Prius gen II-Add cruise control-EU model- 2006- full guide
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Ramanjit81, Aug 19, 2011.
  1. Ramanjit81
    39
    Dublin, Ireland
    How to add Toyota OEM cruise control to a non- cruise control European Prius.
    Disclaimer: The procdure mentioned hereunder is an account of what I did to successfully add a cruise control to my base model car. I do not extend any warranty/ guarantee nor do I accept any responsibility against any damage anyone may cause/ incur after reading/ attempting these instructions/directions. Any use of this information is entirely at your own risk.
    I have completed the installation successfully today and would like to provide this concise list of parts needed and links to pictorial installation illustrations.
    Parts needed:
    1. 45186-47010-CO cover steering wheel x 1- to replace steering wheel cover to accomodate the stalk
    2. 90159-50199 screw x2- to fix the stalk the the steering
    3. 84632-34011 switch cruise control x 1- the black stalk
    5. 84633-48020 switch c/control x 1- CC switch wire with connectors
    6. 84340-47020 Brake light switch/ stop lamp switch x 1- brake switch with cruise control
    - This is the varying part for the various years between 2003-2009. Please ensure the one mentioned here is actually the right one for your year and model. A good reference site id www.toyodiy.com.
    One of the most confusing things is the exact brake switch to get. But I can confirm now that 84340-47020 and 84340-06010 are perfectly compatible. Having consulted www.toyodiy.com and verifying it with the dealer I learnt that the correct part number for my car is 84340-47020, but having looked at pictures at the following link I realised that it looked similar to 84340-06010 advertised on ebay and took a chance to order it. It works just fine, the compatible after market item number is Beck/Arnley 201-1566. So any of these would work.
    http://priuschat.com/forums/attachm...617603-wish-i-had-cruise-control-cruise07.jpg
    The following are the links with pictures and good explanations for same for the full cruise control installation procedure.
    1. Google Translate
    2. https://translate.googleusercontent...e.aspx&usg=ALkJrhiMYFggf1UnhFEeHgYs8s6gGL15gw
    3. Google Translate
    I hope this guide helps some one.
    I was able to install the cruise control stalk in the steering cavity without disconnecting the airbag connectors, I did it because I didn't know how to unplug the airbag connectors and didn't want to damage the connectors while forcefully disconnecting them, but I'm sure the safer way is to disconnect the airbag and keep it aside and have two free hands for the installation.
    Getting to the brake lamp switch is a bit awkward, just obviously doable with some perseverence. Please bear in mind that the nut on the back side of the plate to which the brake switch is fixed is welded, so please do not try turn it. We need to turn the one visible under the switch plastic body ever so slightly with a size 14 spanner and thereafter it can be removed by hand.
  2. ohhwell
    ohhwell New Member
    Just confirming that this worked perfectly on the 2008 US model we just bought. Thanks a ton for posting the part numbers and links. The second Google Translated link you posted was the best for me. It was very easy to disconnect the 12v battery in the trunk and worth it to not worry about an airbag going off in my face.
  3. J_eberst
    J_eberst New Member
    Port Saint Lucie Fl
    I also wanted to confirm that this worked for my 2009 base US prius.
    Here are the parts I used that were different from the above.
    8463208021 Cruise Control Switch
    846330E020 CC Switch Wire
    I tried to use an OEM brake/stop switch, but the toyota dealer gave me the wrong one. (84340-30100)
    The correct one is 84340-30110, or you can get the switch from most autoparts retails by just searching prius stop switch with cruise control. If you see a picture the one with cruise control will have connections for 4 wires.
    I recommend removing the lower half of the dash to get the brake/stop switch out. The first 30 seconds of this video is a great example.
    Then use a wrench to turn the switch so the wiring harness faces down. This will make it much easier to remove the wire from the back of the switch.
  4. SanjayRajwani
    SanjayRajwani New Member
    Stockholm, Sweden
    Hi Ramanjit
    Your's is the only post on the internet which actually tells how can we install cruise control to a Prius. (Y)
    I own a 2008 Prius in Stockholm Sweden which I bought a couple of weeks back, and I only realized it a few days back that it doesn't have cruise control. I assumed that all Prius models will have it (stupid of me)! But anyways, having read your post I feel more confidant in attempting to do the job myself. I am only not sure where exactly can I locate the "Brake light switch" ? And you mentioned that there is one which is welded to the plate and the other one that is screwed in. It would be really great if I can see it on a picture? The pictures in the links you've shared are taken too close to understand where exactly the switch is placed!
  5. The Beast1
    The Beast1 Junior Member
    France
    Reviving this thread as it helped me get CC. Install is very easy and a good addon for newbies. It took me about an hour and a half to finish. A few special notes:
    1. The screws you need are M5 screws. Go to your hardware store and pick some up.
    2. There are multiple part numbers for the brake light switch. Toyota switched ODMs for this part multiple times, but they should all generally work.
    3. The pictorials from the Japanese sites above are really wonky. There's no need to disassemble the entire dash. It looks like his Prius is lacking an LED for the dash indicator light which is odd because mine has it. Anywho, if you're unsure just install the cruise stalk first and power on the car. If the cruise indicator light turns on when you click the stalk you're good to go.
    4. Getting to the brake light switch isn't hard. Remove the hvac vent column with the start button on it by pulling out on it. Unscrew all the bolts you see. Go under the wheel and unscrew any remaining bolts on the under dash panel. Pull out on the key fob slot area to unloosen the bottom dash.
    Pull off the under dash out and disconnect the cables. The brake switch indicator sits at the top of the brake pedal so get on your knews to really see it. There is a bolt on top of the metal mount that looks difficult to get to with a wrench. This is the guy you want to unscrew. Don't unscrew the bolt on the bottom. Use the new brake light switch as a guide to know what you're twisting.
    Pro tip: if you can't maneuver well enough, disconnect the ECM unit's cables by unscrewing the mounting brackets holding it in place. That should give you enough room to fit a proper wrench in there. If the nut doesn't want to budge, get a lighter and heat that sucker up. Be wary of the cables underneath.
    I missed cruise control too much!
  6. Orange71
    Orange71 New Member
    UK
    Sorry to drag up an old topic - I bought the parts to do this on my 2005 T3 Prius and got my mechanic to fit everything but it doesn't work. Any idea what I could be doing wrong? Do you have to 'tell' the ECU or something that CC is now fitted for it to work? The stalk was described: Cruise Control Stalk Switch + Harness 84632-34017 Kit Fit for Lexus ES350 GS450H (I can't put a link up but it was on ebay). It claims to be compatible with Gen 2 Prius.
    #6 Orange71, Jan 15, 2020
  7. Umerpk
    Umerpk Junior Member
    24
    Pakistan
    In few vehicles YES you need to tell the ECU by connecting 1,2 wires from ECU to clockspring or brake switch. Hope you have the wiring diagram. It is very easy to connect those wires. Sometimes you need to change the clockspring as well. Most of the times this cruise control switch is just plug n play. In my JDM 2006 pri, it was plug and play but without LED in the dash which I installed myself.
  8. Dilshan
    Dilshan New Member
    Sri Lanka
    I have Prius 2008 Gen 2 (Japanese version) with 4 pin brake switch.
    I have installed the Cruise control lever and connect the white color socket.
    Still the CC not working , please advice the further steps.
    Regards
  9. ald1stil1
    ald1stil1 New Member
    Italy
    Hi everyone, I know it’s been a long time since the last reply to this thread, but since this is the best (and only) guide I’ve found for installing cruise control on European vehicles, I decided to try to revive it.
    I bought my 2008 Prius last December, and ever since I’ve been looking for a way to add this feature to my car. The procedure described above is very clear, but since it sounds almost too good to be true, I wanted to clear up a few doubts before going ahead.
    Before finding this page, I stumbled upon some shops selling complete kits—mostly American—which include extra wiring connections that aren’t mentioned here (please check the attached picture). Could anyone tell me if it’s really enough to just install the stalk to the steering wheel, or if other connections are sometimes necessary?
    Moreover, when I searched for the individual components, I also found non-OEM parts at ridiculously low prices. Do you think it’s worth the risk, or does at least the stalk need to be original?
    Finally, I’d love to know if anyone’s successfully installed cruise control on a European car recently.
    Thanks in advance for your help!
  10. ald1stil1
    Italy
    Update:
    I just bought the necessary parts and installed them successfully!
  11. Truth-Seeker
    Truth-Seeker New Member
    Europe
    Thanks for the update.
    I drive prius 2005 European, could you please share a more detailed experience and which parts you end up using.
    Greetings
  12. ald1stil1
    Italy
    Sorry for the delay.
    Here is the full parts list:
    • 1x cruise control stalk 84632-34011
    • 1x cruise control stalk connector to the steering wheel 84633-48020
    • 2x cruise contro stalk screws to the steering wheel 90159-50199
    • 1x cruise control stalk cover 45186-47010-C0 (C0 refers to the color)
    • 1x stop switch brake pedal 84340-47020
    First of all disconnect the 12V battery, you don't want the airbag to explode when you are working on the car.
    Then just pop out the two plastic covers behind the steering wheel with a flat screwdriver or a clip remover and unscrew the two bolts underneath. Now you should be able to pull the airbag cover. Once you have done that you should be able to take out the airbag and to disconnect it.
    Now take the cruise control stalk, connect the cable, on both ends, mount it on the steering wheel, and reassemble everything backwards.
    Here comes the tricky part. The stop switch is not very easy to reach and therefore to work on, but with a good dose of patience you can do it. My advice is to mark the current bolts position before taking it out.
    Once this last step is done you can reconnect the battery back and test it on the road!
    A few final considerations.
    My car is from 2008 and the CRUISE light on the dashboard was already there, I don't know if the older models have it mounted from the factory.
    You should be able to source all the mentioned parts at your local dealership, but I strongly recommend to buy everything on Aliexpress, as my total expense has been around 20€, and you can find many kits ready for purchase without browsing for the single parts. The only thing I wasn't able to find is the stalk cover 45186-47010-C0 that I ended up buying online as an original part for about 40€.
    If you don't feel doing the work yourself I believe that any repair shop could do that for you.
    All that being said, this is just my experience, but as I struggled to find all these info I really hope that it might be helpful to someone.
  13. dolj
    dolj Senior Member
    8,630
    4,384
    Wellington, New Zealand
    The 2004-2005 model does not have the CC light on the cluster. You can, however, buy the light cluster and matching combination meter from a 2006-2009 model from a wrecker/dismantler. Try to get one that matches the distance (kms) currently displayed on the odometer. You will then need to dismantle the dash to swap these parts over.
