
    What lights were burned out? The reason I ask is there may be a latent, switch defect that allows the bulbs to discharge the 12V battery. In particular, peek at the car after 3-5 minutes to make sure all of the interior lights are going out.
    As the car run, it 'adjusts' the cold-start, fuel trim (i.e., mixture.) When the 12V gets too weak, this can default to an overly rich mixture. Also, the remote-access can not unlock the car.
    #15 bwilson4web, Mar 10, 2015
  16. Justin Valle
    17
    Los Angeles
    "see ned" ? Thanks for quantifying how much my battery may be hurting my MPGs, I was wondering that.
    I cruise at about 72mph on the freeway whenever possible
    The driver's visor light was out.
    Anyone know what voltage will necessitate a free new battery under warranty?
    I just got this thing.
  17. bwilson4web
    16,351
    1. One hp is ~745 Watts, which for a 12V battery which under charge is ~745 W / 13.8V ~= 54 A.
    2. Cruising at 72mph, your expected MPG would be: [​IMG] These MPG values achieved by driving on cruise control on a 'flat' area and does not include acceleration or braking effects. One Prius trick is to learn how to follow slower traffic at a safe distance, say a moving van or delivery truck. The following traffic will see the truck and smoothly pass without 'setting their hair on fire' about the poor Prius stuck in traffic. Meanwhile, play some good tunes and enjoy the ride . . . like golf, the race is to avoid the gas pump. FYI, you have two trip meters, A and B. Use one for the tank and the other for 'test' segments to learn how the car really works.
    3. Driver side visor light, make sure in the dark that when the car is off, there are no other lights draining the 12V battery. Day light it is harder to find these parasitic loads.
    4. Used car warranties are negotiable. An Autozone or car parts store may be able to test the battery and provide an independent metric. WARNING: reversing the 12V battery polarity can destroy expen$ive controllers. You might want the seller's shop to handle the test.
    GOOD LUCK!
  18. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    I could be wrong, but I don't think the 12V battery is covered under warranty.
    Take Ned's "52 mpg for this one" with a grain or two of salt.
  19. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    If it really reads 11.5 with no load, it's dead by anybody's standards.
    BUT......used car warranties often do NOT cover things like tires and batteries.
    Regardless, you need a new one.
    bwilson4web likes this.
  20. Mendel Leisk
    41,859
    A few comments on the above:
    1. If you change the display to show this:
    it's easier to slip the car into electric-only, and keep it there. If you completely lift off the gas, then gently re-apply, while keeping it to the left of the center line on the bar (yellow highlight zone), the engine should stay off. Get too good at this, especially under moderate load, and you'll start to run the hybrid battery down excessively. Arrrow number 1 points to the hybrid battery state of charge indicator.
    Running the hybrid battery down is not terrible, it'll just force the engine on, but use this trick moderately, you'll cut engine use without downside. I'd back off from this tactic if hybrid battery charge has dropped to around half.
    2. I'd reserve B mode for LONG hills only. Like coming down ski hills. To slow on short down grades, just use the brakes as usual. B mode reduces battery charging, it's intent is to protect the battery from overcharging, coupled with protecting the brakes from overheating.
    3. Is that a typo on the tire size?? Correct size should be 195/65R15? If they are 185/65R15, that might be a factor.
