2004 Prius, 176k. Error Codes: P3000; P0A80; C1259; C1310
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zhuying, Jul 23, 2013.
  1. Zhuying
    Zhuying New Member
    Hi there, thank you in advance whoever will read my long post and will help us.
    So I have a 2004 Prius with 176k miles on it. It ran nicely and still could got 48 / 50 MPG until about a month ago, when the nightmare started.
    I rare-ended another car. It wasn't a moderate accident. After the accident, the check engine light was on but still drivable. We had it towed to a tiny shop and let them start to repair the car. They told us they would get it done in 2 weeks. 2 weeks later, they told me they need couple more days.... Long story short, they finally told us we will need to tow the car to the dealer because they couldn't figure out why the engine wouldn't start.
    We towed the car to the dealer and they told us we need to change the throttle body first. Did that. And we get 4 more errors codes as following:
    P3000;
    P0A80;
    C1259;
    C1310;
    The dealer told us we need have both of the batteries changed; 12V battery and the HV battery. And they quote us $3k for the HV battery.
    I did some research and found this local shop (Hybrid Battery Repair based on LA area, 4 and half star on yelp , 8 reviews) would do hybrid batteries and they will come to my house to fix the car. There are three options for us:
    Labor is $100.
    1) 3 month warranty. $800 for a rebuilt battery, each cell will have 100k - 150k miles on it.
    2) 1 year warranty. $1,400 for a second-hand battery from a salvaged car, and it has run 70k - 90k miles.
    3) 2 years warranty. $1,600 for a second-hand battery from a 2011 salvaged prius, and it has run 30k miles.
    The guy told us he has done 40 cars with $800 ones. 90% of them has no problem.
    And the frustrating thing is that the car seems getting worse and worse - it was drivable after the accident; it was not drivable but can be turned on after repair cosmetic stuff at the tiny shop... And now, without a jump start, the car has nothing at all after you tap the big start engine button...
    OK, my questions are:
    1. Based on the error codes provided above, is there anything else wrong that we need to replace other than the batteries?
    2. Is it worthy to get the battery changed?
    3. If we want to change the battery, which plan should we choose?
    4. Anyone else used Hybrid Battery Repair before? How did they do?
    5. We think the tiny body shop should take some responsibilities for drained battery. Sure our car has 176k miles, but the battery was totally fine before get our car to their place. We think their lack of knowledge on the hybrid cars, and a way too long repairing time, caused the both batteries ran low and drained out eventually. How do you think?
    Thank you very much for your time and kindness. We really appreciate.
    Julie
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Julie,
    I would get your Prius to Avi (Avi's Advanced Auto Homepage). He has been helpful to many Prius owners here on PC.
    • I had heard that Hybrid Battery Repair was in bankruptcy, but that is hearsay.
    • The $800 option sound low and is probably not a full rebuild, just replacing a few modules which does not generally produce a long lived repair.
    • Using a low mileage salvaged battery from a 2004 to 2009 (newer is better) Prius is a good path and the price is in line with this approach. I would also spend the time to rebalance/test the modules before installation for a reliable repair.
    • Using 28 modules from a 2010-2013 salvaged battery installed in your existing battery shell is a very good approach. I would again spend the time to rebalance/test the modules before installation for a reliable repair. These newer batteries are not quite compatible as a complete unit swap which is why you do the module swap.
    JeffD
  3. Patrick Wong
    18,210
    6,513
    1. I agree that the 12V and HV batteries need to be replaced. The car will probably be operational after that is done.
    2. That is a decision you have to make, considering how much longer you want to drive the Prius with 176K miles. If you had to pay for the body repairs, you may want to get some return from that investment.
    3. Assuming you want to keep the car for a long period of time, I would select the option that uses modules from a 2011 salvaged Prius. If you want to repair the car so that you can sell it, then the "rebuilt" battery would be sufficient. Note that the battery is not actually rebuilt, it just uses modules from salvaged battery packs and hopefully the modules have been discharged and charged to a common level.
    5. How old is the 12V battery? If it is older than 3 years, I don't think it is reasonable to expect the body shop to accept responsibility for replacing it.
  4. SamM
    SamM Junior Member
    28
    Hi Julie,
    I also have an 04 Prius with the same error codes. I replaced the HV battery and the 12 V battery and the ABS relays. (fortunately I had another prius to take the good parts off of). None of those actions solved the problem and the same error codes are there.
    Did you resolve your problem? Please post the results! Thanks.
  5. JC91006
    JC91006 Senior Member
    16,827
    8,600
    are you sure the parts from the donor car were good?
  6. JC91006
    16,827
    8,600
    Julie,
    I met a battery rebuilder today that seems to really know what he's doing. I was just asking him general questions (not that I need a battery) but his responses were very genuine, not loaded with crap from people that just talk. I asked if he can install gen3 cells into my gen2 battery pack and he told me he would do it for $150 if I provided him with the gen3 cells. I thought that price was incredible!!
