  1. Boston Jim
    Boston Jim Active Member
    202
    148
    @WolfpackBill - did you just buy the center caps or did you plastidip them as well, leaving the crome toyota symbol?
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,460
    92
    Today was the washer nozzle delete.
    Burna J, Starbrand and sfv41901 like this.
  3. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I worked on this today.......these are just teasers
    More too come
    VS980 4G ?
    Tracksyde, Jayare, Burna J and 6 others like this.
  5. ncases
    ncases Senior Member
    609
    672
    Chicago
    I'm excited my friend! Can't wait.
  6. WolfpackBill
    WolfpackBill Senior Member
    349
    501
    Lexington, NC
    I Plastidipped the cap as well. The caps that I have allows the Toyota emblem to be clipped on so I took the emblems off and Plastidipped the cap.
  7. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    is this the before pic?
  8. Burna J
    1,071
    3,341
    53
    Long Beach, CA.
    Somebody's going to happy !! :rolleyes::D:D:rolleyes:
    sfv41901 and Dylan Doxey like this.
  9. Dylan Doxey
    1,389
    3,460
    92
    Shortly after I posted this I realized that I put it in back to front. I was probably rushing the finish to beat sunset. Here's the morning after revision.
    Here's a few snapshots detailing how I fabricated the plug.
    20150417_164340.jpg 20150417_182516.jpg 20150417_183806.jpg 20150417_184806.jpg 20150417_191009.jpg
    I found a carriage bolt with a 1" head. Using an angle grinder and a dremel tool, I sculpted it to closely match overhead profile of the washer port. Then I hit it with a coat of primer, and a shot of 8V1, and installed it using he original gasket.
    #6989 Dylan Doxey, Apr 18, 2015
    sfv41901 and Starbrand like this.
  10. Dylan Doxey
    1,389
    3,460
    92
    No, that's the after pic.
    Perhaps "delete" is too strong of a term. Let's call this a washer port plug.
    It's using the original gasket from the washer port which keeps it raised a bit.
  11. Accordlayingkit
    1,618
    1,748
    377
    Gotcha
  12. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    image.jpg At @sfv41901s pad to install some df210s.
    (y)
    sfv41901, Jayare, ncases and 2 others like this.
  13. Dylan Doxey
    1,389
    3,460
    92
    Today's project: Inverter Cover (and Friends) Installation
    Before:
    After:
    The coolant bottle and the wiring harness covers were simple snap-ins. However, the inverter cover was made for Lexus & Prius v (a.k.a プリウスα). So it takes some tweaking to get this to fit in the ZVW30 just right.
    The inverter cover has three issues.
    1. There's a grounding bracket that interferes on the corner near the fuse box.
    2. There's a mounting hole which has nothing for the push-pin to push into.
    3. The radiator cover doesn't play nice with the forward edge of the inverter cover.
    The grounding bracket issue took a little work with a cutting wheel and some touch up work with a dremel sanding drum.
    For the mounting hole issue, I fabricated a fake backing for it. It's purely cosmetic.
    For the case of the interference between the radiator cover and the inverter cover ...
    I used my dremel sanding drum to shave the radiator cover a bit.
    There, it is.
  14. Burna J
    1,071
    3,341
    53
    Long Beach, CA.
    You could use one of this...... I think it was on isle 5, at Lowe's..... Right? @Accordlayingkit . :D
    bonchang, sfv41901, ncases and 4 others like this.
  15. Accordlayingkit
    1,618
    1,748
    377
    lol that's right!
    sfv41901 and Burna J like this.
  16. Sweet n Low
    Sweet n Low Junior Member
    24
    20150418_153546.jpeg Lowered the car on Megan springs..
  17. Dylan Doxey
    1,389
    3,460
    92
    I finally got around to installing those hinge covers.
    Before:
    After:
    That's much better!
    Accordlayingkit and sfv41901 like this.
  18. Jayare
    Jayare Junior Member
    25
    17
    Chino hills Ca
    Went over to sfv4190 pad got a taste of Prius101 had my DRL's hooked up to a switch I'll take some better pics later car is dirty ...Oh also installed some HID's and OEM Toyota window visors that was a few weeks ago
    next up drop and front lip
  19. ncases
    609
    672
    Chicago
    So your drl turns on with your headlights?
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes, they stay on with the headlights & can be turned off when not wanted. Think of them now as DRLs during the day & fogs at night.
    St frmmy V80 G uing Tatalk
