Melchior's 2007 white "Comfort" Gen 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Melchior, Jun 5, 2015.
  1. Patrick Wong
    18,210
    6,511
    My post #17 shows the price I paid: USD6.37 each from amazon.com
    Regarding feeler gauges, the best type for checking spark plug gap would be the type of gauge that is composed of stiff wire, bent 90 degrees near the end to form an "L" shape. A flat feeler gauge will not work as well (that type of gauge is better for valve clearance adjustment.)
    Something like this:
    or this:
    Before buying any specific gauge, make sure it has a 1 mm gauge...
    #21 Patrick Wong, Jun 24, 2015
  2. Melchior
    Melchior Junior Member
    74
    Netherlands
    Yes, yes it does. Apologies for making you repeat yourself, and so politely too! :) That is so much cheaper than I can find them here. But if they last 120,000 miles, I'm not so sure it is worth worrying about the price.
    This evening was lovely warm and still, OH doing some working from home so I was free (you know how it is) to do as I wanted. That HV battery ventilation fan was calling me so I pulled some trim off and had a chat with it, the dirty little thing...
    Around 8 years and 207,000km's worth of schmutz:
    Split in half:
    Job done:
    Dead easy job, I'd recommend doing it if you haven't done it before.
    #22 Melchior, Jun 24, 2015
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    :D:D:D:D:D:D
    So glad you took the time to clean the fan...
  4. Melchior
    74
    Netherlands
    Today with 207636 km on the odo, I changed the oil again. A mere 658 km (just over 400 miles) since fresh fully synth 5W30 went in, and it came out with the colour of dark maple syrup (not the same consistency, thank goodness). Obviously this engine has not had its oil changed regularly but for the next few months it will do, until it starts coming out cleaner.
    As for the fan cleaning, this evening after changing the oil I went for a drive and for the first time the sound of the fan running. Either I was subconsciously listening for it, or it is actually louder since being cleaned, I'm not sure. Suspect the latter; less filth = more air flow = more air flow sound.
  5. Melchior
    74
    Netherlands
    Now with 210250km, the oil is still pretty clean looking so the worst of it must be cleaned out.
    Last weekend we did a 500km each way trip. The car was faultless, cruising on the German autobahns at between 125-135km/h it was quiet and still used only around 5-5.5l/100km (around 50 UK MPG). The armrests on both sides are too hard, that's the only comfort issue I have with it.
    Yesterday I had the urge to excercise our carpet cleaner so set to work on the Prius. It doesn't look a huge amount cleaner but does smell a bit fresher. Despite this only slight visual and nasal (?!) improvement, the dirt which came out was pretty shocking.....
    Sorry if you're having your dinner :eek:
  6. Eclipse1701d
    645
    224
    Three Touring
    There is a spray on foam cleaner in the States called Tuff Stuff. It seems to work well at removing stains...
  7. Melchior
    74
    Netherlands
    Another oil change today with 212206 on the clock. After 4500km the oil came out very very dark brown but not black. Still got some cleaning to do inside that engine, but getting better.
    Apart from this, I have nothing at all to report!
  8. Melchior
    74
    Netherlands
    The temperature here is due to drop suddenly in the next days so today I swapped from summer to winter tyres. Whilst under the front left wheel arch, I found the protective sleeve over the strut to be broken and so exposing the strut.
    Is there a way to replace this cover easily? Or maybe even.. "easily"? I suspect not and suppose the whole strut and spring will have to come off, spring compressors used to take the top mount off... and so on. :-/
  9. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Yep, just like replacing the strut. If you're going to go that far, check the strut for replacement. Also, the top mounting bearing, mine was a little stiff and caused my steering input to be less than smooth.
    The work is no different than any other vehicle, just time and a wheel alignment afterwards. Good luck.
    Melchior likes this.
  10. Melchior
    74
    Netherlands
    No action taken on the rubber strut cover yet.
    Nothing at all to report save for the odo ticking over to 220,000km a couple of days ago. It just works - first car I've EVER owned which did!
  11. Melchior
    74
    Netherlands
    Since I've had this car it has felt like it needed the alignment done. It doesn't pull left or right but the steering wheel doesn't sit straight and at full lock it doesn't want to self centre.
    As I write this, the car is up on ramps at a local Euromaster having the job done
  12. Melchior
    74
    Netherlands
    All done, the results are in. They told me it was WAY out. Maybe it's had a bump in the past, or suspension work without alignment afterwards. It feels a bit better now but I only drove it half a mile back to work so far.
    Odometer reading is now 221020 km.
  13. Melchior
    74
    Netherlands
    OCD ODO achieved yesterday.
  14. Melchior
    74
    Netherlands
    APK test today (Dutch version of the English MOT, German TÜV... a yearly safety etc. inspection)
    Passed with no issues, the tester did mention the rear pads are getting low. They'll replace them for just under €100 but I figure I'll have a look for myself when I swap to summer wheel/tyre in the next few days. If it looks like there is a decent amount left, I'll re-check them in 6 months when I swap back to winters.:)
    #34 Melchior, Apr 5, 2016
  15. Melchior
    74
    Netherlands
    It's now a year (give or take a few days) since I bought this. There is pretty much nothing to say! It just works. It is easily the most boring car I've ever owned but its stupidly low (i.e. non-existent!) running costs mean I am seriously considering buying a fun car to run alongside it.
    ODO now reads just over 224,000 km which means I've done 18,000 in a year. If the HV battery holds out (which I am fairly sure it will; there are no hills here and the climate is very mild) then I reckon I'm just going to keep it and keep going.
    To celebrate, here's a photo taken a couple of days ago. The micro car is a Canta LX which is powered by a 160cc single cylinder petrol engine. No driving licence needed, they can be parked on the pavement just like a scooter. Lots of people use them over here :)
    bisco and Eclipse1701d like this.
  16. bisco
    52,256
    nice! can we get more shots inside and out please?
  17. Melchior
    74
    Netherlands
    Of my Prius or the Canta? If the latter, please use Google - the one in the photo above isn't mine, I just happened to park next to it. If the former, then just imagine a base spec white Prius, that's what mine looks like inside and out :p
  18. Patrick Wong
    18,210
    6,511
    Have you replaced the front struts and rear shocks yet? Since the car has logged 139K miles, that repair would probably help the car's handling and ride.
  19. Melchior
    74
    Netherlands
    I have not replaced either. Maybe a previous owner has, but I'm not aware. The handling and ride are fine though so I see no need to do this work.
    Incidentally last weekend I did buy a fun car to run alongside the Prius, a 1992 Mazda MX-5 which is the polar opposite of the Prius. Thirsty (ish), noisy, low, impractical and lots of fun! :)
  20. bisco
    52,256
    i had a '91 for 12 years and sold it with 27,000 miles. lots of fun until i found my '04 prius!:cool:
