75,000 Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jrb451, Jul 15, 2015.
  1. jrb451
    jrb451 Junior Member
    59
    Conway, AR
    I have a 75,000 maintenance coming up on my 2010 Prius. I recall past discussions about the merits of replacing the transaxle filter & fluid at different mileage points. I've never done this but is this something I should perform at this time? It's never called for on the Maintenance Schedule, only "Inspect transaxle fluid" and that's not even indicated at this mileage point.
    FWIW - I'm driving less than 5,000 a year since retiring. Just want what's best for my car.
    TIA
  2. JC91006
    JC91006 Senior Member
    16,930
    8,640
    Yes you should change it now. People are suggesting changing that fluid every 60k miles
  3. bisco
    52,755
    if you plan on keeping the car beyond 150k, it's probably worth doing.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    No filter, just fluid replacement.
    I swapped mine at 60k miles.
    Easy DIY job, and inexpensive.
