Car burning oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pyrotalk, Jun 20, 2015.
  1. pyrotalk
    pyrotalk Junior Member
    What would you do for prius 2010 with 128,761 miles that is burning oil? i have paid to change the spark plugs and PCV valve. I never could find the damn PCV valve. I just change the oil at 127,190 miles and the stick shows it. The white arrow shows the level of oil at the last change. How do you compute the loss in terms of quarts?
    Well the ticks shows that much oil lost for a mere 1,571 miles. Unbelievable, i just fill it a month ago.. I am using Mobil1 0-20W but i will use 5-20w unless anyone has other oil type suggestions
    thanks
  2. JC91006
    JC91006 Senior Member
    16,723
    8,546
    When you changed the oil, how much did you put in? 4 qts?
  3. pyrotalk
    Hi.. I changed the oil on May 25 at 127,190 miles and i put about 3.5 quarts (approximation, i use less than gallon). I read here many options, change to 10W-30 (even though toyota says 0 or 5w-20) but since i have a problem i will change to thicker oil..
    I am curious about piston soak but i just changed the spark plugs
  4. JC91006
    16,723
    8,546
    If your car is from 2010, gen 3, it takes 4.4 quarts. That can explain why your dipstick shows half way.
    From the top mark to the bottom marks on the dipstick, it's 1.6 quarts
  5. bisco
    51,486
    the white arrow shows the level after you put in the new oil? and where is it now? hard to see.
  6. Mendel Leisk
    40,919
    Yeah, I'm confused too. Is this how much it's dropped??
    Between the two dimples is about 1.5 quarts, fwiw.
    (I like how you continue to call it the damn PCV valve, in your postings. It has that effect on people, for sure.)
  7. bisco
    51,486
    nice pic!
  8. Mendel Leisk
    40,919
    Windows Snipping Tool. Built-in, as of Win7.
  9. bisco
    51,486
    i admire your skills. i can't even cut and paste. well okay with scissors and glue, but it makes a mess of my screen, and no one else can see it for some reason.:cool:
    Andyprius1 likes this.
  10. Mendel Leisk
    40,919
    If you're on Win7 or later:
    Type "snip" in the search field of start menu. Then right-click the search result, choose properties, and assign it a hot key, say "S".
    Then anytime you want to use it you just type <ctrl> <alt> S. It pops up, your screen goes kinda white, and you can click and drag a rectangle on any part of screen.
    You can save snips, default is the Pictures library, name "capture.jpg". Just keep saving it with that name, very easy to find. If you need two or three, make 'em capture02, capture03 and so on.
  11. pyrotalk
    No way. Then 4.4 will top over the upper dimple. Any case what oil grade and should I fill one quart drive around and fill another. I am in the store literally
  12. Mendel Leisk
    40,919
    What's your current oil level, pick a number?
    Again, the distance between the two dimples is about 1.5 quarts. Get a couple of quarts, and figure out later?
  13. bisco
    51,486
    i would start with the 5-20, and keep going up until it stops burning.
  14. pyrotalk
    Just fill one quart of 10w-30 Mobil and it look like a 3 level. See blurry pic
  15. bisco
    51,486
    wow, that brown oil for 1500 mile.
  16. pyrotalk
    Should I add another quart?
  17. JC91006
    16,723
    8,546
    I would wait and check at another 1000 miles to see where you're at before adding another quart. You are only about 1/4 quart shy of the full dimple.
  18. bisco
    51,486
    agreed. no need to run her at full, but keep a weather eye since your losing oil. no spots where you park?
  19. pyrotalk
    Ok I will and report back. Thanks
  20. Former Member 68813
    3,524
    983
    US
