2005 Prius just won't start
Discussion in 'Gen 2 Prius Main Forum' started by ChiPrius2005, Jun 25, 2015.
  1. ChiPrius2005
    ChiPrius2005 New Member
    Chicago, IL
    Immediately after parking my 2005 Prius (around 127k) on my block last night, I decided to turn the car back on to adjust parking, and it just wouldn't start. I got nothing: no new lights on dash, no light on power button. Just the flashing red car with the key in it (which I believe is on as long as the car is off?) on the dash. The car doesn't make any noises when I try to start it, except for a sort of low mechanical noise when I step on the brake (which I think always happens).
    Internal lights still work fine. The fob will lock and unlock the car. Interestingly, the button on the driver door (and I assume the ones on passenger and trunk door) that generally locks the car when the fob is within range are not working either, which makes me wonder if it's an electrical issue. This doesn't seem to me like a 12V battery issue, but perhaps I'm wrong? I also got a new 12V last year.
    The car's been working generally okay, but I was planning to bring it in soon for a few things: the brakes have been very squeaky lately (especially after rain, but I feel that's normal), the yellow maintenance light has been flashing for a few days when I turn the car on, and it's been getting pretty poor fuel economy (39 MPG). So I was planning to bring it in ASAP, which I guess I wish I had done sooner in retrospect, but nothing had seemed ultra pressing. Before I went home to park the car, I had dropped a friend off and sat in the car with car on, flashers on for a while, but I didn't think that should be an issue because the car was on the entire time.
    I can ask AAA to come jump it, but I'm expecting I'll just need to have it towed to dealership? Does anyone else have ideas about the issues?
    52,421
    welcome! it does sound like a 12v issue. call triple a, and learn how to check the 12v voltage on your screen. all the best.(y)
  3. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Try sticking the fob in the dash and then see if the car will start.
  4. ChiPrius2005
    Chicago, IL
    Thanks, both of you!
    I did try that, and it didn't. Also, strangely, this fob has never worked while inserted into the dash slot; it's always needed to be outside of the slot for the car to start.
  5. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Try changing the fob battery and (if that doesn't help) check the position of the sks switch.
  6. JC91006
    JC91006 Senior Member
    16,835
    8,605
    do you have another fob that works in the slot? The one you have that doesn't work in the slot is probably a replacement fob, never got programmed to work in the slot.
    If you have one that works, you can just copy that programming over to the one that doesn't work.
  7. bisco
    52,421
    are they original fobs?
  8. ChiPrius2005
    Chicago, IL
    Re: the fob, I think it's original, but not sure. I got the car from my parents, who can't remember. I have another fob, that I think may need a new battery, but it needs to be "re-calibrated" with the car, according to my parents.
    Since the fob is working to lock and unlock the doors, and the red LED light is coming on with it, the dealer's take was that it probably isn't a fob problem. Disagreements with that?
  9. JC91006
    16,835
    8,605
    your problem is probably not fob related. I was trying to fix your problem of why the fob doesn't work in the slot.
  10. ChiPrius2005
    Chicago, IL
    Oh, thanks, yes! That has never bothered me, because I don't put the fob in the slot to start with, but I'll ask the dealer about this when I take it is.
  11. bisco
    52,421
    someone has definitely messed with or replaced one or both fobs.
  12. ChiPrius2005
    Chicago, IL
    AAA just came, tried jumping in the front and the back, absolutely nothing.
  13. ChiPrius2005
    Chicago, IL
    About to get it towed to dealership. Does anyone know if it could be an electrical issue?
    Thanks for help!!
  14. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Check the 15A fuse just above the one I'm pointing to in the picture.
  15. ChiPrius2005
    Chicago, IL
    Thanks! What exactly do I look at? It looks normal to my untrained eye.
  16. JC91006
    16,835
    8,605
    you pull out the fuse and see if it's broken/blown
  17. dolj
    dolj Senior Member
    8,570
    4,354
    Wellington, New Zealand
    You can't really just look at it, check it for continuity with an ohmmeter. If the fuse is good it should read (near enough to) 0 ohms. If it is bad it should read infinite ohms.
  18. Avi's Advanced Automotive
    776
    363
    Remove it and maybe the one above it. Look at them from the side. You will see what looks like a little wire crossing from one side to the other. If that wire, or strip of metal is melted, your fuse is no good. Here's an example:
    The one on the left is (probably) good.
  19. hill
    8,939
    Most say yes - they CAN see the blown element
    your vision may vary
    brucebee likes this.
  20. dolj
    dolj Senior Member
    8,570
    4,354
    Yes, you are correct and I tripped myself up with having a particular thought in mind. What I should have said to be more clear is: You can't always tell by just looking at it. As the image above shows, the two fuses on the right are clearly blown. But the only way to tell for sure if a fuse is good, is by putting an ohmmeter across it and check for continuity. Just because the first fuse above doesn't look blown, doesn't mean it isn't blown and it was this point I was trying to make. Even Avi, who posted the image, makes this point by saying "The one on the left is (probably) good".
