2010 Transmission flush
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jim bellina, Mar 21, 2015.
  1. jim bellina
    jim bellina New Member
    North Tonawanda, N.Y
    i have a 2010 Prius IV with 56810 miles, should i do a transmission flush ??
    and how many qt go back into the unit ?
    Thank you Jim
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    jim bellina likes this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Yes, the consensus is at 30k miles and 60k afterwards. So your 60k would be good.
    It takes about 3.5 - 3.75 quarts. There is a drain plug and a fill plug. Fill it until it runs out of fill plug with car level. Be sure you can remove fill plug before removing drain plug. Also get new plug washers to replace.
  4. jim bellina
    Thank you .....My Friends :D
  5. Mendel Leisk
    41,628
    Drain and fill bolts are the same, torque 29 ft/lb. You need a 10mm size hex drive for them:
    (I like Honda's transmission drain bolt better, it's a similar socket-head-cap-screw bolt, but with a 3/8" square bolt. All you've got to do is attach a 3/8" drive to it.)
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,058
    541
    Tucson, AZ
    2021 Prius
    I believe the recommendation from PC, from what I've read anyway, would be to NOT spend the extra $ on what they call a "flush". Just drain and refill should do it.
  7. Mendel Leisk
    41,628
    Really no automatic fluid change warrants a flush, even a traditional automatic, where only 50~60 % of the fluid will drain, as long as you do periodic changes. The only exception would be if you did something bad, like accidentally poured engine oil into it. Then, to get it out, you do a "flush", basically changing the fluid, driving it around the block, repeat maybe 3 times.
    jim bellina and CR94 like this.
  8. Sylvio Briffa
    Sylvio Briffa Junior Member
    Oakland,CA
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,058
    541
    Tucson, AZ
    2021 Prius
    All sorts of expendables if you have the tools and the know-how. There are maintenance manuals (I've had trouble so far tracking down a Haynes manual for my Gen III) and even You Tube videos for fixing this and that. A short list would be the engine and cabin air filters, the spark plugs, engine oil and filter, transmission (PSD) oil, light bulbs (except brake light LED's), brake pads, and fuses. A short list.
  10. xliderider
    8,140
    3,277
    Honolulu, HI
    There is a forum section in priuschat.com called Knowledge Based Articles Discussion. Lots of information and How To articles and threads.
  11. Mike500
    Mike500 Senior Member
    2,593
    767
    When I changed the transaxle fluid last year on my v at 13k, I discovered that the Gen III eliminated the little ceramic magnet on the drain plug.
    So, I milled out a drain plug and affixed a 15 pound pull neodymium magnet to it.
    To see if it did any good, I removed the magnetic plug to find that there was already iron or steel particles attached to the magnet. I had half a quart of ws fluid left from the 4 quarts to refill what I lost in switching plugs.
    I have uploaded photos of the Gen II plug removed after many miles and my plug.
  12. jim bellina
    I'm going to drain and re-fill that's it ,on the Transmission.
    what about radiator flush ?? i just it 57,000 miles today.
    Thanks Jim
  13. Mendel Leisk
    41,628
    In the US schedule it says coolant change at 100,000 miles or 10 years.
  14. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    ...though some of us do it a lot sooner. ;)
    jim bellina and Mendel Leisk like this.
  15. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,699
    1,746
    Bay Area
    Here's a video to save you time on guessing what to do :)
    frodoz737, jim bellina and mrstop like this.
  16. jim bellina
    again Thanks Guys......
