News on battery rubber vent smell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Battery driven, May 29, 2015.
  1. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    I'm thinkin it might be a good idea to just put a wrench on all the bolts in the steering column to make sure nothing is loose. unless the Toyota tech actually did that (and it sounds like your dealer sucks, and he didn't), that is the next logical move. like the one guy that said they over-tightened a pinch bolt a bit and the noise stopped. don't go gorilla and break the bolts, but they all need to be tight
    Battery driven likes this.
  2. Battery driven
    Battery driven Junior Member
    UK
    Thanks, will check this tomorrow or rather today in the afternoon .
    From now on, I am better to rely on this forum, local mechanic and my DIY.
    Not sure what they did to a car as every time I've looked at the parking space it was there. They might slipped it into the garage for 10min max.
    At least they weren't arrogant like the first dealer. That matters I suppose especially when you have enough of.
    Thanks will ask probably my mechanic to do this as I can access underneath the car.
    #82 Battery driven, Jun 9, 2015
  3. Patrick Wong
    18,200
    6,472
    Well, before you do that I suggest you open the traction battery case and confirm that is the source of the smell.
    The 2G spec is the same, the car must be IG-ON, wheels pointing straight ahead. The manual suggests that if the spec is exceeded then either the sliding yoke subassembly (which is like a universal joint) or the steering gear itself is at fault.
    !! :LOL:
  4. Hank
    Hank Junior Member
    MA
    Hi Folks,
    Off the topic but have to ask. I see this picture View attachment 80675 of the trunk floor and it looks exactly like that in my '08. I thought mine was damaged and I'm looking at some kind of tape and water drains but this picture suddenly implies it is standard on all prii? What are these things?
    Back on topic, I report that my '08 has same smell that may have appeared after the following events:
    1. replacing 12v battery
    2. running low/empty of engine oil
    3. leaving car for 10 days closed up in hot humid weather.
    4. running A/C for first time this year.
    thanks,
    Hank
  5. bisco
    49,380
    tape is sound deadening, plugs are to drain water i suppose.
    perhaps running low on oil put stress on the battery, and leaving it locked up in the hot humid weather exacerbated the smell.
    but the a/c can get smelly as well, and might need a cleaning. dealer has a special treatment, or you can pick it up at a parts store. i like the charcoal cabin filter, sprinkled with baking soda.
  6. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Hope you used the proper 12v battery when replaced
  7. sclumpf
    sclumpf Junior Member
    Switzerland
    image.jpg In Europa, its the same Problem with smell from HV Batterie-Tubes on Gen2 Prius.
    This is a work with Silicone-Tube:
    image.jpg With the original Ends.... and small drilled Hole for switching...the Modules...
    image.jpg The smell ( Horse or Cow Piss) is 100% from the original black Tubes , in this pic the upper Tube....
    #87 sclumpf, Aug 4, 2015
    gsv and bisco like this.
  8. Hank
    Hank Junior Member
    MA
    Yes, Optima, direct replacement, vented.
    Did also find mouse nesting material in the AC filter today, but it does not smell at all.
    No smell it seems coming from the passenger seat vent while moving.
    Smell is better, but not completely gone after interior cleaning (not including upholstery), and airing out for a day.
    I'm wondering if replacing the battery and/or removing the duct released some fumes/gas.
    wjtracy likes this.
  9. bisco
    49,380
  10. rogerthat
    rogerthat Active Member
    363
    118
    Georgia
    Battery Driven - did you end up replacing the vent hoses? If so, what was the result?
  11. ive
    ive Member
    104
    43
    I have replaced them and the smell is gone. A few days with the windows open during day time on the drive way and all was good after two years of Toyota refusing to take care of it unless I pay for parts and labor.
    Those tubes are not part of the Hybrid battery and therefore not covered by the hybrid warranty.
    I therefore conclude I also do not lose the Hybrid warranty swapping the pipes myself.
