  1. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Swapped out the front door speakers today.
    I used the stock speakers as mounts, which required trimming them so they're about 5mm shallower depth in order for the door panel to fit with these new speakers.
    This vibrating "multi-purpose" cutter made short work of that task. Took about 30 seconds to do what would have taken me 30 minutes with the dremel.
    The new speakers are RF R169x3 and they sound great together with the new dash speakers.
  2. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    Thanks guys! Ya'll were right.(y)
    xliderider likes this.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Today @sfv41901 installed my TRD springs.
    Here is a before picture from a couple of days ago ...
    I could fit four fingers between the tire and fender. Now I've got about one finger.
  4. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    Nice! Did you have to solder anything?
  5. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    I used the wires inside the stock speakers - I soldered female speaker connectors to the stock wires so they'd plug into the new speakers. Those wires are an uncovered copper braid, so I also slipped heatshrink tubing over them before soldering the connectors on.
  6. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    Thanks for the info, will be trying this soon.
  7. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Search the audio forum here too. There are a couple of posts in there with more info and pics on hacking the stock speakers to use them as mounts.
    Honestly, it's probably easier to just use Metra mounts and wiring adapters. I just like fabbing stuff (or maybe a glutton for punishment) :sick:
    Accordlayingkit likes this.
  8. MeetGeorgeJetson
    MeetGeorgeJetson Junior Member
    48
    33
    Woodstock NY, USA
    Installed my SAMs club cheapie seat covers, they were a bit baggy until I pulled them up tight and used the headrest stems as locking pins, now they actually don't look too bad. A little bagginess on the rear top but nothing to get to upset about, especially for $20. Bummer part, no back seat matching set as far as I know, oh and the head rest cover was completely not usable... again $20, you get what you pay for some times. Slipped a set of washers on to hide ugly cut hole. Also I have wheel cover coming in dark gray with the same stitching , so should look good when its all set up.. Hopefully.
    Ok wheel covers are off. Wheels are in good shape, a couple of scuffs here and there, but nothing distracting. Got a set of caps for the hubs, local Toyota dealer fleeced me but I do like giving my local business some love when I can. They look a bit shiny compared to the wheel so I might try some satin clear Krylon.
    Got some of that shelf/drawer material at JoAnn's fabrics, with coupon only 4 bucks! Made every possible surface non skid!! They had it in this dark charcoal gray/black, very cool. Even the cup holders were lined. I gently tacked it down with double stick foam pads cut very small. This was a fun easy thing and now my phone no longer slides around in the tray.. Also helps with coins rattling about in the little tray in the arm rest.
    slowpriusj, TopRamen, bingee3 and 6 others like this.
  9. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    #7149 nedear88, May 2, 2015
    RightOnTime and Accordlayingkit like this.
  10. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Looks sexy. :)
    It looks like it's pretty close to the plastic piece under the bumper? Make sure it's not too close or touching, I've seen some pictures of melted plastic before, it ain't pretty. :eek:
  11. nedear88
    246
    142
    Yeah...it's a lot of clearance actual, but from the side view it seems really close but it's not. I had the Yaris stainless steel tip before it's even closer than this flowmaster version. I posted it in the for sale forum see anyone want to buy it. For Sale - Stainless steel tailpipe tip ($30) shipped. | PriusChat I like this flowmaster tip...it's heavy gauge and nicely polish from the factory.
    #7151 nedear88, May 2, 2015
  12. munkeeboi
    munkeeboi Active Member
    100
    173
  13. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
  14. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Well after yesterdays all night Modd Party...... :):confused::sleep::sleep:
    Got up early this morning to meet up with @bino and @RightOnTime for the 20th Toyotafest car show, here in Long Beach.
    Congratulations to RightOnTime and his Beautiful Prius G' taking 1st. place. (y)(y)
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Congratulations @RightOntTime
    VS980 4G ?
    RightOnTime likes this.
  16. Sweet n Low
    Sweet n Low Junior Member
    24
    Did sum tinting today going to do fogs and turn signals tomorrow 20150502_140455.jpg 20150502_115602.jpg 20150502_140515.jpg
    #7156 Sweet n Low, May 2, 2015
  17. MeetGeorgeJetson
    48
    33
    Woodstock NY, USA
    Hey Sweet and Low how hard was it to do your own tinting? I want to do it as well but Im thinking I dont wanna screw up and waste money.. Maybe let the pros handle it? Did you buy the tint precut?
  18. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Love it! Did this too on mine. Also pulled this upper box and lined up the surrounding exterior w/sound deadener so when I put something in it doesn't rattle loud enough to annoy me, lol!
    MeetGeorgeJetson likes this.
  19. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    #7159 Sergiospl, May 3, 2015
  20. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    The visible magic of optical illusions :)