    He normally charges $550 to "rebuild" your pack but I wasn't interested in rebuilding, just wanted to do a swap later in the future.
    But if you want a cheap pack with a 1 year warranty, $550 doesn't sound too bad.
  7. SamM
    SamM Junior Member
    28
    Yes the donor car works perfectly with no codes
  8. SamM
    SamM Junior Member
    28
    UPDATE to a solution I eventually came across for my situation causing these codes..
    I had a myriad of dash lights lit for over a year and went through quite an odyssey with multiple 'repairs' that were dead ends. Fortunately the car drove fine the entire time. I swapped out the main HV battery, 12Vbattery, cooling fan, ABS relays, and misc other parts with those from another prius. Thank goodness I had access to that other car or it would have been $10k worth of parts!
    Anyway, the Red Triangle Exclamation, the VSC, and the (!) lights were all lit. Codes for the main battery, ABS, and hybrid control were activated. P3000, P0A84, B2799, and some other intermittent codes. Dealers of course kept saying the main battery was bad and wanted to replace it for thousands of dollars.
    Ultimately the problem was simply a CORRODED CONNECTOR in the electrical wiring harness connector plug. In the right rear part of the car near the 12V battery and blower motor. Some members of this thread had suggested loose or corroded connections as the culprit and they were absolutely correct! Thanks! This is a relatively common problem and can throw codes that have absolutely nothing to do with item referred to in the code (like VSC). So when you get these codes, don't always assume the main battery is bad (even tho the codes indicate that) and spend the extra time tracing and inspecting/testing all the wires and connectors that you can reach when you are making these repairs. In my case it was ultimately simply a $5 repair. Since I experienced this, I have read numerous cases of others having the exact same corrosion issue in the same place. I hope this helps others in a similar situation!
  9. Patrick Wong
    18,210
    6,513
    How about a photo so that we can understand the exact location of this connector?
    Varun Hknz, IsaacO, NotScott and 3 others like this.
  10. yasan
    yasan Junior Member
    sri lanka
    yes spme photo so that we can understand the exact location of this connector
    Varun Hknz and NotScott like this.
  11. valdezcb
    valdezcb New Member
    Honolulu
    Were you able to post a photo?
    I think we are having the same problem.
    Same codes.
    Please help
    Varun Hknz likes this.
  12. Abdulaziz_Barham
    Abdulaziz_Barham Junior Member
    68
    Jordan-Amman
    Three Touring
    Hi
    i am new in this since i got by prius 2008 before 4 month only
    today the red alert appear after i test with OBD2 Bluetooth + my Samsung Phone this code:
    P0A80
    P3000
    please any advice to solve this problem ??
  13. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    i forget to mention that my car had been come from Auction (salvage) from USA to Jordan -
    and checked it with car fox = it was sank ( salt water ) ??
  14. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Those codes imply that you are likely to have 1 or more weak HV battery modules. Do a search on these discussion groups to educate yourself on options for repairing/replacing the 200v battery.
    JeffD
  15. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Since it’s a flood damaged car there’s a change that it’s just corrosion on battery bush bars. So check that if you take the HV-battery apart.
  16. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    this explains why your were getting bad gas mileage
  17. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    yesterday i tested again by Techstream and the HV show these Value :
    Block 1 = 16.58
    Block 2 = 16.58
    Block 3 = 16.57
    Block 4 = 16.52
    Block 5 = 16.58
    Block 6 = 16.59
    Block 7 = 16.57
    Block 8 = 16.55
    Block 9 = 16.56
    Block 10 = 16.66
    Block 11 = 16.57
    Block 12 = 16.50
    Block 13 = 16.60
    Block 14 = 16.62
    and the technician told me that the problem in Block 10
  18. JC91006
    16,827
    8,600
    Test the blocks under load, turn on ac to high and watch the battery drain. If you have a bad block, it'll drop real fast
    Abdulaziz_Barham likes this.
  19. Varun Hknz
    Varun Hknz Junior Member
    17
    Australia
    Technology
    To everyone that wants to see what a corroded connector looks like.
    Here you go.
    HV battery cooling fan fault and fix | PriusChat
    SFO, valde3, bisco and 2 others like this.
  20. Randell
    Randell New Member
    Trinidad
    I have a 3rd generation 2014 Toyota Prius and every so often the code P0A80 Hybrid Battery Replacement code keeps popping up ever so often! I have a obd2 scan tool so i reset the fault code in order for the hybrid system to function! when i perform a reset, it could be weeks till the fault code comes back up again, or it could be days! Time varies!
    So I decided to scarp the hybrid battery and perform some checks on the cells! Every cell i got between 8.02 to 8.05 volts! so seemed like they were all good! then i decided to clean the links that connected the cells together and shine them up good! I also cleaned out the cooling fan for the battery!
    Mounted everything up and started my car and everything was good for a while, but then it still keeps coming up!
    Need help! anyone at all have suggestions based on this experience! would really appreciate some help!