    A few more folks have now done so. Once you small again on the pipes after your car is free of the smell, you seriously ask yourself how you managed to use the car before at all.
    My truck this summer. 4h of work all in.
  12. Mendel Leisk
    38,648
    Maybe Toyo says they're not part of the battery? They sure seem like part of the battery: integral vent system, inside the case. Shame on them on putting their heads in the sand, they're doing a "Honda" on this issue.
  13. JC91006
    JC91006 Senior Member
    16,475
    8,393
    Toyota does this even with the Prius transaxle. The warranty only covers a specific failure, has to produce the certain DTC code. If it's not that failure, then it's not covered.
    So in the battery, they only cover the battery if it triggers p0a80 and nothing else.
  14. EDM Prius
    EDM Prius New Member
    Stockholm
    Well just bought me a Prius 2005 last week, it´s a great car but….. A strange smell was starting to get to me. Some of the friend´s took a drive with the Prius, came back and told me the car was stinking horse….
    I just could not get it, but my nose soon found its way to the rear vent for the battery and YES it seems like the motherload of stink.
    Glad I found this thread to set things straight with the smell, unfortunately there is no easy way to fix this. But the smell is big and musty so I have to do something.
    /J
  15. ive
    ive Member
    104
    43
    if you dealer refuses to swap them, best for silicone hoses, DIY,. Takes 3-4h and is not that hard. It will take a while for the smell to completely disappear. Best to vent a couple of nights (and days) with all windows open, e.g. in your garage.
    iPad ?
  16. Mendel Leisk
    38,648
    Maybe if enough owners raise a stink? :whistle:
  17. Battery driven
    UK
    I have replaced them silicone tubing and it is much better. Occasionally I still get a funny smell but this might be to something else or there is a leak in my modification. I believe I will never completely get rid of the smell, however it is substantially better now. It wasn't very difficult job and I done it with a help of my partner. Obviously you must take a precaution as you're dealing with high voltage. Original tubes were very sticky and they smelled very bad.
    #97 Battery driven, Jan 26, 2016
    ive and bisco like this.
  18. bisco
    49,380
    well done. hopefully, it's just residual and will clear with time. all the best!(y)
  19. Battery driven
    UK
    On another note: After a lot of :mad:arguing, :cautious:complaints, appointments...Toyota fixed my steering wheel issues, with replacing complete steering column. So one problem less.:)
    Another two to go:
    - I am still having problems with clunking noise from the front left side of suspension when driving over speed bumps, pots or entering/exiting driveway. Front left end also feels very wobbly. There is a rough rubbing noise present when braking and slight pull to the left.
    Replacement of both front shock absorbers (right replaced second time as it was started to leak after few months), roll bar bushes, new brake pads, new brake discs did not solve the problem.
    - There is also rough vibrating engine noise when the petrol engine starts or stops.
    Response from Toyota mechanic. Regarding the suspension noise he advised that is normal...
    And also that I shouldn't worry about the engine noise.
    Alright back to brainstorming.:sick:
    None of the local mechanics were able to trace the problem. Everyone says its all tight and secure...
    Previously I had a problem with wishbone bush squeak which stopped after sparing on silicone spray.
    Again mechanics says wishbone is fine :(
    I decided to make an old school test with moving off with parking brake and open bonnet.
    As you know this ain't easy with Prius, but I somehow managed. My brother observed and agreed that engine was rocking excessively.
    At least this confirms a problem with engine mount but how to find which engine mount is bad. They seem to be very expensive too, at least original from Toyota.o_O
    #99 Battery driven, Jan 26, 2016
  20. ive
    ive Member
    104
    43
    Just wait. I gets less and less over time. The more often you can park the car with the windows open, e.g. in your garage over night, the faster it disappears. My last nest was the middle console storage space. A few nights with the compartment open and any paper discarded, it also stopped.
    If you kept the smelly tubes, have a sniff in a view weeks. You won't believe you had that stuff in your car before. It is soon recognisable.
