Drum Brake Thickness Advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gatoman39, Jul 31, 2015.
  1. gatoman39
    gatoman39 Junior Member
    Netherlands
    I have a 2006 Gen II Prius with 120k miles. I recently removed the drums on the rears and want to know if I should replace these shoes? These are the original brakes, the front pads look about 60% worn. Please advise...
  2. JC91006
    JC91006 Senior Member
    16,936
    8,647
    They look fine, the shoes look like they are about half worn.
    gatoman39 likes this.
  3. gatoman39
    Netherlands
    Is it normal for the Gen 2 brakes to last this long? I'm used to brakes last 30-50k miles.
  4. JC91006
    16,936
    8,647
    The Prius brakes are special because there's regenerative braking....everything is electronic until you go under 7mph, then your brake pads/shoes kick in
    I just changed my front brakes for the first time at 170k miles
  5. gatoman39
    Netherlands
    I've done all the maintenance on this car myself and it continues to impress me. There is so much clever engineering in this car. And I can honesty say, that this 10 year old car, every button, knob, switch, etc works properly.
  6. Patrick Wong
    18,210
    6,517
    The new brake shoe lining is 4 mm thick and the spec for replacement is at 1 mm. It looks like you have plenty of lining thickness left. There is very little reason for the rear brake lining to wear unless you leave the parking brake engaged while driving the car.
